Question about LG WM-2277HW Front Load Washer
My laptop cant find the harddisk
I have formated, fdisk ntfs file system and fat32 file system but it never can find the harddisk
    President:
  • 1,073 Answers
Explain your problem in swedish and i may help you.
you cant format both NTFS and Fat32..its either NTFS or Fat32.
But as i i told you above, explain the problem in swedish and i will try to help you.
Posted on Nov 21, 2008
I've dual booted win8 with linux, to remove i used "easyBCD" to restore MBR, and deleted the partition. the deleted partition was lost and my harddisk capacity (showing as online) reduced to 300gb fro
erase your drive and deallocate and repartiton your whole drive using fdisk(windows) or utility softwares like killdisk
also one thing is to be noted that Linux systems recognizes the windows fat32 and ntfs partitions but windows doesn't recognize file systems like ext4 or swap which are the prime type of file systems partitions used in Linux systems!
May 31, 2014 | Computers & Internet
Why does Fdisk assign FAT32 file system to the Drrive after partitioning it to extended logical drive?
Fdisk creates, deletes or change a partition on a hard disk and then you need to Format the hard disk so it can be used to store data.
Fat32 is a format file system and it is used when you want to read and write data between a PC and MAC computer.
If you only want to use the hard drive on a PC and using windows XP, Vista or Windows 7 the format the hard drive using NTFS not FAT32.
Aug 30, 2012 | Computers & Internet
What format should I chose to grab it to a PC?
This will depend on which type of computer and operating system you have
if you are referring to formatting your hard drive to a specific format file system NTFS or FAT choose the Ntsf file system is more secure Ntfs is more powerful than Fat or Fat32 and includes features required for hosting Directory as well as other important security features . You can use features such as Active Directory and Domain - based security only by choosing Ntfs your file system Its easy to convert Partitions to Ntfs . The set up programs conversion makes it easy whether your partitions used Fat or Fat32 or the older version of Ntfs .This kind of conversion keeps your files intact (unlike formatting a partition). If you do not need to keep your files intact and you have a FAT or FAT32 partition, it is recommended that you format the partition with NTFS rather than convert from FAT or FAT32. Formatting a partition erases all data on the partition and allows you to start with a clean drive.
hope this helps you
Sep 03, 2011 | Computers & Internet
My 1.5 tb mybook has been formatted to fat32, and i cant watch movies on my ps3 no more loads up files really slow even freezes. Also disappears on my laptop sometimes then reappears. But transfers and...
FAT32 was the file type used for the early Windows operating systems. With the release of Windows NT and XP it switched to NTFS file system. FAT32 is still used however to transfer data between Mac and PC. The downside of FAT32 is the files read slower and file size cannot exceed 4GB. If you do not use a Mac I would suggest using the Disk Management utility in Control Panel under Computer Management to convert it to NTFS.
Mar 16, 2011 | Western Digital My Book Essential Edition...
Aspire 6930 has 320 GB harddisk,i faced some problem with Avasti Antivirus n i formatted the system to run my system smoothly, but now the problem is harddisk is showing only 128 GB. that too the partition...
You can Reformat the system and REMOVE all partitions. Windows setup will create a new partition from available drive space. If you need to save your data,You can also use a utility like partition Magic and resize the partition. There is a trial version available at no charge. just google "partition magic"
Aug 05, 2009 | Acer Aspire 6930-6771 Laptop
Reformat my external drive to NTFS
The only risk associated with file formats is that a drive formatted with FAT32 file system will not see NTFS formatted file system, whereas, a drive formatted with NTFS file system will definitely see FAT32.
To make it clearer, this means that, if on your system, your hard drive which is having the operating system installed on it, is formatted with FAT32 file system, and you bring an external drive, or even a backup drive which is formatted with NTFS file system, and you plug it to your system, the system will detect it but it wont be able to access the full drive capacity, you will just see it in the device manager page that it is connected.
But If it is Vice-Versa, the NTFS formatted drive will detect the FAT32 drive.
Now in your own case, if your system is formatted in NTFS file system and you plug in your external drive which is NTFS formatted also, from what you have said, I suspect that you have some hidden partitions on your harddrive (the 250GB), so when you plug it, try and do this, Right-Click on my computer icon, select manage, then go to Disk Management Option.
On the Disk management option Page you should see ALL the drives installed on your system, including the hidden ones, so what you will just do is, try and locate the one representing your external drive, and right click on it. then select "Change Drive letter and Paths", and give the drive any new, unique letter (i.e alphabet) different from the ones already on your system, and click on OK.
If you see any other hidden drives there, do the same thing to it.
This should make your External Drive to be detected automatically.
Hope this helps you out.
Jul 15, 2009 | Western Digital My Book Essential Edition...
Recording stops within 10 minutes
Hi G-DyBiec
If the video capture automatically stops capturing at approximately 18 minutes (17 minutes and 55 seconds), then most likely the drive that is being capture to, is formated using Microsoft's FAT32 file system. Microsoft's FAT32 file system has a maxium file size of 4 GigaBytes (4 GB), which equates to a DV video clip of nearly 18 minutes. (18 minutes = 1080 seconds, @ a data rate of 3.6 MB/sec is approximately 4GB). So for hard drives that are formatted using FAT32, this behavior is normal. This is not a limitation of Studio..
To see what file system your hard drive uses do the following:
1. Right click on the Start button and choose Explore
2. Under My Computer, locate and highlight the drive you are capturing to
3. Right click and select Properites
4. On the General tab, towards the top, it will say "File System". It will be listed as either FAT32 or NTFS.
There are a few solutions if your drives are formatted using FAT32:
  1. Convert your FAT32 hard drive to NTFS *
  2. If you can copy any important data from this drive to other drives, it may be faster to re-format the FAT32 drive using the NTFS file system. **
  3. You can do multiple 18 minute captures and string them together in the Edit mode of Studio.
    • Since the first 18 minutes is already captured, rewind the camcorder or VCR to 5 - 10 seconds before the initial capture stopped (which can be edited out later in Studio).
    • Start a new capture to a new file name.
    • Repeat this process until all the desired video is captured from the tape.
    • After all the files have been captured, go to Edit and assemble the captured files from the Album to the timeline in the order you desire.
This is a manual method to workaround Microsoft's FAT32 file system and if this is too time intensive for your needs, then steps 1 and 2 above may be more suitable and should be considered.
* Note: If you need assistance with step 1 above, go to the Microsoft web site at http://www.microsoft.com/ and search on "convert FAT32 to NTFS".
** Note: If you need assistance with step 2 above, go to the Microsoft web site at http://www.microsoft.com/ and search on "how to format a drive in XP".
NOTE: Microsoft's NTFS file system is only supported on Windows 2000, Windows XP and Windows Vista. NTFS support a file size of 4 TB (terra bytes), which is larger than any current consumer hard drive capacity, so if NTFS is used, the capture file size will only be limited by the size of the hard drive.
Aug 13, 2008 | Pinnacle Dazzle DVD Recorder
I am unable to format my Maxtor One Touch III 500gig External Hard Drive. Once i get to 100% using ms disk manager, a message box pops up saying that it was unable to format the hard drive. In linux when i...
If it shows up in windows explorer as a drive, right click it and choose format and choose ntfs as the file format.
Do you know what format it is when you use linux? I dont think you can use a dos command to format an ntfs volume. Your message probably means it cant read FAT or FAT32 because it probably already is NTFS file format.
Mar 22, 2008 | Computers & Internet
Format a gateway hardrive
insert a windows cd...boot from it and format the drive.
Nov 19, 2007 | Microsoft Windows 98 for PC
IBM Netvista 6059 - Can't upgrade to windows XP
Right well XP Pro really MUST be formatted with NTFS only... I suggest you get a third party partitioning program like Partition magic and completely remove the partition & redo it all again & this time Format NTFS. Or if ya have a WIN98 boot disk, and ya can use FDISK, Delete ALL partitions, and remake them again, using all the disk space, then format as NTFS, then proceed as below Then using your windows XP PRO setup Disk, start the install ...then when asked about where you want the install located, select C & REFORMAT it AGAIN with the windows setup using again NTFS file system... this should finish & then the Install should "see" your entire hard drive and format it accordingly and then when finished you can proceede to install XP.
Sep 04, 2007 | IBM NetVista PC Desktop
LG WM-2277HW Front Load Washer Logo
41 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
