Question about Video Game Consoles & Games
I deleted the hard disk off the ps3 is there any way i can get it back
  • 586 Answers
    WIth the help of  Recovery software it is possible.
   Thanks and dont forget to rate.  Bye
Posted on Nov 21, 2008
How can i delete the email & password on a secondhand 160gb ps3 please
http://uk.playstation.com/ps3/support/general/detail/linked391089/item391133/Delete-data-on-the-hard-disk-drive/
Oct 17, 2012 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console My PS3 hard disk is corrupted, It say to restore i put restore and nothing had been restored Bid
Corrupted hard disk? Lets see....
You could attempt to boot up the PS3 in safe mode and restore the file system (should delete any corrupted data). Describing how to start up your PS3 in safe mode would just be confusing, so instead here's a link to the official page on the PS3 Safe Mode feature.
Follow the instructions, and then I'd say try options 3 (Restore File System). If that doesn't work, try 4 or 5 (Rebuild Database or Restore PS3 System).
If that fails, you could just replace the hard drive. The PS3 uses standard 2.5inch SATA laptop/notebook hard drives (5400 or 7200 RPM). They can be found online at any computer parts website; for example, Tigerdirect.
If somehow the new hard drive doesn't fix it, or you don't feel like buying a new hard drive, you could send the PS3 back to Sony. If you're under warranty it's free; otherwise it's expensive (150$ I believe).
If you request the repair service, they send you a box, you put the PS3 in it and ship it back to them. A month or 2 later they send you a fixed/different PS3. Simple, but takes forever to get a working PS3 back which is why I suggest you try a new hard drive first.
Anyways, hope you get it working soon!
Mar 22, 2011 | Sony Playstation 3 (PS3) Console
Cannot start correct hard disk not found
Try this:
Enter Recovery Mode.
Choose "Restore PS3 System". WARNING!: This Will Delete All of Your Data!
If this doesn't fix the problem, replace your hard disk drive.
Mar 22, 2010 | Sony Playstation 3 (PS3) Console
Yes my playstation 3 is saying hard disk needs to be rebuilt and it only says ok so i click ok another message pops up and says hard **** not found hard disk data will be deleted and lets you selesct ok or...
you could try to remove the hard drive then boot up, then put the hard drive back in and boot and see if that helps or you can try to rebuild the file system and database.
To get to ps3 recovery console to rebuild the database or the file system(neither will format the hard drive), when the ps3 is in standby mode(red light) press and hold the power button till you hear a double beep.
Most of the time the double beep comes after the ps3 beeps once then twice then turns red again when red again release and press again real fast and hold,... this time you will here a "beep" then " double beep beep" then you release and you will have the options to rebuild the database or the file system. basicly keep holding power button from standby till you here a double beep, if it shuts down try again, once you get the hang of it its easy.
if rebuild database and file system doesnt work then you may have to choose yes on the reformat option but it will wont hurt the ps3 itself just anything you have saved on it.
Sep 22, 2009 | Sony Playstation 3 (PS3) Console
Ps3 game will not start because of not enough hard
Delete Some Files like Music and PIcture and if you still have to much data delete some game data
Aug 13, 2009 | Sony Playstation 3 (PS3) Console
Hard Disk is corrupted, would rather not reformat.
This is to do a factory hard reset on PS 3 all files and systems settings will be deleted and restored back to factory this should hopefully solve your hard drive a problem. depending on the system reformat clould take 3 1/2 hours do a full format as to clear
Faulty memory
1. Power Off the PS3 via the power switch in back and power back on w/switch.
2. Hold Power Button on the Front until you hear 3 beeps.
3. Then go through the initial setup and then run a full Format via System > Format.. You may need to have our AV cables ready if your using HDMI (in case HDMI isn’t detected after initial reset)
Jul 27, 2009 | Sony Playstation 3 (PS3) Console
40gb ps3 not reading any discs
clean off a disk and see if that helps. if it doesn't, the laser lens inside the PS3 may be dirty. you may have to have someone check, if nothing works, to see if the laser itself has broken. also, listen to hear if the guts are working at all.
Jun 12, 2009 | Sony Playstation 3 (PS3) Console
My ps3 freezes in the main menu Yea i have the same problem... when i turned on my ps3 and was gonna log into my psn it just freez up.. so now i'm stuck at the  "Log in Naddepusen" (psn) with the wave...
**USE A FLASHDRIVE FIRST TO BACK UP YOUR SAVED GAMES**
Settings > System Settings > Restore PS3™ System
Delete all hard disk content and restore the system software to its default settings. Follow the on-screen instructions to perform this operation.
After the operation has been completed, the initial setup screen will be displayed. Follow the on-screen instructions to complete the operation.
Notices
  • When you perform this operation, all data on the hard disk will be deleted. Also, the system software will be restored to its default settings. Be careful not to accidentally delete important data as the changes cannot be undone. Data loss or corruption is the responsibility of the user.
  • Do not turn off the PS3™ system during this operation. If the operation is cancelled before completion, the system software may become damaged, and the system may require servicing or exchange.
  • During this operation, the power button on the system front and the PS button on the wireless controller are not active.
  • You cannot use this feature to go back to an earlier version of the system software.
  • You can shorten the formatting time by selecting [Quick Format] from the hard disk format methods. However, in this case it may be possible for some deleted data to be restored if a specialized tool is used. Select [Full Format] when formatting a hard disk that contains important or sensitive data.
May 29, 2009 | Sony Playstation 3 (PS3) Console
Acount choices do not show up when the console is turned on
Your hard drive is not being accessed by the other parts of the game, for what ever reason. I've seen this problem a lot! There's a laundry list of reasons why this happens. I can't really determine the specifics of YOUR unit unless I looked at it, which is virtually impossible. The best solution I can offer you is this: While the console is in "stand by" mode, hold down both the power & eject buttons simultaneously. You'll hear a single beep, then a double beep. Once you hear the double beep, release the buttons. This will bring up a six item menu. You'll need to pick option #3, first. Hopefully this will help you with your problem. If it doesn't, you'll need to choose option #6. The draw back of this option is that it will delete all of your saved memory; erasing EVERYTHING! But it may be the only way to keep from having to send your console to the repair shop. You can re-load your downloaded games,demos & trophies from the PlayStation store free of charge. If all else fails, you can contact PSR repairs at www.psr1.com .
May 16, 2009 | Sony Playstation 3 (PS3) Console
PS3
ur hdd is corrupted and to play or use ps3 further you can send to sony to fix for warranty or buy another hdd of any size.
Apr 21, 2008 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
18 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
