Question about Yamaha HTR-5990 Receiver
SW-12 subwoofer not working
Infinity sw-12 is not working, everything is out of box, any help wuld be great.
  • 236 Answers
SOURCE: subwoofer
the best connection is to connect your sub to the output connector (subwoofer) of your HTR. it should have one. But you can also connect parallel to the speakers, any of right or left speakers or both. i normally connect to the speaker set B if thorugh the speaker connections.
Posted on Mar 31, 2008
0 characters
1 Points
I have a Pioneer VSX-1123-k receiver and a Klipsch SW 450 subwoofer and the connection is not clear. Can anyone help?
Should be an rca connector on the back of the receiver marked subwoofer or sub preout. connect that to the rca connector on the sub and it should be good to go.
Sep 26, 2013 | Pioneer Audio & Video Receivers
I just bought a subwoofer and I cannot get it to work. I changed the receiver setting to SW = YES. Where is the correct place to plug it in the receiver, there are two subwoofer outlets.
Here's your manual. Check Pg. 9 for correct Sub Woofer connection. Leave the SW=YES setting as is if you any small speakers in the system. It can be set to SW=PLUS if you want all bass signals sent to the Sub Woofer. It should only be set to SW=NO if no Sub Woofer is connected. Experiment between the YES and PLUS settings and leave it where it sounds best to you.
If this was helpful, please rate it "4 thumbs up" - thanks & good luck!
Aug 04, 2011 | Pioneer VSX-D514 Receiver
I have a cambridge audio Azure 540R. WAs all working fine. A red box with SW under the L speaker channel has appeared. No sound from the L speaker, Although the test sound through the L channel is ok. The...
Register and download the manual for free at
"SW" stands for SubWoofer.
Page 8...
Shows the currently active channels depending on decoding mode and source material. Icons lit indicate active channels in the source material. Icons with a box around them indicate actual channels being output separately.
Search for the word "balance". Page 8 again (circled 8)...
Lights when the Front Left and Right speaker outputs have been set to different levels in the OSD, i.e. a balance adjustment has been made.
You can look at the relative levels of all channels as described on Page 14.
Mar 22, 2011 | Cambridge Audio Azur 540R Receiver
What does the sw level setting do?
hello.. the sw level is short for your subwoofers volume setting .when you use a subwoofer thats powered and connect it to your recievers sub out,this is than a way to adjust the subs volume from your seating position rather than only adjusting it from the back of the sub.. i recommend putting your subs volume(on the back of the sub itself) to midpoint and playing a bass heavy song or movie and adjusting the sub level on the reciever to how you like it.. enjoy
Sep 11, 2010 | Audio & Video Receivers
How do i connect it to a the subwoffer sw 50 ht
on the back of your receiver is a subwoofer pre-out, connect one cable here, and connect the other end of this cable to your subwoofer - line level in. (depends on your subwoofer and receiver) but that's how mine is connected. yours will be similar.
Feb 10, 2010 | Kenwood VR-505 Receiver
Speaker wire for subwoofer
Usually, a subwoofer will have its own built-in power amplifier. Thus, it will be designed to plug into a standard RCA jack (the type used for DVD players, etc). rather than having wires to connect to a speaker terminal block. Look for a jack on the back of the receiver called "Subwoofer", or simply "SW". If your subwoofer has 2 single wires, it WON'T work with your reveiver's subwoofer output, as this output only carries a line-level signal and is not amplified. You would need a separate power amplifier for this type of SW. If your SW speaker has a DVD-type plug, it should work fine with the receiver's SW output jack.
Jan 02, 2009 | JVC RX-554V Receiver
RCA Sub-Woofer
Did you try making sure the subwoofer is turned on under the set up menu on the Sony Receiver?
Press Set Up, Press the left or right button above the scroll wheel until you get to SW. It should say SW: ON or SW: OFF. If it says SW: OFF, use the Scroll wheel to scroll right until it says SW: ON. Also, make sure you aren't in 2CH mode, try A.F.D or surround sound.
Jul 26, 2008 | Sony STR-DE445 Receiver
Sub Problem with Dennonavr- 1907
Go into setup and make sure sub is turned on and set sub for LFE + main otherwise sub will only work with Dolby Digital LFE signals. LFE plus main setting will allow sub to output low freq's that would normally go to Front Speakers. Refer to Owners manual setup Info.
Feb 11, 2008 | Denon AVR-1907 Receiver
Onkyo TX-SR304
Onkyo offers access to manuals at their web site. HERE is a link to the receiver line.
Personally, I'd connect the speakers to main left/right. The subwoofer to subwoofer out. The Go VIdeo unit to VCR/Video 1, the cable box to Video 2 and the video output to the Sony TV composite input. No need to connect the TV audio out to the receiver since the audio feed comes from the cable box.
Jan 13, 2008 | Onkyo TX-SR304 Receiver
Sub-woofer output not working
"Sub-woofer output not working" problem, and notify you when a new solution is offered.
Press the setup key on the front of the receiver
Select the subw setting
Move the multicontrol knob until the sub woofer is on
Turn off the receiver and turn back on- the subwoofer should be on
The operator manual can be downloaded on the web site--- free
Sep 22, 2007 | Kenwood VR-507 Receiver
Yamaha HTR-5990 Receiver Logo
Top Yamaha Audio & Video Receivers Experts
Steven Wander
Steven Wander
Larry Stiles
Larry Stiles
Are you a Yamaha Audio and Video Receiver Expert? Answer questions, earn points and help others
