Question about Technics Audio Players & Recorders
Hifi stand by light is on when switching it on it turns staight off onto stand by again
    Novelist:
    Champion:
  • 218 Answers
Sounds like it may be fried. Test the output transistors and the predriving circuit for them. Good luck.
Posted on Nov 28, 2008
Sony DHC FLX5D hifi system shows a red light near power on switch but won't start
You opened the case to check the fuses, do that again and look at the devices that resemble small cans. See if the are bulging, leaking or exploded.
Jan 06, 2014 | Sony Audio Players & Recorders
1897 Yamaha Fzx 750 runs but stalls when put in first gear. Was working yesterday...
Saftey circuit issue! check clutch switch, side stand switch and wiring these are connect to the neutral light switch and the 3 are part of the saftey circuit,
circuit is designed to cut the bike out if the stand is down and you kick it in gear also to stop the bike turning over & jumping forward when you hit the starter and its in gear and the clutch isnt pulled in.
weak stand spring my not be pulling stand onto the stand switch correctly there fore no making the curcuit, switches just make and break the curcuit.
Aug 30, 2011 | 1989 Yamaha FZX 750
When bike is sitting up right it bogs out and back fires won't stay running, but if put the kick stand and lean it to the side it clears up and runs good and when stand staight up again it starts to bog...
I would say you have problem in the tank with the fuel pump line. When you lean the bike on the kickstand all the fuel goes to the left side an covers the line which then creates enough fuel pressure to run the bike. If you filled the tank full it would probably run ok until the fuel level gets below the bad line.
Oct 05, 2010 | 2003 Harley Davidson FLSTCI Heritage ...
We've had a new fridge delivered, the Daewoo frsu20iai, how long do we need to leave the fridge standing before switching it on? Different people have told us different times ranging from 1 hour to 24...
ideally leave it for 24 hours(but it wont hurt if you switch it on staight away)the standing time is to allow any air(gas) in the system to rise to the top of the pipes.besides it gives you time to check and level the doors,so that the seals fit flat all round.dont forget to cover/wrap all food in the fridge to cut down on condensation.root veg is best kept in airtight bags.
Aug 06, 2010 | Daewoo Refrigerators
Hi i have a set of 203 JPW floor standing hifi
remove grill and approximately 6 to 8 screws hold speaker to box. Follow appropiate wiring in removal as replacement. Check crossover while you have it appart
Mar 08, 2010 | Sony MHC-RV888D Shelf System
Sony midi Hifi switching itself off
These digital amps are very prone to blow if the speaker wires are shorted so Sony appear to have put in a protection system that mutes the amp when this happens. You have to unplug the amp for a minute till the light goes off, make sure no speaker wires are touching each other and then it should work ok. I found the same problem with one I bought 2nd hand.
Feb 03, 2010 | Sony Audio Players & Recorders
Cruze conrtol
sounds like your brake switch is out of adjustment
Jan 24, 2009 | 2006 Mazda 3
Can't switch on the tv.
try to press channel button on your tv set.
Jan 01, 2008 | Toshiba CF36G40 36" TV
42 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
