USB transfer error changing the format of the whole memory stick.
Hi I tried to transfer some photos via Windows Explorer from a Sony memory stick duo pro (photos taken from digital camera) to my laptop, but the usb cable slipped halfway through and disconnected from the memory stick card reader. When reconnected, there were hundreds of folders which all said ''folder is empty''and I cannot find my photos anywhere!! Usually it should only have 2 folders - DCIM and MISC and the photos would all sit under DCIM. Those were really memorable photos and I hope you can help me recover them. Please help!
  • 143 Answers
Posted on May 09, 2017
  • 36 Answers
SOURCE: PROBLEM: k750i Memory Stick Duo Pro - Sony
first format the memory card and upgrad the firmwer of your mobile then check for the same problem, happen again change
thet memory card.
Posted on Apr 22, 2008
  • 271 Answers
SOURCE: Can't access pictures taken
If you can't access the memory card even with a card reader...your camera is working fine...the problem is ith your memory card (internal problem)...if your warranty is not finished sony will replace that to a new one
PLEASE RATE ME ( FIXYA )................................
Posted on May 26, 2008
Posted on Aug 01, 2008
SOURCE: Connected cam (with Sony mem stick pro)to PC>Corresponding drive is empty -No DCIM folder
I have the same problem with the DSC-W170 Cybershot
Posted on Aug 08, 2008
SOURCE: camera memory card - deleted dcim folder with antivirus
Try this..maybe work for you..cause it's work for me
in your explore click tools- folder options-view
check "show hidden files and folders" box and
"hide protected operating system files" box.
press ok. Your folder and picture will appears..
Cause in my case the virus change the folder into protected operating system files..
I hope will work for you too..good luck
Posted on Sep 10, 2008
How to format memory stick
If you want to format your Memory Stick Duo memory card while it is inserted in the Sony Ericsson phone, you may get an "Memory or Application In Use" error.
The correct way to format the memory card is to first change the USB port mode on the phone to File Transfer mode while it is disconnected from the Windows PC. Then connect the phone to Windows PC. It will be visible as a Disk Drive in Windows Explorer. Right Click and format it.
Nov 27, 2010 | Sony Ericsson K530i Cellular Phone
Sony memory stick PRO duo 4gb card says memory full when empty
I would suggest formating the memory card through the options on your camera. If you reformat the memory card and you still get the same error then you have a bad card. Just like anything else the cards will break down internally over time.
Mar 07, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
I deleted Photos from my 2G Memory Stick Duo on my computer, now the camera says there are no images but has only 100mb memory space available
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
2. Format Memory Stick Duo
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Jan 25, 2010 | Sony 2GB Memory Stick PRO Duo Memory Card
When I install my Memory Stick Pro Duo 8GB in my camera it will format and take and store photos fine 1460 total. I then try to put the Memory stick in my card reader which says it supports this format it...
You need a new memory card reader. The reader isn't supporting the higher capacity of the new Memory stick. For a workaround, hook the camera directly into the computer via USB cable - then the camera itself becomes the reader and can transfer all of the pictures. Look for a reader that specifically does Memory Stick PRO Duo sticks, the PRO means the higher capacity.
Dec 01, 2009 | Computers & Internet
Error 8022008B.....
If it is having trouble formatting in a PSP try taking it out and formatting it on your PC in Windows. Hope this solves your problem!
Please rate!
Oct 04, 2009 | Sony 4GB Memory Stick PRO Duo Memory Card
After slideshow memory stick is missing photos (not on computer)
If you put the memory stick back into the camera can you see them thru the camera menu? If so your computer's SD card port may be having issues. try using the card in another computer or use the cameras USB cable to transfer the pictures from the camera to the computer if it has one. Do other memory sticks work in the computer ok? If you cannot see them in the camera either then the pictures will be corrupted and probably cannot be recovered. Then the card will need to be formatted to erase any errors on the card. Always use the camera to format a card whenever possible...Hope that helps.
Sep 19, 2009 | Sony Memory Stick PRO Duo (2GB) for PSP
Memory stick
Format the Memory Stick via PSP.
Go to System Settings->Format Memory Stick
This process creates all folders that are supposed to be on your Memory Stick.
Feb 18, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
thet memory card.
Apr 17, 2008 | Sony Ericsson K750i Cellular Phone
Sony ericsson Memory stick problem
there may b variable reasons for this kind of the prob , u c that a computer would support all formats that a cell phone would not do , either the files that u have transfered are kindly check all these properties and transfer these photographs again...
Oct 21, 2007 | Sony Ericsson Walkman W810i Cellular Phone
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
