Which is the poitive connection on the DC connector tip for a TINY A 360 laptop
    President:
  • 1,901 Answers
Not familiar with an A360, but if the adapter is anything like this:
All I have ever seen are negative on the outside of the barrel, and positive inside.
Posted on Nov 21, 2008
Amilio laptop not charging in spite of new charger
please measure the output for your charger,normally they have 19.5 vdc exactly, if they do not measure the adapter is faulty, repair or replace.If the output is o.k the battery can be faulty. Use the software diagnostic coming with the computer, restart the computer HOLD the key f2 or esc depending of your computer model, and make the diagnostic.try again and see what is the result, if the battery is o.k or faulty.God bless you
Apr 05, 2013 | Fujitsu Computers & Internet
I can not identify where to silder wires connecting to my mother board
And you expect by this one lone statement, that someone else can?
A) Lenovo laptop? Good. Now POST the model number.
It's on the Bottom of the laptop.
B) Solder wires connecting your motherboard to WHAT?
Passing airplanes?
State what you are trying to connect to.
DC Power Jack to motherboard?
Is the DC Power Jack a DC Power Harness?
The DC Power Jack has wires coming off of it, that end in a plug connector.
The jack plugs into the motherboard.
Did the plug connector come off the wires?
Post back in a Comment.
Regards,
joecoolvette
Jan 31, 2013 | Lenovo 3000 Computers & Internet
Won't charge, purchased new battery and new AC adapter, still does not charge. AC charges other Dell I have so must be in charging circuit or connector. How do I disassembly computer to voltage getting to...
You are right, most of the situations like this end up that the charging connector fixed / soldered to the motherboard get damaged because of shaking the connector when ever we connect and disconnect it .
Mar 06, 2011 | Dell Inspiron 2600 Notebook
I have the targus model APM65US DC auto/air adaptor and various tips. Which tip/connector is compatible with a Dell Inspiron miniu 10. Several look like the right size: #s 102, 104, 206, and 207. Which...
I know this sounds odd but use whichever one is the best fit and works. Also I suggest that you compare them carefully with the original noting differences in length, diameter and construction.
I think you will find that one fits better than the others.If it works and you don't have to push too hard to locate it, and it stays in firmly and connects OK then it will be fine.
regards
I hope I have been of help but please do not hesitate to ask if you have any further questions.
Feb 20, 2011 | Targus APM65US Auto/Airline/AC Adapter -...
On start up the lap top starts to come on and within 6 seconds it switches off and not even the screen comes on?
Do you have it plugged in? Also, do you know if the battery is charging? You may have a bad DC connection.
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
The DC connector needs to be resoldered on the system board.
Dec 08, 2010 | HP Compaq nc6000 Notebook
I have an ASUS eee netbook. Recently the power cord hasn't been connecting well to the computer and now it doesn't even register. It's plugged in but isn't charging. Is it the cord or the laptop?
You have a bad DC connector, which came loose from the system board:
Problem symptoms:
Here is a tutorial on how to fix a DC connector problem. You may want to have a tech fix it.
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
Nov 30, 2010 | ASUS Computers & Internet
Intermittent dc jack connection for Gateway mx3215
Here is how to disassemble Gateway laptop,
Here is replacement DC socket (needs soldering),
Here is DC board (no need soldering, but expensive).
Hope this helps.
Mar 17, 2009 | Gateway MX3215 Notebook
Wiring poitive and negative
Hi, I have an SBM 500H massage cushion without that AC-DC adaptor... may I know whats the working DC Voltage in Volts and DC Current in amps it works on? Kindly, email me at stycch@yahoo.com... Thanks!
Feb 04, 2009 | Homedics SBM 300H Therapist Select Shiatsu...
Targus laptop ac adaptor is not recognized by laptop all the time i have to wiggle connector for it to work
its not your ac adaptor its the connector in the laptop it eather has to be fixed or replaced
Jul 05, 2008 | Computers & Internet
Removing the DC input from a Gateway 7322gz notebook
I tried looking up a manual on how to remove the motherboard on Gateway's support site but they do not provide one. They may have one available that is not published on the site. I would first contact their tech support via Chat and ask if they have one available for download. This would give you specific instructions on how to open the laptop and remove the motherboard so you can replace the DC jack. You will need the serial number from the laptop to open a chat session.
If they do not have one you can try it yourself. I did this myself with my HP laptop and after many tedious hours of work I was able to remove the motherboard, remove the dc jack, and resauder a new one on the board and it worked out perfectly.
If you feel comfortable doing the work yourself first start off by removing the screws on the bottom. You then should be able to remove the keyboard, look for a cable that connects it to the board. Now you should be able to remove the pieces of the case around the keyboard, look for the cable connecting the touchpad to the motherboard. After that you should be able to remove the LCD screen, look for the cable connecting it to the motherboard. Now remove the screws holding the motherboard in and remove the tiny bolts around the external monitor connector and the printer connector if you have one. Now you should have access to the DC jack. You will need to sauder the current one off the board and resauder a new one on. Keep track of the many many screws and try placing the components in the order they came out so will know which ones need to go back in in the proper order.
This is VERY tedious if you are not familiar with working on laptop hardware. You maybe able to find a local shop willing to do this or you can look online for a place that replaces DC jacks on motherboards.
Hope this helps!
Nov 29, 2007 | Gateway 7322GZ Notebook
Open Questions:
Computers & Internet Logo
David Payne
David Payne
