Question about Ovens
No heat we have replaced the element in the oven although the oven is on and the element is on the oven will not heat up.
  • 833 Answers
I'm assuming that you've changed the element and turned on the appropriate control and it isn't heating.  If so, the control or relay related to it is likely bad.  Did you check to see that BOTH breakers are working?  Did you see if the socket holding the element is undamaged?  Is the wiring to it in good condition?
Have you checked to see if the high limit element is conducting?    Use your circuit diagram to trace...with the power off.
Posted on Nov 21, 2008
My defy oven's bottom element heat up although the oven is turned off
Assuming you have not removed or reconnected any of the wires I would look at the thermostat.
Nov 23, 2014 | Ovens
Lower oven loss of power
I'd check the control switch first, and the wireing and connections.
Sep 05, 2012 | Ovens
I have a Zanussi ZHQ575 X Double oven, the main oven will not work when I select the Fan Oven setting. I have tried a new selector switch but it still will not work on this setting. The fan comes on but...
I have the same problem.... It's not the element gents, please read the question again... the oven heats up on the other settings it's just when you select fan oven (the most popular) I too have tried replacing the selector switch with no luck. Really need a wiring diagram.
Apr 14, 2012 | Zanussi ZHQ575 Electric Double Oven
Hi I have just replaced the oven element for my baumatic thinking this was the cause of the oven not heating up, but it still does not heat up although the element gets slightly warm. The thermostat...
Try removing the thermostat bulb from the oven and then turning it on. (Observe the elements carefully because they could over heat very quickly). If they do get hot under this condition, the thermostat is faulty and needs to be replaced. This is not a difficult task, just make a note of how the old one came out and replace the new one the same way. Make special note of the wire terminal positions.
Apr 04, 2011 | Baumatic Ovens
No heat from oven although fan and light are both working
hello gavin..... Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
This is an inexpensive part and relatively easy to replace. Call your local appliance store to obtain the part and the instructions on how to install it. Joe
Thanks for choosing Fixya!
Jan 05, 2011 | Belling XOU270 / XOU271 Electric Single...
Oven has stopped heating up
Hi.
This oven should have two elements.
If both broiling and baking element are not heating, then the most common fault causing the problem is a defective temperature probe.
The probe is located inside the oven cavity.
On most ovens there is only one temperature sensor, connected in line on the circuit from electroning oven control to baking and broiling element.
When the probe fails, it will affect both baking and broiling function.
The temperature probe is tested reching the probe, cutting or disconnecting its wiring, and testing the probe at room temperature, with a multimeter set on impedance at Rx1. If the multimeter reads no continuity (circuit open), then the probe must be replaced.
If the temperature probe is good, then parts that may be responsible for the fault are oven electronic control and wiring. Having both elements failing at the same time would be rather unusual.
If only one element is failing, then the fault is probably the element. In that case you can test the element removing it from the cavity, and testing Ohms on the element. If circuit is open , then the element must be replaced.
Regards.
Mar 03, 2010 | Baumatic B180 Electric Single Oven
Oven not working - rest of appliance fine
It is most likely that the oven heating element has failed and will need to be replaced.
This not an overly expensive part to have replaced and should be much less than the cost of buying a new oven although you would need to compare actual costs in your area.
Jan 17, 2010 | Ovens
Heat element is not coming on!
It is entirely possible that while cleaning the oven you may have inadvertantly bumped the element enough to cause it's connection to come loose enough not to work. With the power unplugged, wiggle the element where the connection is made inside the oven. If this does not work it is possible the element has 'gone bad'. Sometimes this happens from various causes and replacements are available from the manufacturer
Dec 04, 2009 | AEG Ovens
Oven will not heat
Although I am not familiar with this oven, living in the u/k, I would say that without any doubt the oven element(s) have failed, more so if the fan is working, so I would have hesitation that you replace the suspect element (s)..
Plz let me know how you get on.Thanks.
Jan 03, 2009 | GE JKP15 Electric Single Oven
Ovens Logo
91 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
