How to conf cisco 871 w router - Computers & Internet
  • 120 Answers
Reset password Catalyst 4006 Ethernet Switch
Depending on the Supervisor Module model, most likely it's a standard Cisco's "password recovery procedure":
Connect to the console
Reboot the switch (power cycle)
Start pressing Ctrl-C till you get to the BOOTROM
Change boot configuration register to 0x2142 (confreg 0x2142)
Boot the switch. It will ignore confuguration and boot "empty".
Go to "enable mode".
Copy startup configuration to running configuration ("copy start run")
Change boot register back to 0x2102 (conf t -> conf 0x2102)
Write config (write mem)
Reboot
Good luck,
Mike / CCNP, CCDP, CCSP, CCVP
Headset Adapters for office phone system
May 03, 2016 | Cisco Catalyst 4006 Chassis ( 4006)
Configure
I'd start by resetting the switch to defaults with the command
  • erase startup-config
  • The restart the switch with reload
  • Once rebooted enter conf conf t
  • Then simply configure all the ports at once
  • int ra fa0/1 - 24 if they are gig ports then it would be int ra gi0/1 - 24
  • Then type no shut
  • That should be all you need.
May 22, 2013 | Cisco ME 3400-24TS - switch - 24 ports
I NEED TO GET A USB WIRELESS ADAPTER FOR MY COMPUTER, THE MODEM IS A CISCO,ANY SUGGESTIONS WHICH ADAPTER TO GET?
I would try to stay with the cisco/lynksys brand if money is available for it.
Just be sure of what speed of router that you have prior to purchasing anything. It is a waste of money to purchase a better card than you have router. Examples are G, N150, N300.
If you have a N300 router and card you will be very pleased.
Jun 12, 2011 | Computers & Internet
How do you configure a router to a network?
go into enable mode (type "en")
type "show run" to identify the interface you wish to configure.
type "conf t"
type the interface name e.g. eth0/0 or serial0/1/0 or fa0
the prompt should change to reflect interface mode (config-if)
type ip address 192.168.1.1 255.255.255.0 (for example)
type "no shut"
Mar 21, 2010 | Cisco 2610XM Router
How to speed changed in gigabitEthernet 2/1 from cisco 4506switch
Hi
Ok so once you have logged into the router you do the following
go into enable mode by tyoing in en
Then type in conf t
then type in int X where X = the interface
then type in speed 100
then type end
This will set the interface to 100mbps
Feb 27, 2010 | Cisco Catalyst 4506-E Cat4500 E-series...
Password Recovery for Cisco Catalyst 4506
Please see Cisco's page at http://www.cisco.com/en/US/products/hw/routers/ps5199/products_password_recovery09186a0080093e12.shtml
for step by step details and more in depth instruction.
1. Reboot
2. Press the "break" button on your keyboard within 60 seconds of the power-up to put the router into ROMMON mode.
3. confreg 0x2142
4. reset
5. type, "no" when prompted to enter the initial configuration dialog.
6. enable
7. copy startup-config running-config
8. conf t
9. enable secret <password>
11. config-register 0x2102
12. reboot again
Jan 20, 2010 | Cisco Catalyst 4506-E Cat4500 E-series...
We are converting from DSL to Comcast cable, both have a static IP & VPN to another site. Is there anything we have to do other then change the addresses?
As much as I know, you're correct. All you need is just change the static Internet IP from Comcast on the VPN configuration for local and remote gateway address.
Oct 25, 2009 | Cisco 871 Router
Unable to connect 2 routers need help!
Do you have any funky subnets for your Cisco router? Do not connect the wireless router to your network yet, as it may have the same IP address as your other router.
Basically the easiest way to do this is to set a dedicated IP for the 2Wire router on the Cisoo router. Then make them stay on the same subnet, but give an IP range for your Cisco router, like 1-50 or something. If you give the 2Wire router IP .51 for instance, then give the Wifi users on the 2Wire IP range from .52-75 or something.
Make the 2Wire router only use wifi and not serve DHCP addresses. Then you setup the 2Wire router to get its info from the Cisco router.
I searched and there is no howto out there for doing this with a Cisco router. However, here is one I used to setup a similar scenario with a Netgear router. It worked. If you are able to translate a bit, it might work for you:
http://kbserver.netgear.com/inquira/default.asp?ui_mode=answer&prior_transaction_id=306896&action_code=5&highlight_info=16778323,235,239&turl=http%3A%2F%2Fkbserver.netgear.com%2Fkb_web_files%2Fn101236.asp&answer_id=6056802#__highlight
Here is another article:
http://kbserver.netgear.com/inquira/default.asp?ui_mode=answer&prior_transaction_id=306896&action_code=5&highlight_info=16777285,246,260&turl=http%3A%2F%2Fkbserver.netgear.com%2Fkb_web_files%2FN101496.asp&answer_id=6056800#__highlight
Let me know if you are able to work through this. You need to give the 2wire router a static IP and you need to NOT use it for wired connections, and not use it to serve DHCP settings.
Jan 21, 2009 | 2wire 2700HG-B Router (2700HGB)
Cisco 857 router
You might need to reset the password. In order to do this, follow these directions:
  1. Console into the router, then power cycle it. As its rebooting hit the "break | pause" button on your keyboard, and you get to the rommon1> prompt.
  2. Then type rommon1>confreg 2142 rommon2>reset
  3. The router comes back on as if it were new---answer no to the first question, and sometimes it asks a second question (do you want to terminate autoinstall, or something...)---answer yes to the secondquestion if it asks. Then hit enter and you get router> in a few seconds.
  4. Then router>en router#copy start run
create a new account:
  1. router#conf t
  2. router(config)#username bob priv 15 password bob
set register back:
  1. router(config)#confreg 0x2102
  2. router(config)#exit
  3. router#wr
  4. router#reboot
and that should let you login with bob/bob
Nov 30, 2008 | Computers & Internet
Computers & Internet Logo
96 people viewed this question
David Payne
David Payne
