Question about Cameras
What lens do I use with a canon eos 500 35mm film slr
  • 44 Answers
Any Canon EF series lens except EF-S lenses will work with your Canon EOS Film Camera (EF-S lenses only fit Canon digital SLRs).
Posted on Nov 22, 2008
Quantaray lens
You did not mention which lens. Some Canon digital cameras will only take EFS lens, others take both EF and EFS. Also there are other types of lens mounts made by Canon.
Cordially,
Jan 01, 2014 | Canon EOS Rebel XS 35mm SLR Camera
Quantaray 70~210 Lens
If your lens is a EF mount and your digital can take EF lens the answer is yes.
Cordially,
Lens mount fit
None directly. The T90 was the last Canon camera to use the older FD lenses. All newer Canon SLRs, film and digital, use the EF mount. However, by using an adapter such as http://www.rakuten.com/prod/adorama-canon-fd-lens-to-eos-body-adapter-with-correction-glass/216466533.html?listingId=120668308, you can use the old lenses on any Canon digital SLR.
Aug 12, 2013 | Canon T90 35mm SLR Camera
Will the lenses for a film camera (Canon EOS Rebel) fit a new digital body? Thanks.
Yes the Canon EOS lenses from film bodies will fit and work well on Canon digital bodies.
Depending on the Canon digital body you select the lens may have a 1.6 x factor. Meaning the focal length of the film lens will become a longer focal length. For an example Canon's 50mm f1.8 lens on the APS size digital sensor will translate to an 80mm equivalent. This is great for most people but, getting a good wide angle lens is a bit of a challenge, there has to be a tread off somewhere. There are Canon full frame cameras that this factor doesn't apply, for example a Canon 5D.
Dec 08, 2010 | Canon EOS Rebel XS 35mm SLR Camera
Canon EOS 500n 35mm Film Camera, best cheap lens
In short, you won't. All Canon Digital SLR's use the same lens mounting system as your EOS 500n and new lenses are very expensive especially for those who have purchased full-frame models.
As a result, demand for the lenses which fit your camera is very high and so prices are high as well: it's just basic supply and demand economics. There were cheaply made kit lenses available with your camera when it was new, but like most kit lenses they weren't built to last, so most of the older ones are either non-functional or have been scrapped after owners upgraded. All that leaves are the higher quality, well built, lenses from the time your camera was made which are far cheaper than new lenses but still comparatively expensive.
If you want cheap lenses then you've picked the wrong system. Buy an older FD mount Canon SLR if you want to stay with Canon; you'll then find that lenses are so cheap that they're often offered for free on your local FreeCycle group. The same source is where I've got all of my manual focus (and some AF) SLR equipment over the last few years.
Mar 14, 2010 | Canon EOS 500n 35mm Film Camera
I have got an EOS Elan II E Film Camera (Cannon). I want to know Cannon has camera with a digital body which suits the lens attachment of EOS Elan II E.
Hi, all canon EOS digital cameras can take all EF lenses. An EF lens from 1989 will fit a Digital body from 2009.
The newer EF-S lenses will only work with the smaller APS-C size sensors on the cheaper consumer bodies.
Hope this answers your query, please take the time to rate!
Mar 10, 2009 | Canon EOS Elan IIE 35mm SLR Camera
Cannon lenses
All canon EF lenses (and compatibles e.g. Sigma EX) can be used with both analog and digital  EOS-bodies. Depending on the sensor size (usually smaller than a 35 mm negative) a crop-factor due to the smaller field of view must be considered.  Example: Canon EF 50mm/1.8 lens used on a digital EOS (40D, crop factor 1.6) equals a 80mm lens (50mm x 1.6) compared to analog cameras using 35mm film. Some digital EOS-models can also use EF-S lens-series.
Nov 28, 2008 | Canon EOS 40D Digital Camera
White balence
The EOS Rebel K2 is a film camera. White balance settings on digital cameras are an electronic 'adjustment' to the image sensor. In film cameras, the film is the image sensor. So white balance is dependent partially on the film you're using, but more often on the filters you add to the lens to correct for various lighting conditions and light sources.
Jun 13, 2008 | Canon EOS Rebel K2 35mm SLR Camera
Canon EOS Rebel G
From the Canon Help Email - this worked for me: If you are using an EF series Canon lens, please remove the lens and clean the lens contacts with a pencil eraser. We also suggest that you remove the film and battery for 15 minutes; ensure that the battery has a full charge and reinstall. If the issue persists, we suggest testing the camera with a different EF series Canon lens. Should this persist with a different lens, then the camera body itself will need to be examined.
Jan 17, 2007 | Canon EOS Rebel Ti / 300V 35mm SLR Camera
Cameras Logo
116 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
