Question about Toro Blowers Rake and Vac - Electric Blower/Vac - 51573
Toro SIngle stage snowblower 221QE Whate type of fuel? Plan gas ?
Cherylcummings7@yahoo.com
5 Suggested Answers
  • 37 Answers
SOURCE: toro 421 snowblower won't start
check to see if in line fuel shut off valve is open.If so,sounds like carb is gummed up.
Posted on Jan 28, 2009
  • 2248 Answers
SOURCE: Toro 824 snowblower starts fine but won't keep running and new gas new plug as well cleaned the whole carb
Is there an adjustment screw on the carburetor if there is turn it out a little at a time. This sets the amount of gas going into the carb and lets it run the way it should. I hope you have one as this is the answer to many engine problems. When you say you cleaned the whole carb did you clean the fuel jet. It won't run if the jet is dirty.
Posted on Feb 07, 2015
Terry Corrow
  • 10875 Answers
SOURCE: What type of engine oil should I get for my 526 Toro snowblower
10w30
Posted on Jun 18, 2015
  • 48512 Answers
SOURCE: What type of gas and do I add oil to run A Toro Snowblower ccr 3650 65 hp?
there is no such snowblower made . 65 horse power is bigger than a small auto
Posted on Nov 13, 2015
Snowblower won't start
"Gone thru Carburetor" Did you check the Needle valve Seat? The ethanol gas ruins the seat if they are made of rubber and the needle valve is all metal.
Does the Float actually move up and down as it's supposed to? sometimes the ethanol gas absorbs too much moisture and the needle valve or pivot point of the float rusts.
Mar 01, 2015 | Toro Power Clear 418 ZR - Single Stage...
New 621E toro snowblower running on prime fuel has been running now will not stay on with choke out what do i need to do
HOW OLD IS THE GAS . PLEASE DRAIN THE GAS OUT OF BLOWER AND PUT FRESH GAS IN IT I WOULD ASLO GET WITH THE STORE THAT YOU BOUGHT IT FROM TO EXCANGE THE BLOWER
Feb 21, 2015 | Toro Snow Blowers. Power Clear 621E 21 in....
My toro snowblower will not start,with gas or starting fluid,no spark,stater rust cleaned off flywheel,carb cleaned,bench set,It fired with starting fluid ,but the carb had gunk in float bowl,what am
Clean out the float bowl as well clean out the fuel jet in the bolt that holds the bowl on. There usually are very small holes in this jet and if you can't see or blow through them you have to clean this out. Will not run if this is plugged. You can blow this out with an air com presser or a very small wire to push through it. Don't force anything through this hole or you could damage it. If it will start when you put a spoon full of gas in the spark plug hole and replace the plug and stalls in a few seconds it's usually a dirty carb or dirty jet. You can buy a cleanser as well to spray if needed.
Dec 26, 2014 | Toro Powerclear 221qe Electric Start...
Snowblower leaks gas on garage floor
Is it coming from the carb or tank? Either way replace the fuel lines, they crack an get pin holes in them an cause problems. If it comes from the carb get a rebuild kit an, very cheap, an replace the seals.
Feb 28, 2014 | Toro Powerclear 221qe Electric Start...
Toro power clear 418 won't start
does it have good gas in it , clean it out if it is 2+2 mix put new mix most small snowblower are 2 stroke which takes gas oil mix , make sure you clean plug and are getting spark
Feb 18, 2014 | Toro Power Clear 418 ZE - Single Stage...
Not getting gas
do a fuel system service on your unit. clean carb and fuel tank check fuel lines etc
Feb 13, 2014 | Toro 826OXE 2-Stage Snowblower 38624W
Not getting any gas
Most people leave gas in the tank year round. This is a problem for engines that are only used a few months out of the year. Old gas will cause the carb to gum up and not allow gas to pass thru into the combustion chamber.
You will need to pull the carburetor part and clean it.
check out this YouTube video. It shows how to clean a single stage snowblower carb
http://www.youtube.com/watch?v=KYj5oH0vNVg
Dec 15, 2013 | Poulan PRO® PR 621 Single Stage 21 in. Gas...
How do I clean carburetor
check out this YouTube video for cleaning a single stage snowblower carb.
Dec 15, 2013 | Toro Power Clear Snowblower 418ZR - 38272
Toro Power Clear 418 snowblower wont start after sitting through summer
Check the fuel line to the tank, and see if another one is inside, maybe it fell off, or it's filter is clogged.
Nov 29, 2013 | Toro Power Clear 418 ZR - Single Stage...
Toro Blowers Rake and Vac - Electric Blower/Vac - 51573 Logo
429 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
