Toshiba es 4511 will not print color. Copies color fine but will only print b&w
  • design468 Nov 21, 2008
    Thanks for trying Nixcroft. I had checked all of the windows settings prior to posting here.
    The latest drivers are installed. On reading the info on the driver, it was noted that they were for firmware model 4006 or later. Having checked through the function list I found that my firmware is an older version. My best guess is this might be the problem. To check whether it is an OS problem, I installed the drivers on three different pc's. XP pro, Vista 32bit and Vista 64bit. All came out thesame. Prints beautiful black and white, bur all stubbornly refuse to print color. What do you think firmware?
    Thanks again,
    Ian
    Scholar:
  • 135 Answers
Check under the printer settings in windows and check if it isnt set to print balck and white only.
normally this is the case and when something was printed and it was asked to print in black and white it defaulted to it...
Posted on Nov 21, 2008
  • Uwe Klopfer
    Uwe Klopfer Nov 24, 2008
    brwosing through sites like driverguide.com etc could supply you with an older driver version more compatible for your version of the printer...
Error f090
H
I have managed to find a description of this error here:
Error Codes Toshiba Studio 4511 Code F090
which says:
Description:- SRAM abnormality on the SYS board
Unfortunately the page doesn't give a remedy for this error as it normally does, but you can download a pdf format service manual from this site by clicking on the link near the top of the page.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 27, 2014 | Toshiba Estudio 4511 Color Printer,...
My Toshiba estudio 4511 says call service
Your CYAN is one of 3 colors the "Smart guys" came up with to make 252 some colors. Between Cyan Magenta Yellow and the ever so present Black you can make all your colors. Obviously you don't need the three C,M,Y to make a black and white copy. So the issue remains that a low or empty Cyan (pronounced S-eye-ann)
A couple differant issues I've run into since the creation of color copies near 2003 is A pull tab on the toner isn't pulled off before inserting the tube. Another is for several possible reasons the toner just isn't getting down into the developer mixing auger. There is also, upon occasion a situation that the motor that turns the toner auger inside the new toner cartridge doesn't turn enough/properly/ or at all. These days that will almost always throw a code in the display window. My 23years of Toshiba tells me try your C cartridge, play with it a bit and make sure its in right, with tab pulled. another tool is monitoring how long it tries to and the Cyan, does it attempt to restore it' levels for about 90 seconds or is it immediately tell you there's a cyan issue? Can you hear the motor and toner bottle turning? It should tell you "adding Cyan Toner" or even "Check Cyan Cartridge" worst case scenario you call Toshiba business Solutions and they vacuum it all out and do some adjustments......could be a good thing With Toshiba you get a lot of bang for your buck, meaning: a service call is good every once in a while. Your 4511 is a work horse you won't regret $pending for service. ~~~~~> SC
Sep 22, 2014 | Toshiba Estudio 4511 Color Printer,...
Donde puedo bajar el driver para que funcione
http://mba.toshiba.com/support/index.jsp solo selecciona el tipo de maquina que es osea COLOR COPIER y selcciona el modelo e-studio 3511 o e-studio 4511 y descarga el archivo, si necesitas que imprima en opcion a color baja el driver que sea PL5C y si solo quieres imprimir a blanco y negro baja el driver que termina con PLC6.
Suerte y saludos
Mar 22, 2011 | Toshiba E-Studio 3511 Color Copier
Toshiba 3511/4511 suddenly stopped faxing
Try use the monitor button for faxing, check whether there is tone or not.
Jul 08, 2010 | Toshiba E-Studio 3511 Color Copier
Department Codes
What is your email address I can give you instructions
Jun 07, 2010 | Toshiba E-Studio 3511 Color Copier
E studio 4511
check carona wires. check your optics.
Sep 18, 2008 | Toshiba e-STUDIO 4511 Printer
118 people viewed this question
jasbo
jasbo
