Question about Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Dishwasher Problem
The hot water takes about 1 minute to get to the faucet. Even when I run the hot water first to get it up to temp. the dishwasher hot water pipe does not get hot and the water is cool.
Our dishwasher has tube coming up the back wall onside that carries water to the top rack, The dishes are getting cleaned or rinsed on the top, could this tube be plugged, how do I unplug. The dishwasher is a kenmore about 3 yeas old.
Posted on Mar 07, 2008
  • needyperson Mar 07, 2008
    sorry I can't spell either, it is Not getting the dishes cleaned or rinsed on top. The tube is inside in the middle of the back wall. Thanks.needyperson
    Novelist:
  • 148 Answers
The dishwasher will probably heat the water the rest of the way for you. depending on the specs and features.
hot water is not likely an issue with the dishwasher itself.
you could have cold water plumbed to the unit by mistake.
also, it could be that it is not fully pumping out, and the water going in is mixing with water in the sump.
try running it for few minutes and then pump it out. start a new cycle and see if you are getting hot water. if not, then at try to confirm that the unit is heating the water on its own. run it for about half a cycle and check the water temp again.
you do need hot water to clean in most units.
for certain this is a plumbing problem that is delivering cold water. and if its not heating, make sure that it should be per manufacturers specs, and call for repairs if its not heating the water.
good luck
mark
Posted on Dec 28, 2007
Heater takes more than 1 minute to get water to kit faucet , then temp fluctuates
1) Guesses: Sounds like a bad single-handled faucet cartridge, or low water flow at faucet, or clogged water filter.
Replace faucet cartridge, clean the aerator, and/or clean sediment out of pipes below sink, and clean water filter at tankless unit each month.
2) For exact measure of problem:
Typical faucet can have 2 gallon per minute flow rate.
2 gpm flow rate means faucet fills 1 gallon container in 30 seconds. Test faucet using 1 gallon container and a cooking timer to get flow rate.
Clean aerator to improve flow rate. Compare kitchen flow rate with other faucets in home.
http://waterheatertimer.org/Low-hot-water-pressure.html
Most homes have 1/2" diameter pipe running to kitchen faucet.
100 feet of 1/2" diameter pipe holds 1.2 gallons of water. This assumes no sediment build-up inside pipes.
http://waterheatertimer.org/Water-heater-recirculation-system.html
Assuming only hot is turned on: If faucet is 100 feet away from water heater, and pipe diameter is unobstructed 1/2" diameter, and faucet has 2 gallon per minute water flow, then hot water should arrive in 36 seconds.
50 feet away, and hot water should arrive in 18 seconds.
If kitchen has single handled faucet, and the handle is raised in the middle, then equal amounts of hot and cold water are drawn at same time. This doubles amount of time for hot water to arrive.
If single handle faucet has a bad cartridge, then faucet can have crossover.
Crossover means that cold water can enter the faucet even if faucet is turned to hot.
Bad single-handled faucet cartridge can delay or stop the arrival of hot water.
http://waterheatertimer.org/Crossover.html
Tankless require maintenance including cleaning combustion parts yearly, de-lime heat exchanger frequently, and clean water filter each month.
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
http://waterheatertimer.org/pdf/Bosch_Overcoming_fluctuating_temps.pdf
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Add a comment for more help.
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 15, 2011 | Rheem Direct Vent Natural Gas Tankless...
Tip
Clean light flashing on dishwasher
if you have a whirlpool/ kenmore dishwasher and the clean light is flashing 7 times then pauses and then repeats, it is a problem with the heating circuit.
follow this keypad operation: push the high temp wash, air dry, high temp wash, air dry. this will put the unit into a service mode and it will run a short diagnosis cycle. after it gets done, about 5-7 minutes, then it will reset and allow you to use the unit again.
make sure the water is hot enough at your faucet at least 120 degrees, and the door is getting closed tight.
on Jan 18, 2010 | Dishwashers
No hot water on Moen single handle shower faucet. cold ok and shut off is fine
do you have hot water elsewhere? if not, might be that your water heater is not heating.
if you do have hot water elsewhere, did you let the faucet run for a minute or 2.
did you have hot water before? is this a new house? new valve?
need a little more detail.
on posi temp valves, if there were no water coming out of the hot side of the valve, the valve will not operate.
Aug 12, 2010 | Moen 1 Handle Lever Shower Faucet With...
My whirlpool dishwasher is not releasing the tablet and not doing a cycle wash. Some cold water is going in then it bleeps it is finished.
your machine should only get hot water going into your machine .that is the problem right there,chek faucet temp then start machine must be hot going in.the tablet even if was dropped will not dissolve in cold water. let me know if i was helpful to you
Feb 24, 2010 | Dishwashers
Dishwasher issues
You should always turn the hot water faucet at the kitchen sink first before starting dishwasher. If you don't your entire wash is cold water. This will also cause the water temp mode to take forever to heat the water to the 140 that is factory set. Hope this helps.
Feb 02, 2010 | Dishwashers
Clean light stays on and will not run on our Kenmore 665 dishwasher.
Jan 18, 2010 | Kenmore Dishwashers
My dishes are not cleaning no matter what cycle i try
If water is spraying as it should, and you are using adequate detergent, then most suspect is your water temp is too low.
Run your kitchen faucet till hot before running the dishwasher if this is the case.
Also use of a sheeting agent like JetDry may help.
Nov 24, 2009 | Whirlpool Dishwashers
Runs too long
the water going into the unit needs to be 120 degrees for it to work correctly. the D/W is trying to heat the water up to 120 degrees. it will heat a degree a minute. depending on what the temp is in the washer. try turning on the hot water first before you turn the dishwasher on. verify that the water is 120 degrees coming out from the faucet.
Oct 19, 2009 | Whirlpool GU1100XTLB / GU1100XTLQ /...
Dishwasher runs for a long time
If your dishwasher's cycle times are too long, check these:
Water pre-heating
Cycle not completing
Water pre-heating Yourdishwasher may pre-heat the water. If so, and if the water entering thedishwasher is cool, the heater may take up to half an hour to heat thewater.
To avoid the wait, increase the incoming watertemperature before turning on the dishwasher. Do that by running thekitchen sink faucet until the water runs hot. Or increase thetemperature of the hot water to the entire house at the hot waterheater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Nov 12, 2008 | Kenmore 24 in. 17362 / 17364 / 17369...
Dishwasher
Wash water isn't hot even after we run hot water in sink before turning on dish water. However rinse water is hot. It appears the heating element is not working on wash but is on rinse?
Dec 19, 2006 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
428 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
