Question about Microsoft Xbox 360 Console
No colour on screen
Old box replaced now when plug in new box no colour on screen works on different tv but had no problem with old box on mine help
  • 63 Answers
Try a different cable, make sure its on the right channel, other than that without more information that is all the advice I can tell you right now.
Posted on Nov 23, 2008
Converter box will not stay on - starts green light then switches to red
I have one of those right here attached to my computer so I can watch TV on the PC. The red-green light is the power indicator. Your converter is turning off for some reason. Possibly it is getting a signal from another remote, and turning off. You can block the converter's remote sensor with something (black tape works) and then change the channels with front panel buttons if it has them.
Mine has power buttons for both the TV and the converter, so watch out for that.
Apr 06, 2017 | Televison & Video
I had the TV on earlier tonight. Turned it off. No problems. I turned it back on a couple of hours later and it started OK .. normal sounds of the tube 'kicking in'. I had volume, and then the entire...
Try a different source on the tv to see if the tv is toast. Ten years is quite old and tvs have come on a long way since this one. Alternatively try a different tv on the cable box.
May 03, 2011 | Panasonic CT-36SX31 36" TV
When i turn my tv on the sound is great but the picture is very narrow.My tv is at least 8 yrs old.
something similar to this happened to my old T.V, with mine it started to go wrong colours, the screen started to fade, with it being 8 years old, you may just need a new one, they will eventually fully break, so its best to get a new T.V
Dec 09, 2010 | Samsung DynaFlat TX-P2764 27" TV
Xbox 360 plays movies fine but colour is wrong on games
i will suggest if you new tv has more inputs, just try a different imput, and make sure the plugs are in all the way. this is a new tv so it will be tight.
same with the video connection on the back of xbox well plugged and straigt.
hope this woks. and remember to rate me if i helped you
Oct 09, 2009 | Microsoft Xbox 360 Console
Engine change
To write out instructions would take many pages. I suggest you get a manual. Here are some general tips though. When removing items write down everything you do for install reference. Label all plug ends with different coloured electrical tape not only on the plug, but on the component it goes to (match up on install.) Put everything you remove in boxes and cans. there is nothing like trying to find a lost bolt, etc. during install!! Look carefully at new and old engine. Anything different on new one must be replaced with old engine parts, so it matches up when installed. If replacement is used, check for any and all oil leaks it's far easier to deal with them out of the vehicle. As a rule, if replacement engine has over 100k on it, I replace the timing chain. Most are well worn by that time.If you did not hear or see the replacement run, check spark plugs for good burn pattern and colour, if you find burned residue, you don't want that engine!!! Do not forget to repalce any lost fluid from trans, transfer case etc before firing it up!!!
Feb 08, 2009 | 1996 Jeep Grand Cherokee
Screen says no signal. when i push the input button,tv says no signal not available Stuck on the blue screen, there is NO lock icon on the screen. I have the same problem. I attached the cable from my...
HD TVs do have different cables, I went to Time Warner and swapped my regular box for an HD box, the cable ends are blue red and white, I believe. Also in order for my box to work on the screen I have to switch to "Component" instead of "TV". Hope I helped!
Dec 11, 2008 | Haier HL22R 22 in. LCD TV
There is a lock on my screen and nothing works
Try holding the display button for 10 seconds, worked for mine, unless the vcr presents a different issue
Nov 10, 2008 | Insignia IS 20" TV040919 TV
Phone socket
I found some good information on this site: http://www.ling.upenn.edu/~kurisuto/phone_wiring.html.
He lists that the old style wire has become obsolete, and shows a diagram of how they line up to the new style.
Jun 17, 2008 | Lands Phones
NEED COLOR DISC RED GREEN BLUE CAN YOY HELP
You can use a samsung colour wheel on the Sagems (Part no.BP96-00250AT) and remove it from the Samsung mounting. There is a black 'flag' on the motor body that tells the TV where the colour wheel is. This is different on the sagem but you can just peel it off and draw a mark with a permanent marker pen in the same position as the old unit. I've replaced mine on HD-D45 recently. Works perfectly
Mar 12, 2008 | Televison & Video
No image on screen when boot up computer
check vga cable! check also video card on the pc!
Aug 16, 2007 | LG Flatron L1710S 17" LCD Monitor
Microsoft Xbox 360 Console Logo
35 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
