Dropped my Maxtor 80GB USB HDD, ouch. Salvage my data?
Dropped my Maxtor 80GB USB HDD, ouch. Seems to start (lights up ...but 2 buzzes) but the PC (OS is Vista) doesn't see it. I am in Perth, Western Australia. Advice please! - I am feeling I must say goodbye to the unit ...but who do I turn to for data recovery?
  • 981 Answers
Check out Maxtor for analysis tools and referrals of course. There are books out there on exactly what to do, but of course there are also firms who will offer to recover data you didn't back up for a price (ca. $400, say; it's not wild competition there, somehow.)
Posted on Nov 22, 2008
Product do not power on. you hear it trying but the light do not come on and the sound start and stop. How can I get my files off the hard drive
Your drive definitely needs to be sent into the manufacturer for repair. Unfortunately the only way to salvage your data is to send it into a data recovery specialist. They generally charge $500-1500 to repair the drive and salvage your data based off how much data you have and what is wrong with the drive.
Mar 01, 2011 | Maxtor OneTouch 4 500GB External USB 2.0...
Want to replace 80Gb HDD with a bigger one. How? Do I have to copy everything from the original one to the new one before actually replacing it? how?
Before you change the 80 GB Hard Drive you can take the backup of your hard drive to the External Hard Drive or if you have any sata case so you put your new hard Drive in the sata case and make 2-3 partitions in the new drive and copy your data in the new hard drive except in first partition which will be primary C Drive for your laptop and will replace data when you install windows in it. after the windows is installed and your data is verified in your new hard drive you can clear your old hard Drive or use it as an External Hard Drive (as you like )
2nd thing which is more safer and reliable is that you make backup CD/DVDs for your data before proceed to formatting or even changing hard drives, it will be very useful and helpful for any unforeseen data loss
if you require more assistance regarding this feel free to reply to this post
Regards, BA
Jan 14, 2011 | Acer Aspire 9300 Notebook
Maxtor 3200 is not getting reconized by windows 7 ... i need a new driver
Install it another computer which is running well.If your Hdd run well in that computer ,change the USB cable .If the HDD can not run in another pc you think, you have lost data.Because that Hdd cant run any more.
If the problem is same.
follow the step
R_click on my computer>Properties>Hardware>Device manager>uninstall all the usb hub ,one after one .
After UN install all the usb, restart your PC .
If the problem , is same as before ,
Insert your OS in the cd tray > press Win key + R>type sfc /scannow (please take a space between sfc and front slash)>hit enter .Again you will restart the PC.
If the problem is same please change the Hard disk.
Hope it will help you
Jan 10, 2011 | Maxtor Personal Storage 3200 (U01E200) 200...
I have a maxtor one touch mini and does not pop up on my screen, what can I do ? i need all file inside
follow the step
R_click on my computer>Properties>Hardware>Device manager>uninstall all the usb ,one after one .
After UN install all the usb restart your PC .
If the problem same as before ,
Insert your OS in the cd tray > press Win key + R>type sfc /scannow(please take a space between sfc and front slash)>hit enter .Again you will restart the PC.
Hope it will help you.
Dec 27, 2010 | Maxtor OneTouch 4 Mini 160GB External USB...
How do i set the jumper when installing diamond max plus 9 80gb as a 2nd disk what does cs enabled mean thank you
CS means Cable Select .Parallel data cable have two conectors.If you set jumper set on CS ,in this way ,example,you have two HDD when you plug parallel data cable in middle connector ,1 Hard drive working like Master ,2 HDD work like slave,if you plug in last connector First HDD working like slave,second HDD Master.
http://www.tacktech.com/display.cfm?ttid=379
Aug 04, 2010 | Maxtor Hard Drive
Hard drive does not operate
1, switch off computer
2. remove side (usually two screws on the back held it)
3. remove and then re-insert power cable from hdd
4. remove and re-insert data cable, from hdd as well as from m/b
5. start computer and hold your fingers on the top of the affected hdd, if you feel vibrations, this meant that driver is spinning and therefore rescue can be attempted at home.
6. research and purchase hdd recovery software, follow it's instruction and save data on another medium, be it another hdd or cd's dvd's.
if there is no spin, recovery is still possible but in specialist lab and will cost more money....
always back-up your data, second hdd is much cheaper than data recovery from existing one...
Jul 27, 2010 | Maxtor Hard Drive
HDD Maxtor 80Gb IDE: Harddisk error! At boot it say's Primary harddisk error. Press F1 to continue. *When I press F1 nothing happens. *When I go to the bios at IDE Configuration and hit refresh at Primary...
OK the only shot you got is to geta USB to SATA/IDE converter dongle, connect to another PC's USB port. Hopefully, you will be able to read it. Otherwise still plugged in you may be able to use recovery software and get you DATA back. Recover my files is one,
http://www.recovermyfiles.com/
Other freeware data recovery software GL.
http://www.freebyte.com/filediskutils/
Feb 15, 2010 | Maxtor Hard Drive
I have a Maxtor one touch 2 external hard drive,serial#2dd10020,worked fine on Windows XP,I'am now using it on Windows 7,it shows up in computer as drive Z,I cannot unlock it to get to my files,any help...
ok for one your computer no matter what OS you are using stores no drive letter , a drive letter is only given in the order as it is
installed on your system for example if you use 2 internal HDD
and one external HDD your computers C: drive will be the master
the F: will be the slave and the external will be G: , now if you have changed the order of the drives from your last OS then it
will conflict to the last drive letter given , your unit will know
what letter it was given so it must be in the same location for
the new OS , there is also the possibility that Windows 7 doesn't
support the driver for that unit , you can try hooking it up to
another computer retrieving your data , then hooking it back
up to windows 7 run its software , then installing the data back
into your HDD
Jan 29, 2010 | Maxtor OneTouch II external hard drive...
DROPPED and BEEPING
Remove and reattach the HDD from Casing once and check it. If this wont work HDD may damaged. Consult MAXTOR customer service.
Mar 25, 2009 | Maxtor OneTouch III Mini Edition 120GB...
Dropped my Maxtor 80GB HDD Portable. Recovery advice?
that may be depends upon the damage of your HDD if it dam more then you need a service center for data recovery because it’s a hardware issue (cost varies approx.-50 USD) Thanks
Nov 21, 2008 | Computers & Internet
Computers & Internet Logo
66 people viewed this question
Alun Cox
David Payne
David Payne
