Question about LG LRM1250 Microwave Oven
No heat in microwave oven
How i can check capicitor of microwave oven
  • Anonymous Feb 09, 2009
    light turns on turntable turns but it just does not heat
  • LG Master
  • 9,098 Answers
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
Here is a link you or someone you know can use to test it, but please read the safety info:
Posted on Nov 23, 2008
My Kenmore elite built in microwave oven model 790 488 03100 has stoppped heating what can i do
It may be a bad fuse or capicitor. I have had a time in the past with something similar. I contacted Repair They were very helpful with their advice and even followed up to make sure I got things fixed okay.
Dec 09, 2014 | Kenmore Microwave Ovens
use the common sense,clearly, logically, and fix it .God bless you
can take some time. This is where you must be able to read a wiring diagram and do some "live" checks on parts. First easy check is to make sure power is coming off your control board at the MW relay. Make sure of the wires and test here, if you have 120 volts at this point, you have ruled out a lot of parts that could be the problem. You have now ruled out any switch problems, control board problems, or a thermostat or 2.If you do not have power from that MW relay on the control board, you must trace the wiring back to see if the proper voltage is going through your switches, any thermostats, and arriving at your control board. Your wiring diagram on your sheet will show you where and what to test. Below is a general switch test troubleshooting guide.
mwswitchtest.jpg mwswitchtest2.jpg If the proper voltage is coming into your control board and you are not getting voltage at the MW relay, then you need to replace the control board. If voltage is interupted by a thermostat or switch from your testing to the control board, then replace that part.Now, testing from the MW relay on to your transformer, high voltage capacitor, magnetron, and diode. Do not do any voltage reading from the secondary side of the transformer on, this can be a deadly microwave oven repair if you do not follow directions. This can result in electrocution and the "blowing-up" of your voltmeter, only do OHM testing with the power off and the capacitor discharged. Someplace in this circuit, usually before the transformer, you will have another thermostat to test. It is usually mounted on the magnetron. Do a quick OHM test to see if it is open or closed.
Now to test either the transformer, high voltage capicitor, magnetron, and diode, you must test each part separately. A good rule of thumb, if your capacitor is bad, change the diode also. Another note, if you are working on an OTR model and you have determined to be one of these "heating" circuit parts, you can not test these parts until you take the unit down. If you don't have the parts with you and you have to order them, order the magnetron, capacitor and diode and you will have a 90% chance of solving the problem. If it is an older microwave, order the thermostat also, most times you can return un-used, un-opened parts. Check with your parts supplier. This way you only have to take the unit down once.
To test these parts, scroll down this page and you will see a chart with component tests. Follow the instructions to find which part(s) are defective in your microwave oven repair.
Aug 02, 2012 | Kenwood Microwave Ovens
No heat coming from Microwave oven-GE Spacemaker Model XL 1800
in the microwave there is a part which produses the heat which will be called as magnetron you check that part.
Aug 07, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave keeps blowing the fuse upon hitting the start button
you have one of three problems (H.V. diode shorted or leaky, H.V.capicitor shorted, or the magnrtron tube is beginning to draw excessive current)if thats the case its not usually worth spending that for the mag.,the other two items aren't that expensive
Jul 23, 2009 | Magic Chef CMV1000B Microwave Oven
Microwave not heating...power going to it...turntable runs, lites heating
If you have the experience with discharging a capacitor and you have a (VOM) Volt Olm Meter. Unplug microwave, discharge capicitor, and check the resistance of the two thermal cut-off discs by removing the lead and set VOM to RX1. If you don't get a reading of zero, replace the discs. If you found any of these suggestions helpful, please rate my solution. D. Lange
Apr 26, 2009 | Microwave Ovens
Microwave not heating food. What should I chedk?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
Apr 10, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Monitor Switch Part Number?
They might be referring to a diode connected to the big silver capicitor and screwed to the case.
These can go short circuit causing the fuse to fail.
Mar 16, 2009 | Microwave Ovens
Turntable stop working along with microwave and convection oven
would be a door micro-swtch sharp part # Sharp Part Number: QSW-MA085WRE0
Jan 07, 2009 | Sharp R-1405 / R-140 Microwave Oven
My GE Profile Convection Microwave Oven - Convection not working
Dec 02, 2008 | GE JVM1790SK Convection/Microwave Oven
No Heat
ALL functions work.... just no heat? Is that right? I am assuming that the control (computer?, relays?) ARE supplying power to the magnetron.
IF everything checks out as you say, is the magnetron filament O.K.? (You have to disconnect it from the transformer to test it.)
If the magnetron transformer draws 8 amps, it sounds like it's O.K. cause if it was shorted, it would blow a fuse, and if it was open, it wouldn't draw ANY current.
Check it out, tell me more and let me know. No heat means the Magnetron isn't working.
Mar 30, 2008 | LG LRM1250 Microwave Oven
LG LRM1250 Microwave Oven Logo
151 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
