Question about Asrock M266A Motherboard
Windows XP hangs up and never continue opening...
My windows xp does not continue opening. it does start reading but hangs up and never continue opening. Please help. I am on the "Safe Mode" right now. How can i fix this problem?
  • 781 Answers
Go to Windows Explorer Right click C:\ go to properties / Tools / click Error check new box pops up tick small box to fix errors and reboot. On reboot windows will scan disk and fix any errors in system files then restart.
If windows restarts OK problem solved If not
Boot from windows CD and after all drivers loaded windows will ask what you want t do 0Install Repair etc" press the R key for repair and follow instructions from there
Warning until window finishes installing do NOT press any keys when it reboots
Posted on Nov 21, 2008
  • David
    David Nov 21, 2008
    Please give me a Fixya when done thanks
Xp_rec_con.iso download
How to Create a Bootable XP Recovery Console CD:
http://www.bleepingcomputer.com/forums/t/485370/bootable-xp-recovery-console-arcdc/
Nov 19, 2013 | Microsoft Windows XP Professional for PC
My sony vaio laptop is always hang 5 to 7 mins. but mouse pointer is still moving. all application im working are stuck a few minutes. what are the possible solution for this problem. i do reformat but...
Please backup the data by logging in to Safe Mode, please restart and start pressing F8 key to select Safe Mode then re-install the Windows 7 Operating System using the Recovery Disc or recovery Partition of the Hard Drive. The Recovery Partition can be accessed by restarting the computer and try pressing F10 Key. The Windows XP Operating System is displaying an error because it does not have SATA Driver to detect the Hard Drive. As Windows 7 has it, you can re-install it from recovery partition.
Mar 24, 2011 | Sony VAIO (PCWA-A200)
My laptop hangs even before the windows is started, It also got heatup. any solution to the hanging problem?
A PC/laptop hangs when there is a clash of SW and HW. HW you can do nothing about and hence it is the SW or the operating system, ie, Windows that is at fault. It is just that some parts of the Windows OS hs got corrupted for some reason. Please re install Windows to get rid of the hanging problem. I am giving a link below for you to read, understand and follow if you have Windows XP. If other than Windows XP then you will have to do a fresh reinstall for which there is another link to be followed.
For Windows Xp http://www.informationweek.com/shared/printableArticle.jhtml;jsessionid=ZC30BJMORZQH5QE1GHPSKH4ATMY32JVN?articleID=189400897
For other Windows Saving Data After A Crashed Windows On...
Jun 07, 2010 | Sony VAIO VGN-T350P/T Notebook
My acer aspire 4315 hangs during shutdown. windows XP OS
This happens when there is a process still trying to work in the back end.
Try to disable most of the applications which get opened by default when windows starts.
Click on start/run/ and type msconfig. Once the window comes up click on start up tab and disable all.
Now try to reboot the system.
Also hope there is no usb device connected at the time of shut down. This would also make xp hang.
Thanks
Mar 01, 2010 | Acer Aspire 4315 Notebook
WINDOWS XP HANGS...
Increase the RAM in the system to at least 1 GB or More to resolve the problem
Nov 27, 2009 | Microsoft Windows XP Home Edition
Hanging on detection of drive when installing Windows XP
Installing Windows XP on a SATA hard drive is not a straight-forward task as Windows XP does not recognize the SATA drive. In order to install operating systems such as Windows XP on SATA drives, the latest SATA drivers are required.Download SATA drivers for the motherboard from the website and integrate them with the XP installation CD using software such as nLite. SATA drivers can also be installed as third party drivers; you will be prompted during the installation process. Without proper SATA drivers, installing Windows XP on a SATA hard drive is not possible as SATA mode would have to be disabled in the BIOS to continue with the installation.
Installing Windows XP on a Serial ATA hard drive is not an easy task, because the system does not recognize SATA drivers at startup. Windows XP Pro SP2 fares a little better with SATA drivers, but here is what can be done in cases where the driver is not recognized.
Mar 31, 2017 | Excelstor Technology J880 Hard Drive
Window xp home version hanging while typing login password
reload os or load xp when prompt to repair choosse that option select drive enter password and do a system restore from that location.
Apr 13, 2008 | Toshiba Satellite M45-S2692 Notebook
WINDOWS XP SERVICEPACK TWO INS NOT WORKING
try to change your ram b4 you install sp2.
Mar 15, 2008 | Intel D865GVHZ Motherboard
Not able to install win Xp
CHECK THE CMOS SETUP OF YOUR MOTHERBOARD,CHECK THE CMOS BATTERY AND MOST IMPORTANT READ YOUR MOTHERBOARD MANUAL INSTRUCTIONS
Feb 04, 2008 | Asrock M810LMR Motherboard
Installing xp
what i can suggest u is(1) boot from the cd first to do that at the starting of booting press del key in keyborad and u will go to cmos there u change the first boot priority to the cdrom then save and exit the setup put the xp cd in cdrom restart the computer and it will show like boot from cd windows xp... press enter it will boot and then follow the instructions or (2) else if u alredy have any operating system working on ur comp then go to the operating system and then put the xp cd the cd will auto run there it show u setup or install windows xp after that it will boot from there follow the instructions any of the comp can have windows xp might be u have got a non bootable disk then go to the(2)solution
Nov 20, 2007 | Microsoft Windows 98 for PC
Asrock M266A Motherboard Logo
143 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
