Question about Creda Washing Machines
Creda iwf12 keeps filling and then emptying - Creda Washing Machines
  • 3 Answers
Take a look at outlet hose if low down it will back syphon it needs to be at the top of the machine to the outlet pipe to drain
ross
Posted on Nov 21, 2008
My creda simplicty washing machine W200FW) is not finishing programs - it spins and fills but doesn't end - on a rinse cycle it just keeps spinning with water in, on a spin cycle it will drain but on
This is sometimes caused by water not exiting during or at the end of the wash. I have also encountered door lock issue for the same reason.
Jan 21, 2015 | Creda Washing Machines
Hi i have a creda iw160v that wont spin or empty the water from the drum. It gets to the spin programme and you can hear a kind of continuous clicking noise. I have cleared some muck and a button from the...
You would have to remove the pump underneath. Ones removed you will see probably a small socks lodged in it. This keeps the drum from spinning and also draining the water. This can also cause the motor to short so i hope it is not shorted yet. Those pumps are attached with large clips, and has two hoses attached to it. Make sure you have a pan to catch the water. and unplug it first. lots of water and electricity is a bad combination. If the pump is mechnically damaged you can get one for about 30 bucks.
May 28, 2011 | Creda Washing Machines
Creda Simplicity 1000 (w100fw) - Drum does not rotate
you could try fitting new motor brush kit it wears down after 4/5 years and need replaced....please leave feedback
Apr 08, 2010 | Creda W100FW Front Load Washer
The suspension spring came undone and fell accross the circuit board shorting it out. Now it will not change cycle and does not wash. I don't think it is filling properly and it doesn't seem to drain...
That sounds like you have right idea. Call your service provider and give them your model and serial number of your washing machine and they can order you a new board. Unplug your washer and switch the board wire for wire.
Feb 03, 2010 | Creda W120VW Front Load Washer
Have a Creda Solarspeed cooker and it Keep and
no..cannot fix it or repair...its normal for cooker....tnx
Jan 16, 2010 | Creda Colonial 42352 23 in. Electric...
Have hoover H130E model, it will fill and spin, will not empty. Have checked black fat pipe to back and propeller thingy to the front of machine and all fine. It's not even making a noise thats sounds like...
Hi.
If the pump is not even starting, then pump is probably faulty.
The pump is simply tested by energizing it. This test must be done by a technician.
Before replacing the pump there is another device that must be tested. It is the pressure switch that detects water level.
Regards.
Nov 13, 2009 | Creda W100FW Front Load Washer
My washer isn't emptying it keeps filling up and flooding
Pressure swith not cutting off, think this is clogged feed tube to switch.. happens often with this.could be rarely faulty fill valve......Good luck
Sep 29, 2009 | Creda W100FW Front Load Washer
My washer does not empty
i had the same prob when i had a new kitchen fitted. . all i did was put the pipe that goes to the sink part in the shape of a n , that will solve it.......
Jun 17, 2009 | Creda W100FW Front Load Washer
Dial keeps turning and clicking
sue worth having inlet valve checked also have heater checked at same time ! is the machine draining ok !! if not there could be blockage in drain system or faulty pump good luck- regards bob btw
Feb 26, 2008 | Creda IWD12 Front Load Washer / Dryer
Washing Machines Logo
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
