Question about Hitachi 57SWX20B 57" Rear Projection Television
Can not get 1080i with composite cables or with dvi cable?
When I set my dvd player to watch movies in l080i mode it down converts to 480p? When I use the dvi cable the images look ghostly, in dark scenes only?
    Habit-Forming:
  • 166 Answers
Your TV will not play in 1080 other than via the dvi you should check they are plugged in correctly.
SUPER8
Posted on Nov 22, 2008
Formats for dvp-ns70h
selectable 720p/1080i output via HDMI digital interface (separate adapter available for TVs with DVI input)
selectable progressive-scan mode for smoother video with HD-compatible TVs (via the component video output)
optical and coaxial digital outputs for Dolby Digital/DTS /PCM
  • 1 set of audio/video outputs (composite, S-video, 480i/480p component video, and HDMI)
  • plays DVD-Video discs, DVD-Rs & DVD-RWs, and DVD+Rs & DVD+RWs
  • plays CDs, CD-Rs & CD-RWs, and MP3 CDs
  • plays digital picture CDs (JPEG)
  • remote control (multibrand for TVs)
  • 108MHz/12-bit video DAC
  • 192kHz/24-bit audio DAC
Oct 14, 2012 | Sony DVP-NS70H DVD Player
The SP7205 will only show 480P. I have connected a DVD to the 7205 via composite cables however the unit only shows 480p. How can I get 720p or 1080i?
Unfortunately the highest video signal you'll receive through composite is 480p. To achieve anything higher than the said signal, you'll need to utilize either the component or DVI input of the projector. Those inputs will detect any HD signals.
Also if you've not done so already, you'll need to check the settings of your DVD player to make sure that it's outputting 720p and/or 1080i/p signal. Hope this helps you out.
Aug 09, 2011 | InFocus ScreenPlay 7205 Multimedia...
How do I get my 52inch rca scenium to show 1080 using my ps3
Video Output Settings Adjust the system's video output settings. Select the best output settings for the TV in use.
1.
Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2.
Select in_setting.gif (Settings) > in_dispset.gif (Display Settings).
3.
Select [Video Output Settings].
4.
Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
videooutput001.jpg Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1 HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i Composite / S Video *3 480i 576i AV MULTI / SCART *4 480p / 480i 576p / 576i *1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5.
Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
videooutput003.jpg 6.
Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
videooutput004.jpg 7.
Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
videooutput005.jpg 8.
Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the in_left_key.gif button.
videooutput002.jpg 9.
Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Output Settings] in this guide.
Source: http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
Feb 28, 2011 | RCA Televison & Video
It's staying on 480i sd why not 1080i
There's only one way to get that TV to switch from 480i (which is an SD or Standard Definition signal) - that's to provide it with an ED or HD resolution signal (a 480P signal is often called ED or Enhanced Definition while 720P, 1080i and 1080P signals are called HD or High Definition).
The old standard yellow composite video cable.
You will not get ED or HD signals through the old composite RCA phono jacks (usually yellow in color), either. You'll need to use an RGB (red, green and blue) component video cable, HDMI cable, DVI, or other type supported by both your TV and the video source (CATV box, Blu Ray disc player, Satellite converter, etc.). More on this, later.
RGB cable.
An HDMI cable - this provides Digital audio signals, too.
A DVI cable.
First, you'll need a source capable of sending ED or HD signals. This can be a progressive scan DVD, Blu Ray player, HD Cable or Satellite converter, or a simple TV antenna. Not all DVD players are capable of the 480P progressive scan output - it must be labeled as such. The DVD movies are not labeled progressive scan as they all will play back at 480P if played in a DVD player capable of progressive scan, otherwise they play at 480i. A stand alone Blu Ray player or one in the Sony PlayStation 3, the older HD-DVD in the Xbox360, (it is important to note that the Nintendo Wii can output either 480i or 480P signals only when connected with their special component video cable), "set top boxes provided when you choose HD service from your local cable provider or satellite TV provider are the main sources for signals better than 480i. As mentioned above, the old standard yellow video jack is not capable of supporting signals better than 480i. You must use the HD jacks and cables between to get these signals into your TV.
The Wii 480P cable assembly - includes stereo audio, too.
Lastly, if your TV has an ATSC tuner (it is not uncommon for it to have an NTSC tuner and CATV tuners as well), you can input a UHF antenna directly into the the antenna terminals on the TV. Broadcasters in most areas have been moved into UHF bands - but some areas have one or two that operate in the VHF bands still. Check antenna web for information and help selecting antennas and broadcasters in your area. The nice thing about the antenna method is that no other cables, converter boxes, etc are needed to enjoy HD signals - plus - they're free!
Just remember you need a source capable of ED or HD signals and a way to get those signals to your TV. The yellow composite cable is from days ago and only passes 480i signals.
I hope this helps and good luck! Please take a moment to rate my reply - thanks!
Feb 16, 2011 | Polaroid TLA-04011C 40 in. LCD TV
How do I go from 480p to 1080dpi on my 65inch HDTV
If you're using an HDMI cable your display will automatically adjust the settings based upon the video source. Make sure that your source is capable of outputting 1080p. If it's an HD Cable Box or DVR, the maximum resolution it can display is 1080i. If you have one of these HD boxes, set it to only display 1080i as there will be a delay every time you change channels from a channel that is not naturally at 1080i.
If your source is a standard DVD player, it can only display images in 480i (or 480p if it is Progressive Scan) and therefore your TV will display the picture in 480 resolution. If your source is an upconverting DVD player it will display up to 1080p however, Keep in mind that DVD's are in 480 resolution and that regardless of upconversion (or upscaling, though improved, the picture will not be in HD.
The only way to achieve a true 1080p (not dpi... that's dots per inch... that's a printer term. The "p" is for Progressive Scan as opposed to an "i" for Interlaced) is from a 1080p source, i.e., a Blu-Ray disc player playing a Blu-Ray Disc with the use of an HDMI cable. Component Cables can achieve 720p/1080i only with your TV as it does not support 1080p over component cables.
As an aside, there are some media players that support 1080p output and some DirecTV Boxes and DVR's d oas well for 1080p Pay Per View movies.
Nov 23, 2010 | Mitsubishi WD-65733 65" HDTV
I Have A Vizio 32LCD and my problem is i am trying to get the PS3 to play with the HDMI I have a HDMI cabel hooked up to the hdmi input on the back of the set and it is hooked up to to the HDMI input on...
1. Check the resolution supported by your TV.
2. Select (Display Settings) under (Settings) in the home menu.
3. Select [Video Output Settings].
4. Select the connector type on your TV.
D2: 480p / 480i
D1: 480i
5. Change video output settings.
6. Set the resolution.
7. Set the TV type.
8. Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the button.
9. Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see (Settings) > (Sound Settings) > [Audio Output Settings] in this guide.
Apr 06, 2009 | Vizio L32 32 in. LCD HDTV
Yamaha HTR 5760 Video Problem with Wii
You need to connect a composite cable from the receiver. The receiver does not carry a composite signal over component cables.
Feb 25, 2009 | Yamaha HTR-5760 Receiver
How do I put it to 1080 resolution
I have this same TV and a PS3. You either need to get a HDMI - DVI cable, or plug in some component cables in order to get 1080i from your PS3. Your DVD's will upscale to 1080i and your Blue_Rays will run at 1080i, but be aware, if you play PS3 games that only read 720p on the back of the game box, the PS3 will down convert them to 480p instead of upconverting them to 1080i.
Peace, Bob
Jun 21, 2008 | Mitsubishi WS-65413 65" Rear Projection...
Converting up to 1080
Hello. You have to use the HDMI port and connect to the HDMI, or DVI, port on the back of the TV to get 1080. Even if playing HDDVD, this cable is necessary to get the increase. That, and the TV has to be in 1080 too. If you look at the display, on the front of the player, while watching the DVD, it will tell you at what resolution the DVD is playing. The HDMI to HDMI/DVI must be installed to get the increase in resolution. I have a Panasonic HD 34" 1080i widescreen TV, with DVI connection. When connected, the player played my DVD's at 1080i on my TV, while at only 480i thru the composite cables.
On some older movies or series(I like Star Trek- TNG), it doesn't work well due to the transfer to the DVD. Most newer DVD's, such as Batman Begins (there is an HD out, but I have DVD only), improved on the upconvert for me nicely.
Jan 21, 2008 | Toshiba HD-A30 HD-DVD Player
High Def.
If you are using the component inputs it will select 1080i automatically IF that is what it is being sent. Make sure your device (cable/satellite receiver) is set to 1080i. The TV recognizes 480i, 480p(progressive scan DVD player) and 1080i. It DOES NOT recognize 720p. Since it has no HDMI or DVI input it can't do HD DVD or "upconvert" DVD but it does very nicely with 480p/progressive scan.
Dec 24, 2007 | Mitsubishi WS-65311 65" Rear Projection...
Hitachi 57SWX20B 57" Rear Projection Television Logo
61 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
