We just moved in Friday and our landlord has no idea why the water doesn't dispense and the ice isn't being made. I checked the water line from the wall and the water is flowing just fine...so the fridge is getting water. My landlord has removed the filter, but hasn't put a new one back in yet...I tried putting the old filter back in, but the water is still not dispensing. Any suggestions? Thanks
4 Other Users Have The Same Problem
Comment by Whiteboots, posted on Mar 31, 2008
Ice maker Kenmore side by side fridge. Will make ice, will not dump ice into bin. Water line to ice maker is not frozen. There is no filter on the water dispenser leading to the icemaker.
Kenmore 363-57552791
Comment by JacJr74, posted on Nov 21, 2007
My ice maker quit working the other day. I checked evrething out and found that thte gear on the ice dump were frozen. So i took it out and let it defrost,then put it all back.Now the ice dump is working but theres no water coming into the ice maker, but there is water coming out of the water despencer on the door is working.
Comment by force, posted on Nov 14, 2007
The Ice machine works great but no water in the door. Replaced the filter even put the plug in and tried. No water to door. When we first changed the filter it worked for about two days.
Comment by seamore, posted on Nov 12, 2007
cHECKED THE WATER SUPPLY AND CHECKED THE FILTER. tHE SOLENOID VALVE HUMS WHEN YOU CALL FOR WATER BUT NOTHING COMES OUT.
Was this solution helpful? Show your Appreciation by rating it:
Also, no ice cubes. I suspect that the line is clogged to the ice tray.
How do I clean that line? Is there a filter beyond the upper connection in the rear of the refrig? If so, how do I acces it?
Thanks.
Rating: 0%, 0 votes
Post a New problem for Amana ASD 2624 Side by Side
Email this problem
