Question about GE Spacemaker JVM1640SJ Microwave Oven
Will not heat food
Everything run but food will not heat up
  • 10 more comments
  • falaise Nov 22, 2008
    will not heat food
  • joelniego Nov 23, 2008
    everything works but it will not cook the food
    the model number is jvm1650
    spacemakerxl microwave oven
  • Larior Nov 26, 2008
    Model JVM 1650WH01
    manufactured Jan 2005
  • jlambeau2 Nov 28, 2008
    we have the GE Spacemaker model JVM1631WB 002
    everything runs but no heat
  • Anonymous Nov 29, 2008
    ge spacemaker oven doe not heat up but everything else works normal. Only 4 years old. Never been used for extended cooking. Makes a quick noise at start up then goes away.
  • GILLIL83 Nov 30, 2008
    HIT BEVERAGE BUTTON. MICRO RAN, THEN BUZZZED, THEN STOPPED DEAD. NO LIGHTS, NOTHING. CALLED GE, THEY CAME OUT AND FOR $234 CHANGED THERMOSTAT. THEY LEFT AND 15 MINUTES LATER, WE TRIEED TO WARM FOOD. NO HEAT. EVRYTHING ELSE WORKS, TIMER, LIGHTS, FAN, BUT NOTHING HEATS UP INSIDE THE OVEN
  • Anonymous Nov 30, 2008
    Exact same problem
  • jenok Dec 03, 2008
    Everything comes on, turns, but it will not heat the food. It does sound louder than normal. The model is GE Spacemaker XL JVM132OWB.
    Any ideas would be appreciated. Thanks. Jen
    email johnathon0302@yahoo.com
  • pravind_souz Jan 03, 2009
    I have a Panasonic microwave, the problem is when i start it it would blow the fuse within 2 seconds. When i set the time and start it will blow the fuse in the microwave.
    Model: NN 6358
    Input : 240- 50hz
    output: 2450hz
    700w
    6.0 amp
    type: S-472H
  • rthomson Jan 10, 2009
    My GE Profile Microwave oven seems to be working...light goes on, turntable turns but food does not heat up?
  • kmwnky May 11, 2010
    How do I check the relay mentioned in solution? How do you fix a faulty magnetron?
  • William Miller
    William Miller May 11, 2010
    When you hit Start to cook, do the inside light and turntable come on?
    Any unusual noises? Is it louder or quieter than usual?
    Do you have the model number?
    These answers will help me judge whether it's in the high voltage
    section (magnetron, transformer, or diode) or the control section
    (door switch or control board relay or connection).
  • 67 Answers
Check the relay that switches on the high voltage transformer or you have a faulty magnetron
Posted on Nov 25, 2008
My samsung microwave oven is not heating up food. It works normally, lights on, food turning on plate, but not heating the food.
if your microwave does everything you have described , and you can hear the cooling fan running as well after you press the start button , you probably have a faulty wave guide. The wave guide is also called a Magnetron Tube. It is the main part of the microwave which produces the microwave energy . If this part is not functioning it is best to replace the entire unit, rather than have it repaired .
Oct 03, 2010 | Samsung Microwave Ovens
Microwave will not heat food everything else seems to work, timer, rotating plate everything works but heating food
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
=0=0=0=0=0=0=0=0=0
Sep 14, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
The microwave won't heat the food. Everything is running except and the lights are on but the food is still cold.
Seems like you have a bad magnetron and it may need to be replaced or you may just want to save yourself the hassle, and get a replacement. Hope that helps.
Nov 10, 2009 | GE JVM1650 1000 Watts Microwave Oven
Microwave runs but food does not heat
If everything appears to work as normal but does not heat, then the magnetron will be faulty. This is the device which cooks the food, however this can be an expensive part to replace & may not be economical to fix.
Sep 23, 2009 | General Electric Microwave Oven
MICROWAVE IS NOT HEATING FOOD
I did more research along with the suggestion of an apprentice to have person to fix the microwave. I was unable to fix it myself. The microwave needs a magnetron .
Feb 03, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My micro wont heat the food but everything else seems ok
I have a GE Spacemaker Microwave, model # JVM1650WB008
The lights work and everything runs in a normal operation, it will not heat the food. I have changed the fuse and still the same, no heat.
Oct 05, 2008 | Microwave Ovens
Microwave won't heat food.
built in 3/94 is it worth fixing how much for magetron
Dec 30, 2007 | Maytag MMV1153A Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
122 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
