Question about Philips Televison & Video
Hello, I recently purchased Philips 37PFL5603D TV. Unfortunately it seems like there is a color/resolution problem, as the picture looks really bad - colour gradients are not smooth(gamma rings) and in general picture quality is very poor. I have Sony RDR-HXD970B DVD/HDD-Recorder 250GB, which I tried to connect to the TV using the standard cable that comes with the TV, then also tried Philips HDMI cable, but nothing seems to improve the picture quality. Also, there seems to be some kind of problem with the screen refresh, as it's noticeable. I would really appreciate any help, as I'm clueless. :( Are there any additional accessories needed? Is the hardware not compatible? Or maybe there are some special "hidden" settings that need to be adjusted? Thanks a mill for your help, Wirginia
  • 1779 Answers
SOURCE: RCA DLP HDTV POOR COLOUR - TOO MUCH GREEN
Hello:
It sounds like your light engine needs replaced, should be around $400.-600. depending on who does it. I have seen the lamp cause similar symptoms but not that likely.
Posted on Feb 29, 2008
  • 34 Answers
SOURCE: I am trying to connect
Hello
by befault your dvd recorder is transmiting signals via component video, so what you need to do is this connect both cable HDMI and Component or just a video cable then go into setup and then select video out via HDMI your video will go off on the screen and then with TV remote slect input source HDMI on TV and it should work fine.
Thankyou
Posted on May 10, 2008
SOURCE: Black/Green Distortion - Picture Quality - Wharfedale
This is no solution but a point in a probable direction.
A tech guy told me ALL the LCDs they have seen in their repair shop have "swollen" capacitors, this is due to voltage instability. Lowering the internal voltage regulator and replacing the swollen capacitors (which eliminate noise) apparently restores the LCD to new working quality. Without actually "seeing" my problem the tech said that should repair it. I have not tried this yet but eventually will begin that way.
Posted on Jun 08, 2008
Slinteriors
  • 8617 Answers
SOURCE: poor picture quality on old 55" rear projection phillips tv
replace the coolant in the CRts. Very common problem with the older rear projection tvs. You can get the coolant replacment kit at the following link which contains the coolant and instruction CD.
http://servicemanuals.vstore.ca/
Posted on Dec 20, 2008
SOURCE: Poor picture quality
Hello Paul. I have this same monitor, but rebranded, Access the service menu with the remote control:
With user’s RC
1. Power TV On
2. Press Menu button and call up User OSD Menu
3. Select Sound-> Balance
4. When Balance value is “0”,Enter 0->5->3 ->2 in sequence.
Note: If necessary, re-do number keys.
5. Factory OSD appears.
6. Press the standby button then AC turn off and restart the TV, which can exit factory
OSD menu.
Now you will be able to change the values for Red Green and Blue channels. I also hated this TV, but after adjusting the colors it's looking great! Hope you could fix it too! :)
Posted on Jul 19, 2010
I have aphillips tv, model number 42pfl7603d/10. The stand which it sits on at base of tv has broke, I'm looking to find where I get a replacement one. My walls will not support brackets for it
The only place I found that has one is in the UK
http://www.ebay.com/itm/TABLETOP-STAND-FOR-PHILIPS-42PFL7603D-37PFL7603D-37PFL5603D-42PFL5603-LCD-TV-/360506039050?pt=UK_Home_Garden_LivingRoom_TV_Furniture&hash=item53efd59b0a
Dec 06, 2012 | Televison & Video
Hello, I have a 60" Phillips rear projection TV
It sounds like a convergence problem; depending on your skills it may or may not be something you can do (parts cost on EBAY will be under twenty dollars).
I will attach some convergence photos: does your set look anything like these?
If it does and you can solder etc I can tell you the best place to get the parts and how to do it.
Before you rate this information let me know what you find.
SD TECH
Aug 16, 2011 | Philips 60PP9202 60" Rear Projection...
I have a Phillips 60" rear projection TV. recently
Tv have a problems known as a convergence problems,it is dead.The tv convergence board it is dead,that why ur tv picture are R,G,B colors lines mis alignments,have colors shadows picture or 3D picture lood alike?The tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Jun 01, 2011 | Philips Televison & Video
50' philips plasma tv has sound but picture is distorted
I sugest you to change the video resolution settings on the PS-3 to see if TV sets to any one resolution...if you have any other video out (analog from PS3)...connect the out to TV and check video at different resolutions. If PS3 has Deep Color settings turn it OFF.
Apr 10, 2010 | Philips 50PFP5332D 50 in. Plasma...
Blues' appear more green
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 05, 2010 | Philips Televison & Video
Resolution on my media centre pc - HD TV not so good...
HDMI is a higher starndar than s-video.. I suggest you try that.
did you look into the manufacturer's website for an udated driver?? try that too.
Dec 25, 2009 | Nvidia GeForce 6600 Graphic Card
I have recently purchased a new HD TV. I have
Perhaps your computer's output is at a resolution your tv can not deal with. Try using a different resolution on your computer, and the PC input is selected on the TV.
Nov 04, 2009 | Computers & Internet
Just purchased tv and the quality of the picture is still fuzzy tried to mess around with the resolution but it still isnt very sharp at all
The TVs produce picture using entirely different methods. Usually the colors and especially level of black color are better on plasma, LCD will have some trouble various shades of gray and black especially shading on peoples faces etc.. This is not a defect in the LCD just a limitation in current technology.
Apr 26, 2009 | Televison & Video
Phillips Magnavox 60in rear .....very hard to view
well......you can fix it and its not that hard but your not going to like the price of the fix. its time to purchase bulbs. as to how to do that on your particular tv you will have to search for that one on the web. sorry about the bad news. it would almost be cheaper to buy a whole new set.
Jan 05, 2009 | Philips 60PP9202 60" Rear Projection...
Televison & Video Logo
221 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
