Question about Music
Problems with amp switch
I have just bought and amplifier but the front switch is faulty. there are 4 wires going into the switch: brown and blue from the mains and red and black going to the transformer if i was to bypass the switch what colours would i need to join? i know that blue is neautral and brown is live but am unsure what the black and red are??
Cheers
  • 51 Answers
Get an ohm meter and test to a known ground, like the sleeve on the guitar cable. If neither is grounded, it doesn't matter. If one is grounded, take it to neutral.
Best bet, get the same switch and put it in exactly like the one you have.
Posted on Dec 02, 2008
Bought amp with no footswitch
The schematic shows it as a standard 1/4 inch stereo plug. Wire the ground common to both switches (Channel and DFX), the ring to one switch and the tip to the other...I.E. ground (sleeve) to ring for one switch and ground to tip for the other. You'll have to experiment with which switch operates what function and label them accordingly.
Nov 02, 2012 | Marshall MG100HDFX 100-Watt Amplifier Head
Marshall mg hdfx100 power switch fell off, is there a way to turn it on without the switch
power switches are pretty easy to replace, i have the mgdfx50 and its only 4 spade connectors, 2 blue and two brown, doesnt have to be a marshall, just a 4 pole switch from an electronics store
May 24, 2012 | Marshall MG100HDFX 100-Watt Amplifier Head
I recently bought hartke a100 and it makes a sound quite bigger than normal bass amps does when i switch it on . same thing happens when I swith it off.The sound comes up along with a blue beep on top of...
The amplifier takes a bit of time to come to DC balance and same thing happens as power goes down. Some fancier units will have a relay to disable speaker until balance occurs, but this one does not. As long as the cone centers within a couple seconds it will not cause a long term problem.
Sep 05, 2011 | Hartke A100 Combo Bass Amp
I bought a factory refurbished xga-3000 gemini amplifier and conected it to my behringer mixer expecting a thump. but it barely sounded like a sound of earphone at maximum volume. I read power supply to...
A large amp like this likely has protection circuit (probably a relay) that doesn't connect the speakers until the amp is stable and balanced. You relly need the schematics for the amp.
Jun 21, 2011 | Gemini Sound Products GEMINI XGA 3000 3000...
THE POWER SWITCH ON THE FRONT OF MY GX5 IS GOING BAD, AMP IS LOSING POWER, STARTS WORKING AGAIN WHEN I FLIP THE SWITH ON AND OFF.
A lot of the rocker switches fail due to starting surge of these amps. You can try squirting a little CRC226 into the back if it has holes. You can get this product at Home Depot in the electrical dept. Use ONLY this product. Blue can about $2.70
If that doesn't fix it, then replacement of the switch is in order.
Mar 26, 2011 | QSC GX5 Stereo Power Amplifier
TH-15A won't make sound. Comes on, then flashing front light
This probably means there is a failure and the internal protection circuits have activated. It will probably have to go to a shop for repair.
Jan 03, 2011 | Mackie ProFX8 / TH-15A PA Package
Wiring diagram pignose 7-100 guitar amp which wire goes where?
There are a couple thumbnail sketches of the diagram at:
http://music-electronics-forum.com/t8790/
They are down about 3 an 6 of the blogs.
Nov 29, 2010 | Marshall Amplification Marshall Mini Stack...
Amp wont turn on, but i hear a pop when turning off
first off nothing should pop when turned off next it could be a grounding problem external or internal or worse an audio output problem take a volt meeter and turn key to on check the ground and positive on the amp should read 12 to 14 volts do same with ground and remote wire if these both read correct remove the back set your meeter to the diode setting the audio outputs are usually the larger ones but sometimes not take your leads and touch out side legs then to the outside to center try each one every way you can switching leads if at any time the buzzer stays on or goes to flat 0 then that output is bad if all check good i would go through the car making better connections and cleaning up any wires that might seem to be faulty maybe even replace your RCA cables
im running 18 speakers and 8 amplifiers in my car and i have done this several times :( but i don't pop unless something is wrong hope this helps
Jul 24, 2009 | Line 6 Spider Iii 30
SPEAKER OUTPUT CHANNEL FAULTY, TWO MIKE CHANNELS DOWN
These are a real pain to open. You have to remove the front panel to remove a shield to remove the back amplifier power supply area. The power supply is a switching type and has lethal voltages present. Working on this should be done using an isolation transformer. With your symptoms, it is likely one side of the power amp MAY be blown, but do check that the wiring hasn't fallen off and the jack itself. Two pairs of wires come from the power amp to the front panel jacks. document location of ALL the cables you disconnect as they CAN be confusing to restore.
May 13, 2009 | Fender Passport Deluxe 500watt Sound...
Music Logo
61 people viewed this question
Top Music Experts
Michial Gueffroy
Marvin
Marvin
Are you a Music Expert? Answer questions, earn points and help others
