Question about Toshiba A75-S125 Satellite Notebook
Toshiba a75-s125 i got this laptop ... it charges the battery but battery does not last that long. after 5 - 15 mins it shuts off and i try to reboot i enter config screen. I select norm boot and i starts again for 2 mins then shuts off. i am wondering is it over heating ... the dc input or the power supply?
  • Toshiba Master
  • 32,281 Answers
Re-charageable batteries have a finite number of charge and discharge cycles.
If your battery is a Ni-cad type battery and it is not very old, it may have a memory problem. Ni-cad batteries that are not regularly discharged to a flat state and then fully charged develops a shorter full charged capacity. This occurs when you charge a half flat battery regularly, it remembers this state/capacity. The only way to fix this problem is to discharge the battery until it is flat and then charge it to full capacity, this needs to be done quite a number of times until it regains its full capacity. If you cannot regain full capacity, you need to replace it.
If you battery is a Li-ion type of battery and does not holds it charge after a few days, even if the battery indicator shows it as fully charged and when the laptop is running on the battery and it does not last more than 1 hour then the battery needs replacing.
I don't recommend buying a second hand battery, you don't know how long it will last.
Posted on Nov 21, 2008
  • 1,073 Answers
It sounds like your battery is out of time. Buy a new one.
you can download the user manual from the toshiba website for your region. it is under the" support" section
Apr 26, 2013 | Toshiba A75-S125 Satellite Notebook
Power lights are on, but fan stops spinning after 20 secs or so
Try and change your Processor. It should work. Since the power lights are on, that means that your motherboard is ok.
Nov 23, 2010 | Toshiba A75-S125 Satellite Notebook
Need a keyboard removal guide for Toshiba netbook nb-205-n230
If you need to ask "how", I recommend that you STOP, and take the computer to a qualified technician, who can safely and correctly repair your computer.
May 30, 2010 | Toshiba A75-S125 Satellite Notebook
Power Port Damaged
YES it's simple and CHEAP... But you will not be able to do it yourself, unless your power jack is like most IBMs where it's all screw in or unless you are very good at soldering... If it's the kind that needs to be soldered, you will need to take it to an electronic tech guy who can SOLDER it for you...
But first, check and ORDER the correct POWER JACK for your Toshiba laptop from EBAY, it's cheap, maybe under $10 bucks... Then pay the tech to solder it for you, maybe another $20 buck... It's that simple...
Here is the link to your POWER JACK and YES it needs to be SOLDERED on... Good Luck...
Sep 26, 2009 | Toshiba A75-S125 Satellite Notebook
Satellite (A75S206) runs well from outlet but never from battery. Was told that mobo can't accept dc. Need new mobo. True?
hello loyd516,
Have you tried a new battery? They are much much cheaper, and a whole lot easier to replace than a motherboard.
Here are replacement batteries that I found searching with Google.
According to Toshiba, there has been a battery recall for your specific model.
If that is the case I would definitely contact Toshiba support about it. Maybe you will get a free battery out of the deal. Who knows.
Here is the link and the list(your model is highlighted)
Sony Battery Pack Recall Programs Document ID: 98082080 Posted Date: 10/10/06 Last Updated: 10/30/08 Operating System: N/A Category: Battery Distribution: Public
Applicable Models:
Satellite A70-S256, A70-S2561, A70-S2362, A70-S2491, A70-S2591, A70-S2482TD, A70-S2492ST, A70-S259, A70-S249, A75-S206, A75-S2091, A75-S2292, A75-S2291, A75-S229, A75-S209, A75-S2061, A75-S226, A75-S2261, A75-S276, A75-S1255, A75-S1254, A75-S1252, A75-S1253, A75-S1251, A75-S125, A75-S2131, A75-S213, A75-S2112, A75-S2293, A75-S2311, A75-S231, A75-S2111, A75-S211, A75-S2761, A75-S2762, M30X-S1592ST, M30X-S1593ST, M30X-S191TD, M30X-S181ST, M30X-S171ST, M30X-S221ST, M30X-S221TD, M35X-S149, M35X-S1491, M35X-S109, M35X-S309, M35X-S3091, M35X-S329, M35X-S1631, M35X-S163, M35X-S1143, M35X-S1142, M35X-S114, M35X-S3111, M35X-S311, M35X-S1611, M35X-S161, M35X-S111, M35X-S1492, M35X-S3291, M35X-S349, M35X-S3491, M35X-S3112, M35X-S1141, M50-S418TD, M50-S4182TD, M50-S5182TD, M50-S5181TD, M55-S135, M55-S325, M55-S3262, M55-S2253, M55-S3251, M55-S1351, M55-S1352, M55-S3511, M55-S351, M55-S3294, M55-S3293, M55-S3292, M55-S3291, M55-S329, M55 Series, M55-S2252, M55-S3512, M55-S3315, M55-S3314, M55-S321, M55-S3313, M55-S3312, M55-S3311, M55-S331, P30-S6362ST, P30-S6363ST, P35-S609, P35-S6091, P35-S6111, P35-S6311, P35-S631, P35-S6112, P35-S6053, P35-S6052, P35-S6051, P35-S605, P35-S611, P35-S6292, P35-S629, P35-S6291
Tecra A3, A3-S731, A3-S611, A3-S711, A5-S416, A5-S237, A5-S516, A5-S136, A5-S3291, A5-S3293, A5-S3292, A5-S329, A5-S118, A5, A5-S6215TD, A5-S116, S2, S2-S511TD
Jul 11, 2009 | Toshiba Computers & Internet
Try the link . . .
For find your best solution.
Oct 12, 2008 | Toshiba A75-S125 Satellite Notebook
Toshiba a75-s231
Your laptop's hard drive must be corrupted. Try a clean install of your operating system or try using the recovery cds included with your laptop.
Sep 21, 2008 | Toshiba A75-S125 Satellite Notebook
Problem During Boot-Up
several things it could be but im going to look at the obvious the battery and cord hook up
laptops when plugged into contstant 120 power the battery is supposed to go into stand by mode and shut battery off so power dont leak into battery
if you have low battery with it plugged into 120 the comp will still think the battery is powering the laptop if battery dead then comp shuts down lack of power
other thing is somehow you caught a virus that reboots comp from dos screen mode
the main thing i always ask is what was the last thing that happened before it did what its doing now
example= was there a power surge pop up screens ect.
May 09, 2008 | Toshiba Satellite A75-S231 Notebook
Sound driver
Could not find sound drivers for your computer but this is the sites searches you might want to try.One of theses sites could also work for the same drivers you are needing.
Toshiba Satellite A75 Driver
Detect Drivers I Need Updates
Drivers For Toshiba A75 S125
Good Luck/Please dont for get to vote.Thank You.
Dec 19, 2007 | Toshiba Satellite A75-S229 Notebook
Toshiba A75-S125 Satellite Notebook Logo
148 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
