Question about Cameras
On the samsung p1000 digital camera charging is proving a problem. An orange light keeps blinking when the charger is connected and the camera remains uncharged and will not switch on
  • Anonymous Mar 18, 2009
    i have the same problem. is there a solution?
Had the same problem! brand new camera, never had it switched on and it just kept blinking.
took battery and card out, put battery in then tried to charge. same orange light.
put card back in and took battery out for min and replaced, red light is on now!
hoping this has done it. will try camera in few hours!
Posted on Jan 16, 2009
Camera keeps opening and closing, orange light comes on
Wow, Not even the manual knows this error. Must be serious. It can mean two things in my mind. The lens is obstructed some how. Inside or outside. Or the battery is not ok. If you can't see anything on the lens barrel outside, please try to charge the battery. The camera will shut down without warning, when the power is low. Be aware the camera won't work as you expect, when a USB cable is attached. Actually you are not allowed to connect the charger, when the camera is still switched on. Look how the charger reacts. See if the battery is charged as before, because if the signal battery full does not appear it could be you have to buy a new battery.
Success.
Jan 13, 2014 | Olympus Stylus 700 / 700 Digital Camera
Hello Sir / Madam, I've got a Samsung Camera L730, 7.2 mega pixel, the problem is while charging, 1st it showed red LED light ( as usual ), then immediately an orange light starts blinking (as per...
Do you have change a Samsung L730 battery and to see if it can be charged? If you charge the battery in camera. It seems something wrong with the build-in charger core. If the camera all are OK beside charge battery, you can charge your Samsung L730 battery with a battery charger, and if your Li-ion battery is over discharged for a long time, it's bad for it. As your camera has been used for 2 years and it maybe not in warranty. To change build-in charger core should be expensive.
Apr 29, 2011 | Cameras
My battery is empty but if i plug it in to charge.. it keeps blinking orange and aint charging.. When i got this camera as a present it had the same problem.. bought a new battery.. problem fixed and even...
I have this same problem. I went onto the Samsung website troubleshooting and it says that if there is an orange blinking light then the charging cable is damaged and needs to be replaced. Hope this helps!
Feb 19, 2011 | Samsung L100 Digital Camera
Samsung ES60 not charging the charger just keeps blinking a yellow light and it does not charge at all
Link
Kindly consult this problem to your nearest Samsung Authorized Dealer as the possible problem is with the charger as it does not charge anymore. You can browse above link for Samsung Support Team.
Thank you.
Aug 02, 2010 | Samsung NV24 HD Digital Camera
Charging doubts
Personally I would suggest leaving it in the charger maybe even overnight because if I'm not mistaken it should turn green when it is fully charged. good luck
Jun 25, 2009 | Samsung L100 Digital Camera
My Samasung NV3 is not charging and not swtiching on.
My suggestion is to open the battery door on your camera and remove the battery for 60 seconds. Then put the battery back in and close the battery door. Then try charging it and powering it on
May 30, 2009 | Samsung NV3 Digital Camera
Charger red lite flashing. Camera comes on for one second and shuts off
Here's a copy from the owners manual:
■ Charging LED
Red LED is on = Being charged
Red LED is blinking = Charging error
Green LED is on = Carging is complete
● If the charge indicator blinks as red, it indicates a battery charging error.
- The battery is not properly inserted
- The terminals of battery are dirty or damaged
If the battery is inserted properly and the charge indicator continues to blink, contact the
nearest Samsung Camera Service Center.
Another charging error is when the batteries are so depleted, they won't charge up to 100% anymore = red light doesn't go out and remains on for too long, means get a new battery.
Jun 10, 2008 | Samsung Digimax i5 Digital Camera
Samsung battery
Green:Fully charged
Amber:Improper connection
Red:Charging
Sep 04, 2007 | Samsung SCH-i730 Pocket PC
Cameras Logo
620 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
