Question about Intel D101GGC Motherboard
Buzzer sound from motherboard spkr
Iam getting a buzzer sound on regular intervals from the mother board. is it indication of something? if yes, then of what? i am worried that there is something wrong with it. please solve my prob if anybody has faced this situation before.
  • 2,351 Answers
Hi kuldeep11203, your Intel D101GGC board uses the Award bios.
Though the descriptions vary, I suggest you check your CPU heat-sink & fan assembly. Clean assembly from excessive dust build up. Remove CPU fan if possible & clean the heat-sink. Check the CPU fan, it may be turning too slowly & may need to be replaced. The average CPU fan runs between 2000 Rpm & 3000Rpm. Blow out your power supply with canned air. Disconnect & than re-connect the Main power connector (2x12) on the board. Item No# K, found on page 11 in your manual. Try these first. See if the buzz sound stops after a good cleaning.
If not replace the Heat-sink assemble with a new one. Check this link for a new assembly for LGA775 socket;
Good luck kuldeep11203!
Posted on Nov 22, 2008
Installing an internal speaker on a Desk top pc mother board do you need to reconfigure your system.
Typically, the speaker is connected with 2 or 3 wires. The connector block should have a pin labled "SPKR" or "Speaker". From there, count three up and find a pin labeled "+5v". These two pins are typically separated by two ground pins.
So, the connection would be: spkr, gnd, gnd, +5v. The ground pins may, or may not be used depending on your design.
Nov 06, 2014 | Computers & Internet
I am unable to get Sound in my system
Download Here
*Select an Operating System: Windows XP (Home/Professional)
*Select Download Type: Driver
*Select the Audio Driver
*You can also download other driver for your motherboard
Jul 27, 2010 | Intel D845GVSR Motherboard
Require Device Drivers Only For VGA ......??
i lost my mercury mother board driver therfore iam not installing my vga & sound so help me which driver of mother board supported .
Jan 15, 2010 | Mercury P4VM800M7 Motherboard
E machines computer, im845g mother board connection pins
The three cables are for power, reset, and an indicator light. They will all be connected within one centimeter of each other on the motherboard. You will see two rows of metal pins about five mm tall. There will be white letters printed on the motherboard. PWR, HD, RESET, SPKR. You want your indicator light connected to the HD pins, the power button to the PWR pins, and the reset button to the RESET pins.
Please post again if you need more help.
Mar 18, 2009 | Computers & Internet
Intel d101ggc making buzzer sound at equal intervals and then pc hangs.
OK this buzz is suppose to be a beep.
The device you described is called apezo electric speaker and is suppose to beep a post code to help define a problem.
If it's buzzing and not beeping there is either a fault with the piezo or the motherboard is not receiving the amount of power it needs to properly drive the speaker.
OK back to the post code. The patern is important it should be a series of long and short beeps. The fact that it is buzzing and not beeping may make it difficult to determine the difference between long and short beeeps.
Try your best to hear a pattern in it. Whether its constant beeps or 2 short 1 long or any other discernable variation please post back the number of beeps and if there is a long or short pattern.
please post back here
Nov 21, 2008 | Intel D101GGC Motherboard
No sound
here is the link
Aug 06, 2008 | Electronics - Others
Asrock Chipset Mother board Sound Drivers
Drivers for CMI 9749 are located here :
Nov 24, 2007 | ASUS Intel 845 Chipset P4B (P4B WOA)...
Intel D101GGC Motherboard Logo
323 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
