Question about LG LRM1250 Microwave Oven
LG MS-3444DPS microwave - spins but doesnt heat
After entering number's on keypad I hit 'Start' and there was a noise inside microwave "Fatt" (same like how capacitor explode).
Now microwave lights come on, also it spins, but does not heat up.
I checked the capacitor which looks ok (no leaking).
Device is out of warranty.
Could some one help me on this?
Thanks
  • kodlya Dec 12, 2008
    Thanks, I tried changing the Diode but no difference....
  • LG Master
  • 9,098 Answers
Chances are you have shorted or blown high voltage rectifier diode.
Here is a link you or someone you know can use to test it, but please read the safety info:
http://www.gallawa.com/microtech/diode.html
To order Goldstar / L.G. parts, visit Vance Baldwin Electronics.
For more Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here.
Posted on Nov 23, 2008
  • William Miller
    William Miller Dec 12, 2008
    You mean you changed the diode without testing it?
    When you try to cook, does it sound louder or quieter than normal?
What is wrong with our LG microwave oven ms 5646 it gets electricity, but it still doesnt go on?
Check the main fuse for continuity - inside the cabinet, near where the power cord enters. Stay away from all high voltage components as they can carry a charge of 4000 volts, or more, even when the oven is not operating.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
May 10, 2014 | Microwave Ovens
My still fairly new kenmore 1000 watt microwave appears to be operating fine but doesnt heat. What might be the problem?
When you hit "Start" to microwave, do the inside light, cooling fan, and turntable all come on?
Any unusual noises? Is it louder or quieter than usual?
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are operating here.
Post a new help request with the answers to these questions as well as the full model number from the tag on or in the unit.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Apr 14, 2013 | Kenmore 62622 Microwave Oven
Have a LG micro wave model no ms-3444dps and is not heating
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
YOUR SAFETY IS PARAMOUNT
This is a job for a professional but if you are safety clued up, here's instruction.
Make sure the !!!!any capacitors are discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 or moving coil meter on high resistance range for short circuit, (DVM's won't show the fault!), the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Mar 07, 2011 | Microwave Ovens
Model Goldstar MS-71tc. when I plug the microwave in it on and the table spins and light inside is on as though it is microwaving something. But there is no heat being generated.I put something in to try...
The problem is in the magnetron "more likely" or the high voltage transformer that drives the magnetron. The cost to repair will run high in either case and come down to a personal choice, but! in the long run cheaper to buy new than to repair.
Jan 16, 2011 | Goldstar MV-1501 Microwave Oven
I have LG MS-3444DPS Intellowave Microwave oven. Turntable has had intermittent high pitch squeal and also thumping noise as turn table turns. Turn table has also been very jerky since new. What is the fix...
If you were to take the turntable coaster out and wash it in hot washing up water paying attention to the wheel surfaces, I think that will fix your problem as I suspect the wheels are uneven with deposits stuck to at least one.
Hope this helps.
Nov 27, 2010 | LG Microwave Ovens
Keypad does not work after steam hits it
I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels.
If it does not dry out over time, it may need to be manually dried or blown out.
The keypad may be damaged or worn out, or control unit may be damaged.
Keypad failure can cause it to come on by itself, which can lead to a fire.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
May 24, 2010 | General Electric Microwave Oven
LG microwave LMVM2075ST panel started acting crazy after I cleaned it. Will not do anything if I push a button except beeping noises. Any suggestions as to what is going on with this machine? Should I try...
liquid probably has entered keypad laminate; causing a short. unplug unit, direct warm hairdryer to entire keypad; plug back in; and hope for the best. if no luck; replace keypad. also never spray anything directly onto keypad; always clean with a moistened towel with light force.
Sep 07, 2009 | LG LMVM2075 Microwave Oven
Microwave stopped working when i pushed the start button
Yes. The white inside the glass that you are describing is a blown fuse. To find out what size fuse it is look around the base or top of the fuse. You will see engraved something like "125V 5A. You can pick these up at Home Depot or Lowes in the electrical isle. You can also type www.google.com and enter the word "fuse" and then the size it is. (125V 5A) If you have found this information at all helpfull, please rate my solution. Thanks D. Lange
Apr 23, 2009 | LG Microwave Ovens
MS-3444DPS LG Microwave
You can see and hear a YouTube video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven. You may have to cut the cover off with snips, then use a screw when reassembling it.
For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit http://www.lgservice.com.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 26, 2008 | LG LRM1250 Microwave Oven
Microwave Keypad not working
This model does have a child lock. If it's on, the display will say "LOCKED". It is turned on and off by holding dfown the "0" key for 4-5 seconds. You may also have a bad keypad, which in many cases can be replaced. A bad keypad may be worn out due to age, damaged, or it may have gotten wet or otherwise contaminated. Moisture and contamination can be caused by spraying of cleaners, by storing the microwave in an unheated garage or shed, or infestation. I warn my customers to never spray cleaner directly onto the microwave keypad, since the liquid can get inside and "lock up" or even ruin the keypad or controller. Apply an alcohol-based cleaner (such as the purple kind) to a cloth (paper towels can scratch) and gently wipe it off. I suggest to my customers that they NEVER use any ammonia-based cleaner (like the blue stuff) on a microwave, since the ammonia will crack and distort polycarbonate plastics. Repost if you need more help.
Nov 04, 2006 | LG LMVM1935 Convection/Microwave Oven
LG LRM1250 Microwave Oven Logo
243 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Ross Metcalfe
Ross Metcalfe
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
