Question about Archos Computers & Internet
Archos 605 can I have a simple phone directory
  • tvservices Nov 21, 2008
    YOUR ANSWER MEANS NOTHING TO ME SORRY. DO YOU MEAN ADD SOFTWARE AND IF SO WHAT SOFTWARE
    sorry for confusion, this is a present for my wife and I would like to store her phone book on the 605 in some form that is easily looked up.She never has her mobile with her but always her mp3.
  • 728 Answers
Connect the device that you want to get the phone number off of and connect the PDA that you want to put the numbers on to a computer. Open my computer and find both devices in the list and click on the one that you are getting the numbers from and find them on the device and highlight all of them. Then right click and click on copy. Then go to the PDA and paste the numbers there. It should work then.
Posted on Nov 21, 2008
  • 19,396 Answers
Yes you can import the phone book into the Archos by exporting the original file into a computer, and then importing on archos.
How to do this depends on two factors:
Export
1 Where do you import from: If the phone book is in outlook, on another PDA or on a computer, you do export contacts from file menu, and export them to a file into a computer.
Import
2 What operative system is installed on Archos:
Archos 605 mounts both Linux and Windows, on Windows you do an import operation from outlook and import contacts.
If you want to import from a non compatible system, like a nokia phone, there ca be troubles in importing the contact files.
If instead you want to import all contacts from an older archos, you just use the archos software to download the old contacts in a file and upload them to the new archos.
    Master:
  • 505 Answers
Go to the link http://www.softpicks.net/download.php?index=13937 and download the Easy Telephone Directory.
You can also go to www.download.com and in the search window type Easy Telephone Directory and download the first software.
Thanks
  • 4,472 Answers
Can you please explain in further detail what it is exactly you are looking for. You can find a great phone directory at http://www.yellowpages.com
Once i have more information I can assist you further. Please take a moment to accept and rate my solution accordingly.
Thank you,
Lee
  • 734 Answers
Yes use a softeare for it
  • 2 more comments
  • futureloginn
    futureloginn Nov 21, 2008
    ok, download from the link and try--
    http://www.softpicks.net/download.php?in...
    thanks
  • futureloginn
    that software is used to store phone number in your Archos PDA
  • futureloginn
    yes, it is a easiest software for using PDA as a phone directory
    THANKS
  • futureloginn
    ok i'll give you sum more software, use them and see which one is more easy for you-
    http://www.mailnavigator.com/magicdial/M...
How to fix archos 605 code 102
I was think maybe there is something was wrong with the Firmware so i decided to download the new firmware that was available at Archos.com. at the white screen wen you see the white screen keep hitting no rapidly until it starts up to your regular screen. If you must try the recovery. Anything to get to the main screen. Then try putting the updated fimware into the root directory after you connect via USB. Then try rest settings.
I hope this helps
Sep 09, 2009 | Archos 605 WiFi Digital Media Player
Archos code 104
Make sure you have the correct model # for your Archos, or these suggestiosn from other experts will not work for you:
hotlyq:
Rank: Apprentice
Rating: 96%, 10 votes
Try the steps below:
1. Select 2nd option "Repair" or 3rd "Format the disk"
2. Connect 605 to PC using USB wire and find the Driver named "a605" or similar words
3. Copy a firmware to the ROOT directory on the driver mentioned above
4. Keep the USB connected and select "OK" on 605
5. Re-calibrate the screen under Display menu on 605.
Hope Everything is ok.
posted on Aug 27, 2008
alcalc:
Rank: Apprentice
Rating: 95%, 3 votes
Just a little FYI: hotlyq's solution works just fine, but the firmware file needs to be name exactly as it is downloaded. I downloaded both OSv2.1.0.4 and OSv2.0.1.0 firmwares to the same folder on my PC. Obviously enough I had to give them different names on the disk, I tried both and neither worked. It turns out the recovery system will not use any firmware unless it is named "firmware_a605f.aos". So if you're like me, copy the firmware over to the root of the USB-drive and then rename to firmware_a605f.aos.
Jan 07, 2009 | Archos 605 WiFi Digital Media Player
I cant access my files when I plug my Archos 605 into a computer!
i had the same problem what i did was i downgraded my 605 to
Archos 605 Wifi (20GB-160GB) OS v 2.0.10
then i upgraded to Archos 605 Wifi (20GB-160GB) OS v 2.1.04
heres the link for 2.0.10 http://update.archos.com/5/a605/a605_r2.0.10/firmware_a605.aos
and heres the link for 2.1.04 http://update.archos.com/5/a605/a605_r2.1.04/firmware_a605.aos
Jan 01, 2009 | Archos 605 WiFi Digital Media Player
Archos 605 Dock station won't work with TV anymore
hi have you change the setting to component or rgb on the display settings
Dec 16, 2008 | Archos 605 WiFi Digital Media Player
Archos 605 Pops/Hisses when connected to Wifi
Contact Archos support and they can provide you the file to repair your disk. Once you have the file stored on your computer, you will then hook up your Archos via USB and copy the file they provide you to the root of the Archos.
The direction I got when trying to fix my pop/hissing
"If you power on the unit by pressing and holding the TV/LCD button and power button simultaneously the unit will boot into a recovery screen. Once in this screen choose "Repair Disk" and follow the on screen instructions.
When prompted, please place the following file into the 'root directory' of
the unit:
Hope this helps.
Aug 09, 2008 | Archos 605 WiFi Digital Media Player
Recovery code 104
Same issue on my Archos 605 wifi 4GB
The Repair didn't work so here's what I did.
1) connected via USB and got all my Picture, Videos and Music to a safe place.
2) Downloaded firmware update.
fouund it here - http://www.downloadplex.com/Drivers/Firmware/Archos/Download-Archos-605-Wifi-4GB-Firmware-2.1.04_109044.html
3. Copied update to root of archos drive and rebooted
4. Archoes installed the update and rebooted and came up to desktop again
5. reinstalled plugins (thank god I saved them) copied plug-in to root.
6. Back on the road again
Feb 23, 2008 | Archos 605 WiFi Digital Media Player
Archos 605 copying films from DVD to the player
If change the setting of the 605 to "hard disk" then a PC sees the 605 as a hard disc when connected using the usb lead. You can then copy and paste files directly to the 605..
Feb 19, 2008 | Archos 605 WiFi Digital Media Player
ARCHOS 605
my touch screen for my archos 605 wifi is not functioning right. How do i resolve this problem?
Feb 13, 2008 | Archos 605 WiFi Digital Media Player
How do I download games on the Archos 605
There are a lot of games you can download for Archs, but most games aren't created for it, so they won't work. Touch works and the game must be in the flash folder (you don't need to install it).
In he widgets -> flash it says empty also on my archos, but go to Files -> then the Flash map.
There you can find all the files, just select and run, Suc6!
Jan 13, 2008 | Archos 605 WiFi Digital Media Player
Computers & Internet Logo
Top Archos Computers & Internet Experts
fordexpert
Computer Links
Are you an Archos Computer and Internet Expert? Answer questions, earn points and help others
