Question about Samsung SCX-5115 Fax Machines
ADF not working for TWAIN APIs
Hi We are using Twain APIs to build scanning application. But we are facing problem for ADF scanning. When reported that problem to our Twain API vendor he told us that there may be a problem in implementation of Twain drivers for Samsung SCX 5x15 scanner for ADF scanning. Can you please help us in this context? Thanks, Nilesh
  • 106 Answers
You cannot utilize the adf in these 1st generation MFC machines for scanning more than one page at a time. the samsung driver is twain based which is not recognized by windows wia nor will windows detect and list the scanning device. You can scan using the adf but each page scanned is classed as a different session.
Posted on Feb 12, 2013
  • 161 Answers
I need a little more description. Does the ADF handles the first page, or no page at all? Keep in mind that Samsung designs its own scanning application (SmartThru). Also check that the connection (parallel or USB) is correctly configured on your app.
Posted on Sep 21, 2007
The scanner is not available while in use by another application or user i get this darn error. I use this scan multiple times a day and all of a sudden i see this.... why?
The error message could be Twain Driver error or ScandAll pro Application error. Please go through the followings:
SCANDALL-PRO APPLICATION ERROR:
Error Code: [SA01020E] No scanner is found.
There is a possibility that no scanner is connected, the connected scanner is not turned on, or the scanner is currently used by some other application.
Status: [Scan] or [Select Scanner] is specified, but no connected scanner is found. Or, the scanner is currently used by some other application.
Action: Make sure that the scanner is connected and is turned on. If the scanner is currently used by some other application, use the scanner after the application ends. Make sure that the driver selected on the [Scan] tab of [Preferences] in the [Tool] menu is installed correctly.
TWAIN DRIVER ERROR:
-The scanner may be OFF or not connected. Check the power supply of the scanner or connection with PC.
-The scanner may be already in use by other application or the "Scanner and Camera" in [Control Panel].Close other application or "Scanner and Camera" in [Control Panel]
-The connected image scanner is not a model supported by this driver. No image scanner is connected. The cable is disconnected.Check whether the image scanner is connected.
-Another application may already be using the image scanner. Alternatively, the TWAIN driver may have been activated twice.Terminate all applications, and start scanning again.
For more information, please refer to the help contents of Scanner utility/Twain driver and scanning application installed on your PC.Hope the above information is helpful.
Thanks,
ScanCare
Jun 22, 2012 | Office Equipment & Supplies
I could not find the icon for the One Touch Visioneer scanning software for my Xerox Documate 510 so I uninstalled the software and re-installed and now I can't find anything. I am completely unable to...
  • Welcome [ What's in the Box ~ The Xerox DocuMate 510 Scanner ~ What You Need ~ Documentation ]
  • Installation [ Before You Begin ~ Step 1: Assemble the Scanner ~ Step 2: Install the Software ~ Step 3: Connect the Power Supply ~ Step 4: Connect the USB Cable and Turn on the Power ~ Additional Applications Available with Your Scanner ~ View the User Guides ~ Register Your Scanner and Check for Updates ]
  • Scanning [ Loading Documents to Scan ~ Load a Stack of Documents ~ Load a Single Page ~ Scan from the One Touch Button Panel ~ Check the Scan Settings Before Scanning ~ Using the One Touch Panel ~ About the One Touch Button Panel's Names and Icons ~ The Default One Touch Settings for Your Scanner ~ Configuring the One Touch Buttons ~ About the One Touch Properties Window ~ Selecting New Settings for a Button ~ Setting Destination Application Properties ~ Selecting Document and Page Format Options ~ Scanning with Optical Character Recognition (OCR) ~ Renaming a One Touch Button ~ Selecting Options for a Button ~ Creating a New Scan Configuration ~ Editing or Deleting Scan Configurations ~ Configure Before Scan ~ Scan and Burn to a CD ~ Scanning with Event Forwarding ~ Creating an HTML Web Page from Your Scanned Documents ~ Transferring Scanned Documents to Storage ~ Checking the Hardware and Setting the Lamp Power Saving ]
  • Scanning with the TWAIN Interface from PaperPort [ Accessing the TWAIN Interface from PaperPort ~ The Two TWAIN Interface Options ~ Scanning from the TWAIN Basic Interface ~ Scanning from the TWAIN Advanced Interface ~ Adjusting the Image with the Advanced Interface ~ Adjusting the Resolution ~ Adjusting the Brightness and Contrast ~ Adjusting Gamma, Saturation, and Color Hue ~ Adjusting Input Size ~ Creating a New Advanced Interface Profile ~ Display the Device Configuration ~ Setting Up PaperPort to Work with Your Scanner ]
  • Scanning with the WIA Interface [ Fine Tuning Your Scans ]
  • Maintenance [ Clearing Paper Jams ~ Care and Maintenance ~ Cleaning the Scanner Glass ~ Cleaning the Automatic Document Feeder ~ Replacing the ADF Pad Assembly ~ Replacing the Roller Assembly ~ Troubleshooting ~ Error Light Troubleshooting Codes ~ Uninstalling Your Scanner ~ Uninstalling the Scanner and One Touch Software ~ Uninstalling the PaperPort Software ~ To Install Another Driver ~ Xerox DocuMate 510 Scanner Specifications ~ Xerox DocuMate 510 Parts List ]
PLEASE SEE THE COMMENTS ON INSTRUCTIONS TO REINSTALL
Jan 25, 2011 | Xerox DocuMate 510 Document Scanner
Adf does not scan all pages
Try cleaning the rubber rollers in the ADF
S. Mohan
Sep 29, 2009 | Ricoh IS 450DE VRS Flatbed Scanner
Will not dow load to vista it can not find twin
I think you mean TWAIN.
twain is a sub process that is used to make scanning easier between different applications.
Part of what you want to do depends on the application you are using to scan your document eg word, photoshop, etc etc.
Quite often when you install the software for a scanner it will ask if you want to install the twain components. You should click yes.
I would try to re-install the software for the scanner including any updated drivers from cannon support on the web.
Some applications may offer other methods besides twain to get yoyr scan. If you select one of those and try again.
Hope this helps
Aug 11, 2009 | Canon CanoScan N650U Flatbed Scanner
I have installed the UE 404090, but cannot scan to my PC. It says no twain compliant found. If I press scan/file on the machine it says select destination _ what can I do there?
Have you at some point installed a second scanning device on the system..
Reason being TWAIN is configured slightly different by every manufacturer to optomise the working of their hardware.
It some cases when you install a TWAIN device for Scanner A this can interfere with Scanner B
Usually its because your trying to use TWAIN(scanner A) on Scanner B
Make sense?
Make sure (if you have installed another scanner device) that you are using the TWAIN software that came with .
You might need to reinstall the entire set up from beginning.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 06, 2009 | Panasonic PanaFax UF-8000 Laser Fax
My computer is unable to open twain driver
you may need to reinstall the twain driver at this time, or use a different application program inorder to scan
appreciate your kind comment
Apr 12, 2009 | Canon BJC S600 InkJet Printer
TWAIN Driver Error
If connected via USB, unplug cable and insert into another available port and error message should disappear.
Nov 14, 2008 | Fujitsu fi-5120C
Twain driver for scansnap s300
The scanner can not be used with Twain.
3 TWAIN or ISIS® applications cannot be used directly.http://www.fujitsu.com/us/services/computing/peripherals/scanners/scansnap/s300.html
Apr 12, 2008 | Office Equipment & Supplies
Inconsistent tif file creation with Panasonic KV-s7065c
pleaz oil the scanning lamp drive unit and clean the lamp
Sep 20, 2007 | Panasonic KV-S7065C Flatbed Scanner
Samsung SCX-5115 Fax Machines Logo
366 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
