Question about Peg Perego John Deere Gator HPX Ride on Toy
12v wiring diagram for perego johndeere gator
Foot petal wiring schematic
    Guru:
  • 154 Answers
Below is a the wiring diagram for the Peg Perego John Deere Gator HPX. I also included the parts diagram.
If the images are too small you can find them online (as well as replacement parts & manuals from a Peg Perego service center) here: http://peg-peregoparts.com/diagram.php?num=IGOD0055
see also: http://peg-peregoparts.com/vehicle.php?num=IGOD0055&display=overhaul
Wiring Diagram
12v wiring diagram for perego johndeere gator - c321785b-edfb-474f-aeb5-b95b778733bd.jpgParts Diagram
18872932-1308-4a2d-be44-39e68011f567.jpg b
Best of Luck!
Posted on Oct 07, 2013
  • 156 Answers
SOURCE: Peg Perego John Deere Gator not working at all
It sounds like you need a pedal switch or it has a loose connection in the wires. It is a specific Peg Perego Switch that will fit under the foot pedal. I have a gator that was doing the same thing so i replaced the shifter switches and the foot pedal switch, but I bet you could start with just the foot pedal switch.
I bought mine at this website http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego.html but you could also call them as well.
Hope this helps
Posted on Apr 30, 2009
  • 156 Answers
SOURCE: replace parts on ride-on toys
The gearboxes for both hummers and peg perego gators are under the back seat.
If you hear a clicking noise It is definatly the gearbox on the gator. The hummer gearboxes sometimes come loose from the motors, so it may be as simple as tightning the motor gearbox.
Here is how you take the gearboxes out from the gator.
1. disconnect battery
2. take hinge pins out from the dump bed to access the green cover plate.
3. take a flathead screwdriver and pry around the plastic cover to expose the gearboxes.
4. take the rear wheels off and remove the rear axle.
remove the motor gearboxes (they are interchangeable)
5. install the new gearboxes making sure the wires are secure and the wheels are going in the correct direction.
6. put back together.
7. hook up battery and your good to go!
If you have any problems are questions you can contact these guys at http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego-switches-and-shifters.html.
They have a toll-free number and are very smart when it comes to these peg perego ride on toys.
Posted on Apr 08, 2009
  • 156 Answers
SOURCE: peg perego gator wont work in forward but works in reverse
I would replace the high low switch for this peg perego gator.
The high low switch as seen here http://www.shopjandl.com/mepu0002.html will not allow it to go forward. The reverse switch will sometimes not work at all as well.
You can contact http://www.shopjandl.com/. They repair them and know how to figure out what is wrong.
I would also check the wiring on the motors. Sometimes the wiring comes loose and doesn't allow all the speeds to function properly.
hope this helps
  • 156 Answers
SOURCE: peg perego gator grinding noise?
The Peg Perego Gearbox is the item that would make a clicking noise or grinding noise.
There are two different types.
One is a cross shape and another is a pentagon shape.
If you contact the folks at http://www.shopjandl.com/ they will be able to tell you what type you need. I get all my parts from them because they help me figure the problems out.
Hope this helps
Posted on Jun 09, 2009
  • 156 Answers
SOURCE: wiring specs for peg perego polaris 700
I would contact the repair help at
They seem to know a lot about these toys
Posted on Jun 23, 2009
How to repair digital piano sustain foot petal
Do you have an ohms meter? The cable is probably defective and should be replaced.
Oct 02, 2014 | Music
What might cause my sewing machine to not respond when the foot pedal is depressed?
make sure the plug for the foot pedal is connected securely to the machine.
could be the plug in the machine has a problem even tho the foot petal is plugged in
could be the foot petal has gone out and needs to be checked.
Jul 27, 2014 | Husqvarna Viking 1
Foot petal is not working and it is plugged in.
Is there power, does the sewing bed light come on? If so there is probably a fault with the pedal. If you are practical you can open the pedal and fit a volt meter across the terminals to see if the voltage increase when the pedal is pressed.
Feb 11, 2014 | Singer 7422
My brake light won't turn off even if my foot
Your brake switch is just hung up. it is located directly above the brake petal and is attached to the petal bracket-use a flashlight and get down low enough to see up under the dash where your brake petal is, it will be hooked onto the petal bracket-just move it, it is probably just mis-aligned.
Jul 20, 2011 | 1990 Toyota Tercel
Husqvarna 3500 keeps runing
your foot petal rheostat is broken you need a new foot petal
Jan 17, 2010 | Husqvarna Viking 1
My Husqvarna Viking 980 continues to sew when I take my foot off the petal. Sometimes the stich get very tight when this occurs. Could this be the foot petal or is my circuit board going out?
I have never seen it be the circuit board, always is the foot control switch. I dont understand the stitch getting tight though. And yes, it could be the circuit board.
Mar 07, 2009 | Husqvarna Viking 1
Hope this helps
Dec 21, 2008 | Peg Perego 12 Volt Rechargeable Battery
Peg Perego John Deere Gator HPX Ride on Toy Logo
4,547 people viewed this question
Top Peg Perego Toys Experts
Marvin
Marvin
Lawrence Oravetz
john h
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
