Question about HP PSC 2410 All-In-One InkJet Printer
Cycle Power I recently had to take my machine apart and now when I plug in the machine, I receive the error message "cycle power". I found a power cord dislodged and reconnected, but no luck. I even tried the # + 6 reboot. Any ideas?
  • Anonymous Mar 04, 2008
    same thing is happening to us. have tried new power plugs. The # 6 also and re aligned paper. Goes well for a couple of pages and then cycle power comes up on the printer screen.
  • rsteinb1 Nov 25, 2008
    Tried the # and 6 which didnt work then tried ok and cancel, the same error comes up. Any other solutions??
    Guru:
  • 79 Answers
Instead of # and 6 try
unplug the power cable, press and hold :
OK and CANCEL, while keeping them on hold put the power cable back in ... it ll do a full NVRAM reset on it ..
It ll be fixed .
Best of luck
Posted on May 27, 2008
How to cycle the power on a Samsung CP610ND?
Pull out the plug, wait five minutes, replace plug and switch on.
Jan 07, 2014 | Samsung CLP-610ND Color Network Laser...
Samsung CLP-315 color laser printer Haven't used it for a couple months. Tried last night, got "system error" message. It said to cycle power. Tried that 5 times alst night, no joy. Left...
When you cycled the power, did you just push the power button?
If so, to really do a power cycle you need to unplug, let sit off for 30 seconds, then plug back in.
Apr 22, 2011 | Samsung CLP 315 Laser Printer
Am getting FP error message on a Whirlpool 6th Sense washing machine. Have removed foreign objects from filter but still getting error message. What more can i do?
your right the error code is filer pump now disconnect power and let unit sit for 1 hr should reset its computer
dam computers
Dec 29, 2010 | Washing Machines
Receiving error message F06. The cycle stops. The only way to restart is to power off and on?
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after three minutes.
Possible Causes / Procedure
1. Verify the shipping system including shipping bolts, spacers and cables are removed.
2. Unplug washer or disconnect power.
3. Check wire harness connections between the drive motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU).
4. Plug in washer or reconnect power.
5. Check the MCU by looking for operations of the drive motor.
6. Check the drive motor for powered rotations.
Replace failed component.(Motor Control Unit)-(MCU)
Sep 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Model c6180 printer gives improper shutdown error
The printer is not getting enough power. When you get this error message it means the printer is being turned off by unplugging the power cord. In this case it maybe that the printer is not getting enough power due to being in a surge protector or perhaps the power module is no longer holding power correctly.
First step is to disconnect printer from any power strip, surge protector, or extension cords and plug in so directly to the wall. If printer still will not stop looping cycle you may need to contact hp for a new power module.
Sep 25, 2009 | HP Photosmart C6180 All-In-One InkJet...
Keeps flashing SE
I recently had this happen but with no error message on my model, the rinse symbol just kept flashing and nothing was happening. I tried running a spin cycle or rinse and spin. The rinse & spin started but stopped when it got to spin. I finally determined that the water was not draining out. I ended up emptying a bucket and a half of water out of the emergency valve near the floor (which spills water everywhere) and found a lint ball that was plugging it. After this I tried running just a spin cycle and it worked.
Mar 30, 2009 | Samsung Washing Machines
Intermittant trouble with code d 11
Answer Duet HT®
Duet®
duet_f_dl_actualsize.gif Duet SportTM
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
fl_doorseal.jpg To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and all of the other conditions above have been checked, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite He3t front load washer - error code reads H & F
the F code is a puwer outige. This is how to fix
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN & SPIN if there is excessive water in the washer.
Re-select cycle and press START. If the problem remains, call
for service.
This is what an HF code is.
"FH" (Water Inlet Problem--no water or insufficient water
supply)
Select PAUSE/CANCEL twice to cancel the cycle. Unplug
Check the following:
Are water faucets completely turned on?
Are screens at inlet hose connection to washer clogged?
Are water inlet hoses kinked?
Are water inlet hoses frozen?
Plug in washer or reconnect power. Re-select cycle and press
START. If the problem remains, call for service.
Dec 15, 2008 | Kenmore Elite 45986 Front Load Washer
Fax and cancel lights are flashing
I found this solution at HP website. It worked for me. Good luck!
A Scanner Bulb Error message is received as a result of the HP LaserJet 3300mfp series product scanner’s inability to find the home reference point.
SOLUTION:
Perform the following steps to walk the scan assembly from the home base and resolve the issue.
1. Remove and replace the power cord from the unit.
2. Wait approximately 35 seconds for the scanning assembly to “walk out" and then quickly remove the plug again.
3. Repeat steps 1 and 2, three to four times until the head moves approximately 1 inch away from its normal resting place.
4. Replace the plug and let the product fully finish the boot cycle.
Oct 08, 2008 | HP LaserJet 3330 All-In-One Printer
HP PSC 2410 All-In-One InkJet Printer Logo
307 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
