Question about Linksys WRT160N Wireless Router
Problem using XBOX 360 Live and Linksys WRT160N
We just upgraded from the 150N to 160N because it has MIMO technology and supposedly a broader bandwidth. The reason we got it is because the XBOX would lose connection to the old router. Now with the new router, we can't even get the XBox Live to work! What do we need to do to fix this problem?
  • Jackie Rucker Nov 23, 2008
    Thanks for your help! When my stepson comes this week we will try that. In the meantime, I hooked up the old router because all of a sudden out of the blue, my laptop in the living room couldn't get online. I worked and worked on it all Friday night and finally gave up and hooked up the WRT150N and it has worked perfectly ever since! It had no problems linking with the 160N when I installed it, but then something happened. I am wondering if I can perhaps use the WRT160N upstairs and hook the XBox directly to it?
  • Anonymous Dec 02, 2008
    went from a b router to wrt160n cable hookup ok but no wireless
    Genius:
  • 1,269 Answers
You need to reconfigure the wireless settings of your xbox. First, verify if you xbox can connect online by using ethernet cable. If it works that way, the only thing that you need to reconfigure is the wireless settings of the xbox. Make sure you have the same SSID and encryption key with the new router.
Posted on Nov 23, 2008
I have hughesnet and a belkin f5d8235-4 v2000 (N+) router and i run a connection test on my ps3 i get 1st 2 success and psn failed because of time out...Also when i play multiplayer games like assassins...
That is the reason you are having problems. NAT refers to how much bandwidth you have. Try making sure that you play whaen no computers are connected. My PS3 is like this as well, and I don't want to upgrade my internet so I just deal with it
Thank you for your time, good luck and I hope this helps
Jun 08, 2011 | Video Game Consoles & Games
Tip
What wireless network card to I need to use on my WLAN ?
In 1997 the Institute of Electrical and Electronics Engineers (IEEE) created the first WLAN standard.
They called it 802.11 after the name of the group formed to oversee its development. this first version only supported a maximum network bandwidth of 2 Mbps today it has been improved to over 300Mbps using MIMO devices based on this first version, a comparable wired LAN on CAT5e Ethernet twisted pair cables usually is classes at a minimum of 10Mbps to a maximum speed of 100Mbps (often called 100/10Mbps)
Here is a summary of all the Wi-Fi versions and letter numbers upto the present day in 2010.
In 1999, the 802.11b specification was released for the the domestic market, supporting bandwidth up to 11 Mbps at the same time the 802.11a was released for the business market upporting bandwidth up to 54 Mbps it was much more expensive and signals had more difficulty penetrating walls and other obstructions so it was dropped.
In 2003, WLAN products supporting a newer standard called 802.11g it combines the best of both 802.11a and 802.11b it supports the same bandwidth as 802.11a of 54 Mbps (hence it is often called 54g this is the Wi-Fi standard), it uses the 2.4 Ghz frequency for greater range the 802.11g technology is backwards compatible with 802.11b, all WLAN cards will call this 802.11b/g
Some versions offer 128g which is 54g twice but only if the router will supports this doubled speed, the majority of all routers use a V.90 modem which will only support 54Mbps (aka 54g).
The newest IEEE standard in the Wi-Fi category is 802.11n (called MIMO technology) . It was designed to improve on 802.11g in the amount of bandwidth supported by utilizing multiple wireless signals and using antennas instead of one, it support data rates of over 100 Mbps upto 300Mbps and also offers somewhat better range over earlier Wi-Fi standards due to its increased signal intensity. All 802.11n equipment will be backward compatible with 802.11g/b networks.
Most internal WLAN cards are plug and play on the PCI bus, however more and more version are being provided as either a USB or PCMCIA version for laptops and desktops, this version below will work with all versions 11b, 54g and 11n upto 300Mbps ( if the router that you have will suport it.
The latest technology is called Wi-MAX is designed for long-range networking spanning miles or kilometers as opposed to local area wireless networking or WLAN. The other end of the Wireless technology spectrum, that split from 802.11b is called BlueTooth and works up to a maximum distance of 10 Meters used exclusively as the standard in Mobile Phone devices like headphones and short distance inter-connection to other phones and PC's.
on Jul 21, 2010 | Computers & Internet
Hello, I have a Linksys Router model No. WRT 160N and have problems with the wireless signal. Doesn't appear the wireless symbol ON and I have connected already the modem cable. The modem is OK cuz I can...
* NOTE: If you tried to set-up the WRT-160N Router previously, but failed, with the Router ON, press the "Reset" button on the back panel and hold it down for 10 seconds, then release. This will reset the Router to factory settings and erase all previous data.
Then do this
1. Hook up the Linksys WRT-160N Router to the modem(cable, DSL or satelitte)
2. Hook up the Linksys WRT-160N Router to your computer via a LAN cable with the LAN cable in Port #1 on the Linksys WRT-160N Router.
3. Type http://192.168.1.1 in the address bar of your web browser.
4. Log-on to the Linksys WRT-160N Router with these log-on credentials:
Username: linksys (lower-case)
Password: admin (lower-case)
5. Click on the "Clone PC MAC Address" tab.
6. Click the "Clone PC MAC Address" button.
7. Click "Save", click "Continue".
8. Click the "Wireless Security" tab.
9. Choose "WPA2 Personal - TKIP/AES" for encrypted security.
10. Enter encryption password (passphrase).
11. Click "Save", click "Continue".
12. Exit the web browser.
13. Disconnect the LAN cable from the computer and Port #1 on the Linksys WRT-160N Router.
In about 5 seconds, your wireless connection should be up and running.
Sep 15, 2010 | Linksys WRT160N Wireless Router
Everytime I turn on my xbox it automatically connects to live. But when I put in the game Call of Duty Modern warfare 2, it disconnects me about 70% of the time, which is very annoying. No other game does...
Probably the game eats a lot of your internet bandwidth, I recommend that you upgrade your internet connection to a higher level so you could obtain maximum performance.
Jun 15, 2010 | Microsoft Xbox 360 Console
Restricted nat for xbox / linksys 160n router need to open
You are trying to open the NAT on the router for X-box.
For this you will need to reduce the MTU settings on the router to 1365.
You will also need to trigger some ports on the router.
For this you will need to open the router set up page.
Router set up page is the page where you can change the settings of the router
Click Here
to know more about router and network
Apr 20, 2010 | Linksys WRT160N Wireless Router
I have a Linksys WRT160N, and xbox live wont even connect?
If your only using this router for Xbox Live id Ditch is I had this same router had nothing but Problems heres a link with a list of compatible routers. http://support.xbox.com/support/en/us/xbox360/xboxlive/getconnected/compatiblenetworkequipment/compatiblenetworkingequipment.aspx
Sep 20, 2009 | Linksys WRT160N Wireless Router
My wireless adaptor on my xbox360 won't connect to the router
suggestion try using mixed mode wireless b/g this will allow the wireless g router to see the wireless n adapter, it will not have high speed mimo technology enabled but it will fucntion as a wireless g adpater, good luck with it. having a wilress n router is required to pair their the wilress n adapter, otehrwise no speed benafit or mimo technology, i hope this helps you a bit. their was very little to work with, but i think we have it.
Aug 22, 2009 | Microsoft Wireless Network Adapter Xbox...
Linksys WRT160N Wireless Router  Logo
2,292 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
