Question about Intertherm Heating & Cooling
My gas furnace that came with the Mobile Home I just purchased will not ignite the Pilot Lite. All valves from tank open, followed instructions. No Spark
  • va7sr Nov 21, 2008
    Thanks
    I have no other Gas Apps, but I will keep trying to lite it. Will take time the auto shut off kicks in after about 20 sec. Wait 5 min. between tries. Thanks for your speedy reply.
  • va7sr Feb 12, 2009
    Sorry for the delay, but I got it working. Some ********* removed the ignition switch.
  • 828 Answers
Try lighting all other gas appliances first. On a new setup air in the lines between the tank and the furnace takes time to bleed out before the gas reaches the pilot light.
Posted on Nov 21, 2008
Getting the heater to lite
Could be a multitude of causes. Here are a few common ones.
Igniter electrode dirty or corroded.
Igniter misaligned.
Failed circuit board.
No power to furnace.
Time delay switch defective.
Sail switch defective.
Overheat switch open/defective.
LP gas valve not opening. Check electrical connections before replacing valve.
Failed to purge system after storage. Light the stove and let it burn for a minute.
Manual LP valve (close to furnace) not opened.
Valve on main LP tank not open.
LP tank empty.
Feb 17, 2014 | RVs
When the heat cycle calls for gas there is no ignition is my gas valve bad?
I don't know what kind of furnace you have. But most furnaces have some sort of pilot first than after it is proven than the main gas will come on. Either a standing Pilot with a thermocouple. A hot surface ignition or Spark ignition with a flame sensor. Or a direct fire system where hot surface or spark ignitor start first than all the burners send a 1 sec blast of gas which is proven by the flame sensor if it proves the gas valve stays on.....
In what you have said you have 24 volts to the gas valve and it has not lite. then does the gas valve have a pilot tube???Does it have a thermocouple?? Do you smell gas?? If you don't smell gas then the main part of the valve has not opened. The Pilot valve has to open first and prove before the main gas will come on. I hope this helps. If you still need help repost with the name and model # of the furnace.
Nov 18, 2013 | Honeywell Furnace Gas Valve Sv9501h2409
How do I light the pilot
1) Open following link to identify type of gas control and read printed 'how-to-light-water-heater' instructions for each different gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
2) Same printed instructions should appear on side of tank by gas control valve, and inside product manual.
3) Add a comment March 2013 and describe gas control valve.
Mar 13, 2013 | Reliance & 40 Gal Mobile Home Water Heater...
Why does pilot light turns on gas burner only to have it go out about 10 seconds later? 30 to 40 sec later repeats,without lighting. What is problem? once in awhile, it will light..not often. The burner...
Hello
Sounds like the thermocouple is going bad.The thermocouple is a thin tube that runs from the pilot lite to the gas valve.
What it does is it sences the heat from the pilot lite and keeps the gas valve open to allow the pilot to stay on.
This can be easily repaird by shutting off power and gas to your heater and removeing the thermocouple from the gas valve,then unclip or unscrew it from the pilot lite area.
Any plumbing supply store or home depot or lowes should have these.
Once you get a new one,install to gas valve and pilot lite area then turn on power and gas to heater and follow pilot lighting procedure,you may need to hold gas on for 60 seconds.
Here is a picture of the thermocouple so you know what to look for.
http://thermocatalytic.com/Thermocouple.JPG
http://homerepairgeek.com/wp-content/uploads/2010/12/furnace-thermocouple.jpg
Feb 10, 2011 | Honeywell Programmable Thermostat Heater
Pilot light on furnace went out. how to i re-ignite?
I have experience with coleman furnaces installed in mobile homes. There is a red switch on the gas valve. Some models require you to slide the red switch to the top and hold. Holding is allowing gas to the pilot. You have to stick a long match,grill igniter, to stick through the inspection hole (a little flap or door to see inside the burner area) and hold the match over the pilot while holding the switch upwards at the same time. Others have a pilot selection on the gas valve which you slide the red switch to pilot and push down and hold while liting the pilot. You may need help with holding the door open while doing this. If you can you can use the copper line for the thermocouple to hold the door open for you. Good luck
Jan 15, 2011 | Coleman Heating & Cooling
Gas Furnace Will not light
Hi, normally when you turn the gas off at the flex line valve and leave it off for awhile, the gas has to clear the gas valve and lines up to the pilot. Purge its self of air before it will light again. It will take the electronic ignition several clicks and more before there is enough gas to light the pilot and then open the main gas valve to fire the burners. Tell me, what kind of gas furnace is this when you speak of water? you say the site glass was full and you had to drain it and then the ignitor kept on clicking when it normally only took one click to light it. Please let me know the style as in a split system, a package unit, all in one, or what you have. I will wait to hear back from you. If the pilot does not light right away, then yes let it continue to click and see if it will light. On a heater with the electronic ignition control module on it or a circuit board, this is what tells the pilot coil to energize to light the pilot. It will send power to the pilot coil to open and let gas through to light and same for the main gas valve, will get a signal to open when the pilot is on. It will not open unless the pilot is lite for saftey. I will wait for you're responce.
Shastalaker7
Nov 27, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
Heil 75kbtu gas furnace 80% efficiency installed winter 2004-2005 timeframe. the exhaust fan comes on and the green lite on the valve flashes green but the unit wont fire. a service tech asked if the pilot...
if it has a pilot, you can follow the pilot tube from the gas valve back to the burner assembly and find it. It may not have one and if this is the case, the air flow switch is supposed to close when the inducer fan comes on . If the flue is clogged, condensation in the bottom of inducer fan(would hear cracking). then after the draft safety switch is closed,the gas vavle will get 24 volts and allow the gas valve to open
Oct 27, 2009 | Cross Furnace Draft Inducer Blower 115...
Lighting the pilot light
The steps involved can vary slightly depending on your furnace model and pilot valve type, so if possible try and find the instructions inside the furnace door cover or in the instruction manual. This is for a gas fired furnace, but applies to any gas-fueled appliance including water heater. Two of the most common types of pilot valve body assemblies either have a red reset button and a gas valve or no reset button and a valve knob that can be depressed. But whichever type you've got, if you have an older model furnace with a standing pilot (flame is lit all the time) then this is the basic procedure.
  • Turn you thermostat to 80 degrees or to a setting that will demand heat. Make sure the thermostat is in "Heat" mode.
  • Go to the furnace and find the pilot valve. The pilot valve body is a box shaped device into which the main gas line will run and is located near the gas burners. It will usually have a gas **** or valve knob that reads "On, "Pilot" and "Off." Locate this gas **** or knob.
  • Turn the knob or gas **** to the "Off" position and wait about 3 minutes for any residual gas to clear away.
  • Find the pilot. It's located near the gas burner tube assembly in the furnace.
  • Get your match or lighter ready. Sometimes the pilot is hard to reach. If possible, try and use a long fireplace match when you light it. If you don't have a fireplace match then a butane BBQ grill lighter works well too. If you don't have that, then you can fasten a match to the end of a stick when you light the pilot
  • If you have a pilot with a red Reset button, turn the gas valve from "Off," to "Pilot."
  • If you have a pilot with no red button, turn the knob from "Off" to "Pilot."
  • Place the lit match or ignited lighter tip at the pilot and depress and hold the button or depress the knob as appropriate. Depress the button or knob for about 30 seconds. This maintains gas flow to the pilot until the thermocouple gets hot enough to open the main gas valve.
  • Once the pilot stays lit, slowly release the button or knob and turn the gas **** or knob from the "Pilot" position to the "On" position. This will ignite the burners and keep the flow of gas supplied as required for the burners as called for by the thermostat.
  • If the burners fail to ignite then it may be because the thermocouple did not get hot enough to open the gas valve. Wait a few minutes and then repeat the above procedure. This time hold the red reset button or depress the knob for about 45-60 seconds.
  • Once the main furnace burners ignite, adjust the thermostat to the desired setting.
  • If you've followed the previous steps on lighting the pilot and it still does not light after, or will not stay lit, then you probably have a problem with the thermocouple or an adjustment needs to be made to the pilot. You'll need a furnace service technician to replace or repair these parts. You may find that the pilot lights, but it is an anemic looking flame. That's a different problem we'll look at in the next section.
  • If the pilot lights but the flame is a weak yellow flame, it will not get hot enough to heat the thermocouple to its set point allowing the gas valve to open.
    A natural gas flame should be a bright blue with the tip of the flame having just a tinge of yellow. A propane flame should have a bluish green flame with a tinge of yellow at the tip. The flame should be strong enough to hit the thermocouple tip about 1/2 inch from the tip end. If the flame is weak or shaky looking, check to see that a breeze or draft is not blowing on it. Adjusting the Flame
    There is usually a small screw on the pilot valve body that will adjust the flame. You may have to refer to the manufacturer's instructions to find the screw. Turn the screw as needed to adjust the flame throw. Yellow Flame
    A yellow flame is caused by lack of air and incomplete combustion. It can be caused by a dirty pilot tube tip. Split Flame
    This is caused by dirt in the pilot tube. Take a needle or small nail and gently clean the tube. Flickering or Wavering Flame
    A flame that flickers is usually caused by a draft.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 18, 2009 | Water Heaters
Furnace gas pilot light keeps going out when windy outside
Honeywell makes an electronic ignition conversion kit. (White rodgers also has one but it uses a mercury switch which can be expense if it goes bad). A good service man can install the "Honeywell Y86 Universal Intermittent Pilot Retrofit Kit". This is a "complete" kit for converting a standing pilot system to electronic ignition. It includes a new gas valve, ignition cables with connectors. ignition module and a pilot assembly. It does not include pilot tubing (pilot tubing is cheap). This kit also comes equipped for either natural gas or propane. Your heating guys probably don't know about it because they are to young and not familiar with the old days. Or they just don't care and would rather sell you a furnace. I think that they just don't care. I live in Ohio I just opened up the "new" Johnstone Supply catalog. This part is "not" outdated its on page 450. Do not let these heating guys buffalo you into a new furnace. You are to smart for that! If you weren't you would have believed them and bought something you don't need. Instead of researching on the internet.
The bad news is this kit lists for $456. plus labor.
Nov 20, 2008 | Heating & Cooling
Heating & Cooling Logo
171 people viewed this question
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
