Question about Kitchen Ranges
Kenmore gas oven intermittently not lighting
Okay, my Kenmore gas range works fine about 85 percent of the time, but other times, the oven just won't light. When I turn it on, I will hear some clicking and then it just stops. It only does this rarely and when I had a service tech come out, of course it was working fine and I paid $60 for nothing. Also, when I cook something a long time (10 hourse) at a low temp (200-225), the oven will cut off sometime during the cooking and then won't come back on. Has anyone heard of such a problem? It's very frustrating, because it only seems to happen when I have people over (as in Thanksgiving) and I need to use the oven! The model number is 665.75022100.
  • tconner2 Nov 22, 2008
    This is probably a stupid question, but the part number says 16A and the diagram just has two 16's, no A. I'm assuming it's the ignitor (16) on the right side of the diagram that's L-shaped, and not the straight one, right? Also, since obviously I know nothing about ovens (or gas), is it something really easy to change or should I get a service tech to do it?
    Thanks in advance,
  • 367 Answers
Replace your oven ignitor. It has to draw enough current to open the gas valve. it is only drawing enough current 85 percent of the time so the other 15 percent it wont light the oven (Gas valve wont open) The part number for the ignitor is 8190618 and is 55 bucks at sears.com
Posted on Nov 21, 2008
  • Justin Duby
    Justin Duby Nov 22, 2008
    If not comfortabe doing the task call a technician. The bill still should not be that much and they can make sure to get you the correct part.
I have a kenmore gas range md 79072909012 the oven lower burner has delayed ignition to the point that temperature is loss in oven and heavy gas smell in home....I am a licensed mechanical contractor in...
If its lighting with the panel and baffle removed, but now with them installed, but you get a heavy gas smell its likely the gas mixture is too rich (i.e. the covers are too tight, gas pressure pushes all air away from burner so only gas and very little air occupies the space above the burner and its too rich to light, oxygen starved.) Not an issue when the covers are removed, so it lights fine. Try adjusting the burne for less gas an more air, see what happens.
Aug 25, 2014 | Kenmore Kitchen Ranges
Tappan 32-1272-10/07056-8509-4080 gas range/oven pilot light works,main oven burner won't come on
You will need to look and see if the igniter is glowing a bright red. If it is weak, the oven will not light. Here is the igniter if you need to order it.
Also check and make sure your getting 3.2-3.6 volts AC to the valve.
Dec 01, 2012 | Tappan TGF320 Gas Kitchen Range
My oven on my Kenmore Gas Range sometimes works and sometimes doesn't. One time I can cook fine and the next time it is like it doesn't stay hot.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Nov 22, 2010 | Kenmore Kitchen Ranges
Why does the surface burners and broiler light but not the oven burner on my Kenmore gas range? Kenmore gas range around 14 years old the model number is 362.7352192. We were using the oven and in the...
The oven gas valve coil has failed Need to replace. Go to repairclinic.com and put in the model and order the coil for the valve. It controls the gas valve.
Sep 11, 2009 | Kitchen Ranges
Kenmore Range/oven Burners won't lite
Ours did the same, I unplugged the stove for 1 minute and afterwards the burners worked fine.
May 19, 2009 | Kenmore 75844 / 75849 Gas Kitchen Range
Kenmore Gas Range/Freestanding/ Electronic Ignition
I have an electronic ignition Kenmore Gas Range. The Model Number is 790.78573407.
Am getting the error code F93 in the oven control panel. The manual says the likely cause is "Maximum oven door lock time exceeded". When I plug the oven the "door lock light" flashes and then the "F93" error code flashes. Am not able to use the bake or broil.
Aug 31, 2007 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Kitchen Ranges Logo
294 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
