Question about Compaq Armada M700 Notebook
Fixed Disk Parameter Error - System Halted
I have a problem here. Can anyone please help. My computer was working fine until the other day i turned it on and while booting it beeps 3 times and then says "Fixed Disk Parameter Error - System halted". Once this happens you can not do anything by pressing any key, you are just stuck and have to unplug the computer or take out the batterie to turn it off. Also, to let you know whiile it tries starting up before the 3 beeps happen, the hard drive is making some clacking noises. Made me pretty sure the hard drive was out. Then i figured out how to get on, when i hit power to start up i gotta hit F12 and it will let me on and use my computer like normal. Also while im using it no sounds coming from the hard drive. Anyone have any idea what's wrong here?
  • Ron Alta Dec 31, 2006
    do you think I should buy a new hard drive and see what happens. Someone told me that if it's working fine once i get in then my hard drive is ok. They said if my hard drive was no good i wouldn't be able to use it with no problems once i get in. Said the whole problem is with the BIOS and that's the clanking sound when the computer does not boot up the BIOS is trying to start.
    President:
  • 2,961 Answers
Sounds like bad disk, although 3 beeps sometimes relates to a memory problem on some motherboard bios's. Click Start>run then type'chkdsk' and then Enter, this will run a damage segment diagnosis and repair, if capable.
Posted on Dec 20, 2006
  • andrew pester
    andrew pester Jan 01, 2007
    No, the bios checks the Basic Input Output Settings, this is not something you can hear.
    After, date, time and timings are checked the processor then takes over to work the motherboard which then powers your HDD which then checks for the Boot.ini files to look for Windows.
    The noise is one of two peices of hardware, either HDD or CDROM.
    You will at times get it running, if you do go to my computer, right click>manage, then click on Disk management.
    Look at the 'C' drive, this will tell you it's state of health.
    The noise you can hear will be the platlettes of the drive trying to be read to find the boot files.
Foxconn p4m800p7ma-rs2 motherboard on Gforce FX5500 system halted
You refer to Master/Slave disks. Are you actually using the Master/Slave jumper settings? Must motherboards and OSs today recommend putting the disks in the CABLE SELECT jumper setting. The problem with the old Master/Slave setting is that the Controller on the Master Disk is used to control the Slave disk as well. This can lead to problems when disks are made by different manufacturers, as sometimes they are not fully compatible. In CABLE SELECT, each disk controller works independently.
Dec 30, 2011 | Foxconn Computers & Internet
Tengo un problema q es fixed disk parameter table or BIOS error system halted que puedo hacer
Deberías tener ciertas habilidades técnicas para resolver este problema, no es sencillo lo mejor sera que lleves tu computadora con un especialista el error que te marca es un error de la memoria del BIOS la encargada de iniciar tu sistema operativo(windows) llévala al técnico.
Suerte.
Aug 25, 2011 | Compaq Armada M700 Motherboard
Fixed Disk Parameter Table or BIOS Error Okay, so I was browsing around the web the other day. My notebook completely locked up, and I had to hold in the power button for 10 seconds to do a hard shut down....
Remove the hard drive and see if you get the same symptom. It should boot, then go into the BIOS and see if it recognizes the RAMs. Re-seat the RAMs if it doesn't boot - if you have two circuit boards - try one at a time. The motherboard can also be your problem.
Jan 21, 2011 | HP Compaq Smartbuy 5102 166 GHz Intel Atom...
Turn on notebook compaq nx6120, always 3 beeps and message "Fixed Disk Parameter Table or BIOS Error" and the low line is "System Halted", And another, i remove the HDD from my notebook in order to...
You should have gone into your Bios pages first.Press F2 whilst booting,learn how to to configure these pages,use the "tab" button to navigate and arrow keys ,Save and exit or restore to factory defaults,learn how to use these pages to enable correct boot sequence--good luck!
Davey Snake!
Oct 23, 2010 | HP Compaq nx6110 PC Laptop
My computer worked fine until one day I attempted to turn it on and it said operating system not found. What happened? Can this be fixed?
This error message could be caused by :-
Check the BIOS to see if it detects the hard disk
If not the hard disk may be faulty or needs reseating. If the hard disk is faulty it needs to be replaced and Windows installed on the new hard disk.
A virus program may have infected the computer and removed or changed some system files - in this case Windows needs to be repaired OR Windows re-installed - this is the best option.
Aug 11, 2010 | IBM ThinkPad X41 Notebook
How to fixed chassis intruded fatal error system halted
Good day! here's the following steps hope it will help you.
Unplug the computer
Take the MOBO battery out
Remove the chassis jumper
Wait a few minutes
Replace the chassis jumper
Replace the MOBO battery
Plug the computer in
Jul 24, 2010 | ASUS P5V800-MX Motherboard
It clicks alot when it's booting and i can't get it to turn all the way on. It says fixed disc parameter table or bios error system halted
It seems as if your hard drive has failed or is going to fail. When you hear a clicking noise like that with no CD in the system that is usually what the cause is.
May 20, 2010 | Compaq Armada M700 Notebook
Bios Issue/Hard Drive Upgrade
i have installed a 60gb hdd into an m700 without even having to stuff with the bios...
Xp sp2 allows you to install larger drives then the bios reccomends.
Feb 18, 2009 | Compaq Armada M700 Notebook
Boot up failure
Fixed disc is refering to your hardrive and the fact that it has been unable to read a bad sector on your hard drive, that sector probably being where the boot.ini file resides. You will have to get the drive checked out, by means of an 2.5" ide to usb powered connector, which will connect to another pc's usb port to enable you to perform a disk check and a repair if possible of the bad sectors, or take to a local repairer where they should have the required adapters.
Aug 21, 2007 | Compaq Armada E500 Notebook
Compaq Armada M700 Notebook Logo
386 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
