Question about Marantz Audio Players & Recorders
Marantz PM 4000 has cut out
My Marantz PM 4000 Amp has cut out. All the lights are on when powered up but no sound. CD player and speakers are fine. Probably happened after my 2 year old son turned the volume to full for the 100th time.
May be the problem solved here :
Posted on Dec 04, 2008
Pm 7000 marantz cuts out when I turn up the volume. Works well at lower volumes... tried other speakers and no issue? Is there a way to check the receiver itself?
If the device works on other speakers then it is probably working as it should. You need to check if the is an issue with the speakers that cause it to cut out. Make certain they are the right Ohms for the Marantz. Check the connections to them. It could be that a safety device is clicking in to protect them amp due to some overload problem, caused by the speakers themselves. It might even be one speaker that is playing up. Try testing one speaker at a time, by not having the other connected and the balance control only to the one connected.
Dec 27, 2017 | Marantz Audio Players & Recorders
Marantz problems
The speakers are 8ohms. Always try using speakers 6 or 4ohms. For B&W 683 on PM 6004 is too low. You should go for PM 7000 or 8000 series to catchup with 683. Also when you increase the volume please decrease the bass as well.
You need 8ohm 55w to 90w or 4ohm 80w to 110w speakers.
Jul 20, 2014 | Marantz PM6004 Integrated Amplifier
Marantz pm 7200 loudspeakers do not cut off when headphones pugged in
Some amps have a button which you press to mute the speakers when the headphones are plugged in. Sometimes marked "Speakers on off". If it hasn't then a new headphone socket would not be expensive to fit. As long as the amp producers sound I don't see any future problems. The previous owner may have used the headphone socket a lot, and simply wore it out!
Jul 19, 2012 | Marantz Audio Players & Recorders
Hi! Have a problem with an old Marantz PM 310 amp. Sound won't come out of the right hand speaker initially. Much crackle from the left hand sppeaker too. Sound WILL come out of the right speaker if I...
I asume you don't have test gear? if you do, google the sevice manual and do the checks. If not Check the transisters on the heatsink they have a tendancy to go dry joint with age. With the cover off of the amp with a source running through it Cd player you could lightly tap around the pcb with the handle of a screw driver dont use anything metal and not you fingers. stay away from the mains supply, transformer rectifier and big capacitors When you tap in the area of a dry joint the fault will change either get better or sometimes worse. It could be the volume or the balance pot. maybe component faliure but you will need basic test gear to check out. Hope that this helps but if your a novice don't touch it you could get a nasty shock
Nov 24, 2010 | Audio Players & Recorders
Hi I have two marantz amps witch cut in and out when run from
In stereo terms your system is "clipping" which means you are pulling more amps than the system can handle. If it happens only when you use the mixer, I'm thinking the mixer cant handle the power. Check the specs, It should show maximum amp input.
Jun 04, 2010 | Audio Players & Recorders
I have a Marantz PM-66SE Ki amp which appears to have a problem with one of the channels which is only outputing about 10% of the volume of the other channel. Have tried swapping speakers and cables around...
I have exactly this same problem with my Marantz PM60100SE - one of the channels seems to have lost power and is much much quieter than the other one.
Did you find a solution to this? Anyone have any ideas?
May 20, 2010 | Audio Players & Recorders
You will have to use an amplifier to power the speakers from the cd player, the output on the CD player isn't enough. You will need to hook the CD player to the amplifier using the red and white wires, on the CD hook them to the OUT and on the amp hook them to the CD or Aux or Tape in. Then select that input on the amp and enjoy the music.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
Nov 05, 2009 | Marantz CDR631 CD Recorder
Marantz Pm-7200 left channel weak compared to the right
hmmm. Let's start by swapping the wires you are using for your speakers. Double check the wire connections first, then take the left and place iton the right and vice versa.
May 05, 2009 | Marantz PM7200 2-Channel Amplifier
Marantz PM-48 connecting to TV
look on the back of the TV and there should be L/R audio outputs (white & red), connect this to a spare input of your amp via a connecting lead eg. AUX or any other input except PHONO.
hope this helps.
Oct 19, 2008 | Marantz PM-68 Amplifier
I have a marantz integrated stereo amplifier PM-57 and it keep cutting out regularly. its sounds like a relay is clicking in and out. what can i do?
please disconnect loudspeaker one by one until the problem is goen -and fix the bad one by change the cabel first and the speaker second if all above does not solve the problem send your amp to service center to repair.
May 27, 2008 | Marantz Audio Players & Recorders
700 people viewed this question
Top Marantz Audio Players & Recorders Experts
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
