Question about Microsoft Xbox Console
Red and green flashing light
Hi guys, my xbox flashed red and green lights and after the xbox logo in the bootup screen, it says needs to be serviced and error code is 12. what could be the problem?? the dvd drive doesn't open up either.
    Problem Solver:
  • 6 Answers
Http://www.llamma.com/xbox/Repairs/explanation_of_error_codes.htm
Check out this web site. It said that
Error code =12 - kernel - DVD parameters (PIO/DMA) Your xbox is having difficulty communicating with the DVD drive. Most often replacing the DVD drive will resolve the issue.
Replacing you DVD is very easy follow the steps in this web site:
http://www.llamma.com/xbox/Repairs/crack_open_that_xbox.htm
Posted on Nov 23, 2008
  • 3 Answers
I had a somewhat similar problem. I remember the drive wouldn't open. i recommend sending to Microsoft for repair. That should do it.
Posted on Nov 21, 2008
My son has been given an original Xbox. He has played with it for 2 days without trouble. When he went to turn it on this morning it loads the Xbox logo, then the mirosoft logo but then defaults to a...
I could repair the xbox for you or possibly replace any damaged parts mostly the hardrive. I wouldnt charge or anything since the console is old the means to repair are simple yet i would need the xbox here as its hard to give you the means to do so!
Dec 26, 2010 | Microsoft Xbox Console
Xbox wont power on past orange brick light
You need to have the 3 red light fix service. We can fix it for you. We are a listed repair service on this site. Here is a link to our 3 red light service.
http://www.videogamerepairservice.com/catalog/item/5675532/5556610.htm
Dec 08, 2009 | Microsoft Xbox 360 Console
Xbox red green flashing lights
r they all red or only certain ones the most common thing to check first are the av cables/hdmi cable from the xbox to the tv.. if they are loose on the xbox it will show the red ring in a sequence make sure their tight...if this does not fix it YOU HAVE THE RED RING OF DEATH its either overheated or you have a bad disk drive or something internal....you will need to call microsoft
Feb 23, 2009 | Video Game Consoles & Games
Xbox Original flashing green and red
Hi there!
This is known as the Christmas lights or FRAG frequent red and green error.
Most of the time the screen is blank and if you were doing work recently such as modchipping this could be caused by solder splashes on the mobo or a shot MCPX chip. Removing the MCPX chip is impossible without very expensive equipment so if you can't find any solder splashes or you weren't soldering on the board junk the whole board.
However, since you said that your xbox is original, I would assume that you haven't done any modifications yet so chances are, the xbox can't find an AV cable connected to this unit. If you do have one, please check if your AV cable is damaged (a frayed or damaged wire). Replace your AV cables and your good to go.
Cheers!
Dec 21, 2008 | Microsoft Xbox Console
Xbox360 and the 3 red lights
Three of the lights on the Ring of Light on the front of your Xbox 360 console flash red View products that this article applies to. if (!loadTOCNode) {var loadTOCNode = function(){}} Expand all | Collapse all if (kb_page_object) { kb_page_object.kb_imageExpandHoverText = 'Click to expand this image'; } SYMPTOMS Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360... loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. uparrow.gifBack to the top CAUSE The three flashing red lights may indicate that there is a hardware problem with... loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. uparrow.gifBack to the top MORE INFORMATION If you are experiencing this problem, you can submit a console-repair request on... loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem:
  1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/ ) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/ ) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/ ) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated
  2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.
If your console continues to display three flashing red lights, your console may have to be repaired. For more information about how to start the repair process online, please visit http://www.xbox.com/support (http://www.xbox.com/support) , and then click Repair your console in the upper-right part of the Web page. Note Online console repair service is currently not available in all countries and regions.If you want to instead contact Xbox Customer Support directly, please visit http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) for information about how to do this.
Dec 06, 2008 | Video Game Consoles & Games
Three red lights on my xbox 360
SYMPTOMS loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. uparrow.gifBack to the top
CAUSE loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. uparrow.gifBack to the top
MORE INFORMATION loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem: 1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated 2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.If your console continues to display three flashing red lights, your console may have to be repaired. If none of these help, pease contact Xbox support at http://xbox.agent.asahost.com/ to talk to a live agent.
Sep 05, 2008 | Video Game Consoles & Games
4 red lights flashing
The TV screen or monitor remains black when you start an Xbox 360 console.
This behavior may occur with or without a game disc in the disc tray. The console appears to be on because the green power light illuminates and the fan continues to operate. However, the screen remains black.
Click on the IMAGE i paste here below:
Thank you,
~micro
May 21, 2008 | Microsoft Xbox 360 Console
How do I Fix flashing green and red light
What error number does it have on the screen? It should be a white number in one of the corners of the screen. If you find out what it is, then select add more details in this question and say what the error number is.
Dec 22, 2007 | Microsoft Xbox Console
3 flashing red lights
got to e bay theres a guy on there selling plans on how to fix the three red lights will save u a lot of money as u wood have to send back to microsoft 4 fixing and its about £25 p&p the the repear on top then p&p back to u hope these helps e mail me if u need more info david666t@yahoo.co.uk thanks
Dec 01, 2007 | Microsoft Xbox Console
Flashing red and green light in xbox
You have a major failure on the motherboard. If it was your hard drive the system will boot up, but freeze on the main screen and you will hear clicking coming out of the hard drive. Red and Green flashing lights means there is a problem on the motherboard. Sometimes you can fix the problem by reflashing the Bios on the main motherboard.
Nov 11, 2007 | Microsoft Xbox Console
Microsoft Xbox Console Logo
149 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
