Question about Fuji FinePix F470 Digital Camera
Can't access pictures or turn on camera
I have just returned from holiday and tried to transfer my photos from my F470 to my PC. The transfer was about half done when a message appeared saying that the picture could not be copied and offering retry, cancel and skip options. I chose skip, and it repeated the message for the same photo. I canceled and ended the copying process. The camera then powered down. When I tried to turn it back on, the digital screen briefly turned gray and then turned off again. It now refuses to even do this and is completely unresponsive. Can you offer any advice or assistance?
  • 71 Answers
Hello, if the batteries where not fully charged when you where copying pictures to PC, the camera may have corrupted the pictures on the xD card. That is why the camera is showig a grey picture and turning off, it can't work without a valid picture card. A vey good way to restore the pictures on the card is to buy a card reader (they are unexpensive) that can handle xD cards and use a picture restore software.
For the restoration proccess, read the following page:
http://techblissonline.com/photo-recovery-deleted-pictures-corrupted-images/
Maybe you don't need to buy a card reader if your camera is recognized as a disk drive by the computer but I strongly recommend a card reader for future picture downloading to PC.
After recovering your pictures, you have to format your card in order to use it again in camera.
Posted on Nov 21, 2008
How do you access pictures on the internal memory of the Fine Pix F470? I'm not sure if the camera came with a USB cable...is that what is needed to connect the camera and my PC?
It is possible to transfer saved images on the internal memory to xD-Picture Card Page 67 on the manual - see limk below
The user manual is here http://fujifilmusa.com/shared/bin/FinePix_F470_Manual.pdf
It is possible to transfer saved images between the internal memory and an xD-Picture Card. 1Press the “w” button to turn the camera on in Playback mode. 2Press the “MENU/OK” button to display the menu on the LCD monitor. 2 a)Press “a” or “b” to select “û” COPY. b)Press “c”. 4 a)Press “a” or “b” to select “FRAME” or “ALL FRAMES”. b)Press the “MENU/OK” button. ALL FRAMES Copies all the frames (files). FRAME Copies only the selected frame (file). COPY 3 a)Press “a” or “b” to select INTERNAL MEMORY \ CARD or CARD \ INTERNAL MEMORY and confirm the copy source and copy destination. b)Press “c”.
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Apr 05, 2010 | Fuji FinePix F470 Digital Camera
Card error cannot shift
Get a card reader and use it to download your pics. Then, format the card in the camera to get it working again.
Apr 03, 2010 | Fuji FinePix F470 Digital Camera
My F470 Fuji Fine Pix takes stripey pictures but when it is in movie mode it is fine
Your cameras shutter is sticking. lines on photo's or over exposed photo's are due to the shutter not closing completely over the lens.
Video is fine because it does not use the shutter.
The shutter will require cleaning.
Oct 29, 2009 | Fuji FinePix F470 Digital Camera
Fuji f470 camera will not turn on. It was beeping and
Here are a couple of things that might be wrong. Your camera comes with what is called "internal memory" This is where your pictures will be stored if you don't have a XD card. One of the reasons your camera might be blinking is because that internal memory is full. If you don't have a XD card inserted in the slot that may be your problem. I would get your manual out and look up on how to transfer your photos from your camera to your computer or how to deleat them. I found this information on page 25 of the user manual for your camera. Page 31 shows how to erase the images. Hope this helps.
Jul 22, 2009 | Fuji FinePix F470 Digital Camera
Communication error when connection to PC. Usb is connected. Usb mode is switched on in camera.. Finepix F470 to apple Mac
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Mar 31, 2009 | Fuji FinePix F470 Digital Camera
Read error
Try formatting the card in the camera using the setting in the camera's menu.
Some makes of xd or sd cards do not work correctly in fuji camera's. Sometimes even formatting them in the camera does not have any effect.
Mar 25, 2009 | Fuji FinePix F470 Digital Camera
Cannot delete pictures, or access memory
there might some software trouble check using different memory card if nothing works try formating memory card r reinstall the software in camera
Dec 11, 2008 | Fuji FinePix F470 Digital Camera
Computer does not recognise the driver for the camera.
have you tried to get the new driver from the Sony Esupport website? and download and install throug that and see if that works? If you are having trouble finding it let me me know.
Nov 11, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Not able to transfer pics to computer (fuji finepix f470)
What computer and operating system have you? Meanwhile try this Remove any third party image software. for example if you have the Fuji software in take it out
Sep 27, 2007 | Fuji FinePix F470 Digital Camera
SD Card Problem
Open the card on your computer with Iso Buster. Download the free or trial version.
May 30, 2017 | Goodmans G-Shot 3021Z Digital Camera
Fuji FinePix F470 Digital Camera Logo
91 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
