Question about GE 24 in. GSD2000Z Built-in Dishwasher
Dishwasher will not go through cycle
My dishwasher will come on and some water comes on but it will not go through the cycle at all. it just hums and nothing else. are there any solutions to this problem?
  • SoxFanFL Mar 30, 2008
    My GSD2030 dishwasher runs, but the dial does not advance. It hums very loudly, and very little water comes thru. Even moving the dial to another setting doesn't help..(short wash, rinse, etc.). Help!
  • bfulks Jun 28, 2008
    My dishwasher started running water in, stopped and hums. The dial goes around but it doesn't finish filling w/water and it doesn't wash the dishes.
    President:
  • 878 Answers
Prettyb, sounds like the pump is stuck, read the following post. http://www.fixya.com/support/t127034-dishwasher_not_cycle Catriver..post back
Posted on Jan 03, 2007
Hobart dishwasher wont fill and motor hums
Hi SubaruB4
it may be the electric valve where the water comes in if it doesn't open when switched on water wont enter
Dec 26, 2017 | Hobart Dishwashers
Turn dishwasher on . the water loads in and then goes into wash cycle, it does it's wash cycle then drains and will not load clean water for rinse cycle it just hums a and then quits, then tries again and...
Tim Derbowka, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Tim Derbowka), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 24, 2017 | Whirlpool GU2300XTS 24 in Builtin...
Dishwasher is not washing
Possibly inlet hose line is blocked with crud from your water source. Please confirm by turning off water under sink, disconnecting hose under dishwasher and, WITH HOSE IN AN OLD MILK BOTTLE, slowly turn on water under sink to verify water flow. If ok, water inlet selenoid is blocked and needs to cleared (with compressed air). Alternatively, input seleniod is burned out and needs to be replaced.
Jan 05, 2012 | Whirlpool Dishwashers
CI am having a problem getting our Miele G575 dishwasher to run through a wash cycle. It definitely has power, the water is on and there is no water in the bottom of the dishwasher. When you turn the...
You said it does not progress...meaning the dial does not eventually move? it may be waiting on a water level sensor to be tripped. The dishwasher is just not filling. The water valve solenoid may be stuck or defective. or a wire may have come off the valve solenoid.
Mar 08, 2011 | Dishwashers
No water
Check the incoming water to the dishwasher. If the filter is clogged clean it and re fix. Strainer is located on the machine inlet junction where the hose is fitted.
The humming sound is due to motor running without water. When you rectify the inlet flow fault, pour additional water manually into the wash chamber and run the cycle. This to remove trapped air in the pump due to dry run.
May 28, 2010 | Caloric 24 in. CDU300C Built-in Dishwasher
My dishwasher fills, but won't start running. it just sits full of water and just hums.
Ok so your dishwasher won't do anything... it justs sits there and "Hums" you can't make it respond to any controls, and the ONLY way to Stop it. is to unplug the unit, replugging back in it simply "Hums" again and will do nothing.
Now this happens because, the STOP Button, is pressed and the "Door Opened", during the Wash Cycle. This should NOT be done. You shouldNEVER TURN IT OFF MID-CYCLE. you should instead, Simply, pull on the handle, to Open the door, the system will take care of everything, after, you close it,and pick up where it left off. The turning OFF, makes the machine "Think" that a New Cycle, is going to be done, before the old one is finished, and resets itself to do it all again. But it still has water, that's not meant to be there so it must dump it out.
Now, the FIX. Take the Dishwasher, out, and tip over on it's side, tip to about a 45' angle. Water will come out from underneath, this is from a small "Overflow" reservoir. this reservoir has an "Anti-Flood" switch. The removing of this water will "Reset" this Switch, and allow the dishwasher to work again.
So what happens, is this, when the STOP button is pressed Mid-Cycle, the machine must "Dump" whatever water is still in the machine, into the "Overflow Reservoir". This water then causes the Anti-flood switch to jam, and this stops the machine, until it is reset,by the above method.
Apr 14, 2010 | GE 24 in. GSD1000G Built-in Dishwasher
Loud humming noise when dishwasher is filling with water
sounds like it could be furring in your water piping. may need a plumber to check it out.
Mar 16, 2009 | Dishwashers
LOUD HUMMING AFTER WATER FILLS AT START OF CYCLE
Sounds like you have something in the sump/motor. I could lead you through it on a chat session but too much just to type. Let me know if you would like me to do so.
Mar 04, 2009 | Whirlpool 24 in. GU1200XT Built-in...
Loud humming noise when dishwasher is filling up with water
your model is pretty new. just so you know your warrenty is 1 year parts and labor. 2 years on parts. it should not cost that much money.
there are two components that start before the circulation pump.(wash noise you hear)
first sounds you hear will be the drain pump. usually rattling noises if something is in it but it can make a hum noise if something is jamming the drain propeller up. which is accessible with a T20 torx driver. take the filters out and the mesh filter. and unscrew the screw in the base towards the left. pull out whatever is lodged.
the other humming sound can come from the next component that activates is the watervalve. make sure you dont have a kinked water intake line. otherwise its a bad valve. i have had to change a few of those water valves out already but not for a hum noise on your model. you have a new style water valve. when brands make new parts we get problems fast sometimes..
Feb 14, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
GE 24 in. GSD2000Z Built-in Dishwasher Logo
162 people viewed this question
Top GE Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Steve Allison
Steve Allison
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
