Question about Zanussi Washing Machines
Door rubber for Zanussi Jetstream Excel 1200
Had to take the door rubber off to clean the drum. The door rubber is a right sod to get back on - I can get it on without the spring retainer but then can't get the spring on. Seems impossible to get rubber + spring on at the same time.
Thanks for any help.
  • Zanussi Master
  • 3,463 Answers
Hi.
It is a sod to get the spring on .
Make sure the rubber is on securely, and then gradually feed the spring round the rubber starting at the top.
It will get more difficult the further round you get, If you can get someone to hold the spring for you when part way round, you will get it on.
You can also try stretching the spring, which will make it easier to get on .
Good luck.
Posted on Nov 21, 2008
Zanussi fl 1084 washing machine door seal. How do I replace the rubber seal?
the seal comes in a shrunken size use a hair dryer to stretch it on to the door lip
Dec 03, 2013 | Washing Machines
Zanussi jetstream 1000 turbodry door remained locked this morning. Emptied machine through filter port and cleaned filter. Door opened ok. Machine will now not start any program although the power light...
the drain pump is jammed .........remove the filter at the bottom left of the machine get down and look in the hole and you will likeley find something in there if not you need a new pump
Feb 26, 2010 | Zanussi FJS1225W Front Load Washer
Horrible scraping noice when drum rotates
YOU WILL NEED TO REMOVE DOOR SEALING RUBBER WHICH SEALS THE TWO HALFS OF THE DRUM THIS WILL ALOW YOU TO REMOVE SAID OBJECT
Dec 28, 2009 | Washing Machines
Jetstream 1200 wont take away fabric softner
strip and clean out the soap tray then remove the tray and clean the fill water holes above it with a stiff washing up brush.
Mar 16, 2009 | Zanussi ZWF1430W Front Load Washer
Noisy during some parts of the cycle
it could be the concrete ring situated at the front of the machine. i had the same problem with mine 2 years ago.
Jul 29, 2008 | Zanussi FJD1266W Front Load Washer
Door seal replacement
This video will show you how to change a door seal on this Bosch classics 1200 WFL 2463GB/12 FD
Jul 24, 2008 | Washing Machines
Door gasket seal
its a sod. it clips over the lip around the drum. belive me when i say i no techs who struggle with this. its each to there own way im afraid
Dec 30, 2007 | Zanussi ZWF1430W Front Load Washer
Door wont open
Either clip on the door is faulty or its the door interlock in which the door locks into easily replaced by undoing the clip pullling back the door rubber and replacing ..
Dec 23, 2007 | Zanussi FJS1225W Front Load Washer
Opening the door
Have you tried to disconnect it from power mains for a few minutes to see if that will reset the security timer?
Dec 05, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi aquacycle 1200
May be the Bearings.Open door and try moving drum, hold at top of drum and pull foreword and back if drum loose main bearings gon. Replace bearings.
Slim Jim
Oct 28, 2007 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
129 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
