Question about Epson Office Equipment & Supplies
Epson DX3850 will suddenly not print
Hi there
my epson printer, although it has been working OK previously, suddenly does not print. I had to change all print cartridges, this was done easily as normal. Now the PC displays "printer not ready to print" but there are no error lights on the printer. Just the Green On line, and the Green light under A4 indicator.
I have unfortunately lost the instruction leaflet so do not know how to solve this.
Would you kindly help?
Thanks
Sharon
jackboy
  • 2985 Answers
SOURCE: epson c62 printer
I assume your new computer is Vista ?
You need the appropriate Vista driver
Epson or do a Google
Posted on Jan 15, 2008
SOURCE: download software
i need help i loss my disc to dowload my printer
Posted on Feb 25, 2008
SOURCE: Copies and prints but won't scan
if your scanner is on a wireless network, you will need to make sure the scanner address in epson scan settings matches the address your router has assinged to it. The DHCP address. Log on to your router by typing 192.168.2.1 or some variation thereof into your window internet explorer address bar. or find out how to log on to your router via the manufacturer of the router. When you do that find the DHCP client list and see what address your router has assigned to your scanner. Once you have this address open epson scan settings and delete the current information there, then add a new scanner by manually entering the address you got from the router.
I have to do this all the time!!!
email me at raygant@msn.com if you want more help
Posted on Mar 10, 2008
  • 357 Answers
SOURCE: Epson printer: print head not moving to replacement position
Unplug the printer when the head reaches the point where you can take out the cartridge.
After you have replaced the cartridge, plug the printer back in.
Good Luck.
Posted on Feb 16, 2009
SOURCE: dx3850 epsonprinter problem jam
It was not easy, but we found a solution.
There are two key points: how to remove the panel with all the LED and buttons, and how to dismount the scanner.
The first is easy: back to the panel there is a small ****. Raise it up, and push the panel to the back of the printer. The panel will slide backwards, and can be easily removed. Carefully disconnect the flat cable and remove it.
The second point is *much* more tricky. The chassis part near the USB plug is only cosmetic, and can be easily removed once the button panel was removed. There is a clip that may be operated in the most back part of the button panel. After opening the clip raisin it a little bit, the small part may be easily removed (forcing a little bit).
Under it there is a screw fixing the left side of the scanner. To remove it you must disconnect all the cables going to the scanner.
The screw on the right side is easily accessible from the scanner top.
The rest is easy
R. Rossi
Posted on Mar 01, 2009
Epson DX3850 disappeared
U need to remove all vestiges of old driver before introducing new one. You might want to contact Epson for help in identifying the items needed to be removed completely.
Aug 22, 2017 | Office Equipment & Supplies
Epson stylus dx3850 ink saying empy when full and wont print
Hi
Try turning the printer off and disconnecting it from power completely.
Check for paper jams on the machine.
Clear any print queues.
Mar 02, 2012 | Epson Office Equipment & Supplies
WHAT CAN I DO TO HAVE BACK MY PRINTER PROGRAMMED TO MY COMPUTER
You can download the Epson printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload :-http://www.epson.com/cgi-bin/Store/jsp/index.do?BV_UseBVCookie=yes
Feb 21, 2011 | Epson Stylus Color 400 InkJet Printer
Click on Epson, then Monitor status then Properties then replacement. A page will come up saying To get carriage into position click O.K. on this page. When you do that the carriage moves into position and you can take out the old cartridges and replace them
Jan 17, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Have used compatible ink before on my dx3850 epson. have some more cartridges and it wont print anything
the head in which the cartridges r inserted is now blocked due to ink dried up in the holes from where the ink comes out.a common epson printer problem.now the whole head needs to be replaced.they r avaiable in the maket just get 1 from your neares epson servi center.or nearest epson printer dealer.
Nov 29, 2008 | Office Equipment & Supplies
Stylus Photo R320 "printer driver dealing with CD printing...
I had the same problem and was able to get my EPSON Stylus Photo R220 to print a CD using the following procedure. This should work for other Epson Photo printers as well.
1.     Open EPSON Print CD
2.     When CD is ready for printing do the following:
3.     Select Print from the File menu
4.     When “The EPSON printer driver dealing with CD printing is not installed” is displayed – click OK and select Manual Print
5.     Set Paper Size to A4 and click OK
6.     In Layout select Print Settings
7.     In Media Type select CD/DVD
8.     Then press Print
Th
May 24, 2008 | Epson Stylus Photo R320 InkJet Printer
Download software
Hi
Please visit following web site and click on the given link below.
http://driverscollection.com/?file_id=26204
You may download the drivers after filling the security code mentioned on the box. I am sure this will help you in installing your epson Printer.
Abhishek
Nov 09, 2007 | Lexmark X1270 All-In-One InkJet Printer
182 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
