Question about Smeg STA4645U 18" Fully Integrated Dishwasher with 5 Wash Cycles, Stainless Steel Racks, 9 Hours Del... Dishwasher
Bleeping dishwasher - not running
I have a smeg integrated dishwasher with Aquastop on water inlet pipe.
When starting the program, it runs for about a second at a time, then stops, beeps twice, runs for a second, beeps twice.....etc.
Originally it would pump out OK on program initiation, but do the above when trying to fill with water (opening the solenoid valve for about a second at a time). It would eventually get past this and run the cycle, but now it won't and just keeps beeping and stalling. It will do this for hours and seems to do so regardless of the program I select.
Any suggestions where to look?
SOURCE: SMEG DI 612CA. Dishwasher
Pisss!!! Comin from my asss!!
Posted on Jul 24, 2008
SOURCE: Smeg Dishwasher STA945.1, flashing lights
have you check the pipe's for blockage
Posted on Sep 11, 2008
huuum
  • 750 Answers
SOURCE: Smeg Dishwasher DI612C
Hello Friend,
Welcome to fixya.
I'm Huuum and happy to assist you,
Try this remedy.
When we have an error code this is the remedy.
This can reset the system.
First turn it off.
Cut power to the washer at the breaker and wait a 5 minutes then restart it.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
Write back right away and let me know that it worked and solved the problem .
Bless You
Please remember to enter a rating here when you finish!
How old is the appliance?
Here is an interesting report I just read.
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Bless You
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF.
Posted on Sep 23, 2008
SOURCE: smeg di612ca (e2 error msg)
http://ukwhitegoods.co.uk/modules.php?name=Reviews&rop=showcontent&id=20
Under installation it mentions this problem
http://www.smeg-service.co.uk/support/index.php?a=1&cat=4#5
list of error code explanations
Posted on Sep 29, 2008
  • 134 Answers
SOURCE: Smeg Dishwasher SA 620 X-Soap dispenser won't open!
Sounds like the solenoid in the dispenser has failed. Youll need to replace it
Please leave feedback
Thanks
Rob
Posted on Feb 13, 2009
Siemens Dishwasher flooded. Now it doesn't take in any water and does not finish program. Aquastop filter?
Typically all dishwashers have a maximum full switch that is located on the bottom of the inside of the washer, on some it looks like a round plastic cap about two to three inches round, if you grab it it will move up and down as much as a half inch, this is a float that when the water level is at the maximum will turn off the water inlet solenoid, I have had something small (in my case a small lid) get under this float holding it in the up position so it would not allow the washer to fill with water, after removing the lid the float went back to the correct position and everything worked fine. I would say this is happening to you by what you say has happened.
Nov 12, 2013 | Siemens Dishwashers
I have a smeg 12059 integrated dishwasher which will not spin. I have emptied the water from the bottom compartment , cleaned the filter and turned on and off at the mains and only the lights will come on...
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect.
Check how to remove the control panel: http://www.espares.co.uk/advice/dishwashers/a/3/1287/how-to-replace-a-hotpoint-dishwasher-fascia-p.html
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor. The water pressure must be good and the spraying must be seen to be good. If there is low pumping or pressure then the spray arms will not turn around to inject with pressure. If so the pump must be checked for clogging.
Oct 19, 2011 | Smeg 24 in. DWI612 Built-in Dishwasher
My SE53200GB/01 fails to input water. I have checked the inlet supply hoses and filters and they are clear. I have tried different programmes and they all activate but the water fails to enter the main...
Your aquastop system is activated :deactivate by turning off the water supply, running the dishwasher so that it is expecting to fill (if you hold the grey square box at this point, you should feel it slightly vibrating, which is a good sign that it is working ok). Clear the filter in the aquastop. Turn off dishwasher via the reset as per model. Refit valve, turn on supply and check for water tightness. Finally, restart the the d/w and if there was a fauklt with the aquastop ( and not a different fill problem) this process should have reset it. Hope this helps.
Dec 08, 2010 | Siemens Dishwashers
When starting wash cycle the dishwasher cda cw447 doesnt appear to be getting enough water in and is making a droning / whirring / electrical ? noise. pipes all connected ok inc aquastop water supply unit,...
Try removing the inlet pipe, and refitting, might fix it, else likely that the
Inlet water soleniod failing/failed or tiny mesh filter (it does come out for cleaning) behind the inlet hose clogged. Temporaily bypass the aquastop water stop unit; it might be the culprit!
A replacement solenoid is usually only about £10 from www.espares.co.uk, or ebay sellers (no connection with these but they are very good), fits in minutes (2 or 3 electrical spades ,and a posidrive or two) and usually fixes all water related problems. the noise you can hear is probably the solenoid trying to actuate, will be droning/buzzing sound.
could simply be stuck with some foreign matter in there that's got through the mesh filter but unlikely. they normally fail and sound terrible.
Don't throw your dishwasher away for the sake of a £10 part.
Good luck
Sep 12, 2009 | Dishwashers
Drain was clogged and the dishwasher overflowed. It's a 10yr old Bosch dishwasher. Now water won't flow into the dishwasher but it runs through the cycle and dishes arent clean.
Probably the aquastop (if you have one). We have a similar problem after our owerflow. The dishwasher is starting and running through the programs but no water is coming.
Jul 31, 2009 | Bosch SHU9915UC Dishwasher
Newly installed integrated dishwasher will not start
have you checked that the water inlet pipe is not kinked or that it is turned on. some models have water pressure sensors and wont work on low pressure supplys
Apr 26, 2009 | Smeg Dishwashers
Smeg DI 612 C Domestic Dishwasher
I was told by a SMEG engineer that I needed to replace the detergent dispencer. Just waiting for him to get back with a new one.
Aug 15, 2008 | Smeg 24 in. DWI612 Built-in Dishwasher
Mar 04, 2008 | Smeg Dishwashers
Zannussi de4744
Aquastop on water inlet tripped. Turn off and slightly undo main inlet hose. find water inlet valve and remove thin pipe from nipple. Turn m/c on for a few seconds, turn off and replace all pipes m/c will now fill and continue
Dec 05, 2006 | Zanussi 18 in. DE4744 Free-standing...
Smeg STA4645U 18" Fully Integrated Dishwasher with 5 Wash Cycles, Stainless Steel Racks, 9 Hours Del... Dishwasher Logo
79 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Marvin
Marvin
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
