Question about Pioneer VSX-1018AH-K Receiver
  • Anonymous Mar 25, 2014
    optical audio input
    audio/video output
  • 218 Answers
If this is a new hookup be sure this amp doesn't have pre-out/main-in jacks that may need to be bypassed. Otherwise, maybe look to see if any tape deck buttons are pushed. Good luck.
Posted on Nov 28, 2008
How to hookup sub woofer
Is there any sub woofer output for this unit? If you have one then just connect that with your subwoofer in.
Jun 13, 2010 | Pioneer VSX-1018AH-K Receiver
VSX-1018AH-K 7 Channels Receiver: My VSX 1018AH mutes automatically after 15 seconds...
The exact problem just started with my same receiver, did you get a solution to it in any way ?
May 16, 2010 | Pioneer VSX-1018AH-K Receiver
I have my vsx-1018ah receiver hooked up in for 7.1. Everything was fine for months. Now the back right speaker won't work. Speaker is fine, connection is good. Tried hooking up a different speaker and...
Assuming you're using the Surround Back speakers for their primary purpose, let's establish that there is something in the way of programming being routed to that speaker. Fire up the speaker level setup procedure and use any handy audio device (*) to see if a signal is present at the Surround Back Pre Out jack. If not, that speaker will never, uh, speak.
* For this test you could use your powered subwoofer. You DO have one, right? Just swap the RCA cable from Sub W Pre Out to the SB R Pre Out jack to see if anything appears there.
Jan 28, 2010 | Pioneer VSX-1018AH-K Receiver
No hdmi audio
some receivers need extra audio cable beside hdmi ............dont ask me why
use optical or coaxial cable for digital audio and see if it works
let me know
Jun 26, 2009 | Pioneer VSX-1018AH-K Receiver
Get ''not supported ''message on vx-1018-ah
Verify this is a Pioneer VSX-1018AH.
The manual explains it all... The problem is probably an incompatible setting on your source.
Search for "not support" in the manual...
I think this may do it... From Page 86...
No picture or sound. • This receiver is HDCP-compatible. Check that the components you are connecting are also HDCPcompatible.
If they are not, please connect them using the component or composite video jacks.
• Depending on the connected source component, it’s possible that it will not work with this receiver
(even if it is HDCP-compatible). In this case, connect using the component or composite video jacks
between source and receiver.
• If the problem still persists when connecting your HDMI component directly to your monitor,
please consult the component or monitor manual or contact the manufacturer for support.
• If video images do not appear on your TV or flat panel TV, try adjusting the resolution, DeepColor
or other setting for your component.
If ‘NOT SUPPORT’ appears in the receiver’s display, try adjusting the resolution, DeepColor or
• While analog video signals are being output over HDMI, use a separate connection for audio
• When this receiver reproduces MULTI CH IN audio sources with the HDMI setting set to
THROUGH, you cannot hear audio output from all channels. In this case, make a digital or analog
audio connection.
• To output signals in DeepColor, use an HDMI cable (high speed HDMI cable) to connect this
receiver to a component or TV with the DeepColor feature.
Check the HDMI Control (Page 65-66 of the manual). It only works with Pioneer Flat Panel TV's. Also check Page 83 for "No image is output..."
No image is output when an
input is selected.
• Check the video connections of the source component (see page 18).
For high-definition video (using component video connections), or when digital video conversion
is switched off (in Setting the Video options on page 72), you must connect your TV to this receiver
using the same type of video cable as you used to connect your video component.
• Make sure the input assignment is correct for components connected using component or HDMI
cables (see The Input Setup menu on page 67).
• Check the video output settings of the source component.
• Check that the video input you selected on your TV is correct.
Some components (such as video game units) have resolutions that may not be converted. If
adjusting this receiver’s Resolution setting (in Setting the Video options on page 72) and/or the
resolution settings on your component or display doesn’t work, try switching Digital Video
Conversion (in Setting the Video options on page 72) OFF
Apr 05, 2009 | Pioneer Audio Players & Recorders
Need an owners manual
All you have to do is go to Pioneer's USA site and get the PDF file for the manual. You may need to Google search to find that link (just search on model no. and look for Pioneer site link) as it is a retired model. I just purchased one from BB but it was complete.
Mar 29, 2009 | Pioneer VSX-1018AH-K Receiver
No audio output from Pioneer VSX-D608 Receiver
If it's under warranty..get a new one.
It's an internal breakdown service only.
Feb 05, 2009 | Pioneer VSX-D608 Receiver
Pioneer VSX-1018AH-K 7
Check if Zone 2 is 'On' if it is set it to 'Off' using the front panel button. Hitting the 'Recieiver' and 'Setup' buttons is the correct way to set the system up.
Sep 29, 2008 | Pioneer VSX-1018AH-K Receiver
Pioneer VSX-1018AH-K Receiver Logo
404 people viewed this question
Top Pioneer Audio Players & Recorders Experts
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
