Question about Thetford Norcold RV Cooler/Freezer
I have a Norcold n611 fridge gets too cold and freezes even on lowest setting.
On the last camping trip I ran into an issue of things freezing in the fridge, despite it being on the warmest setting. Once we got home, I turned the unit off and left if for a couple of weeks. Upon turning it back on, it cooled properly then began freezing items inside the refrigerator portion. The kids don't really care for ice in their milk. Any ideas?
  • Thetford Master
  • 1,344 Answers
The temperature control thermostat, alson known as the colds control thermostat has gone bad and basically isn't converting electrical/temperature signal properly and needs to be replaced.
Posted on May 11, 2012
  • 15 Answers
SOURCE: my norcold frig(RV) freezes food in lower level
in your refridgerator there is an internal thermostat on the cooling fan u can move up or down it should be placed on the last finn to the right looking at the fridge
thanks
cruz
cruz's mobile rv repair
Posted on Jun 17, 2009
walesarumi
  • 6993 Answers
SOURCE: reset circuit board on
there are two methods by which you can reset the circuit board, depending on the model of your refrigerator:
Procedure 1:
Click on the below link, scroll to the second (2nd) page. Read and follow the reset procedure.
http://www.rvtechlibrary.com/appliances/noco_old.pdf
Procedure 2: http://www.rvtechlibrary.com/appliances/noco_new.pdf
Good luck.
Posted on Jun 27, 2011
SOURCE: RV freezer cools, but fridge section doesn't
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Posted on Sep 12, 2009
  • 15 Answers
SOURCE: I HAVE A NORCOLD 6162 RV FRIG AND THE FREEZER
u need to open the thermister up its located on the back on the fin also check to make sure u are getting full 12 volts to the fridge check the voltage at the fuse
Posted on Jan 29, 2010
gordanddar
  • 477 Answers
SOURCE: norcold refrigerator igniter not generating a
Sounds like your ignition board is not working.
Aftermarket ones have a common automotive fuse.
Have a look at the following on line so you know what you are looking at in your unit.
Dinosaur electronice makes a UIB ( universal ignition board ) that will fit just about any fridge.
about $100 online. $250 where I tried to buy one at a rv place.
Posted on May 27, 2010
Maytag Dual Cool - fridge side too cold even on lowest setting - freezing vegtables
It's just as previous person, on warmest setting vegetables and meat are freezing in drawers
Apr 10, 2013 | Maytag MSD2651 HE Side by Side...
The Fridge Section is freezing even though I have the frisge settings on the lowest setting! Jeff Malley 0402 004405 Rye Vic.
I have this same issue on a C410B, also located in Rye .
I think its a thermostat issue, unless yours is freezing only on the bottom of the fridge (which could be a fan circullation issue)
Jan 01, 2011 | Fisher and Paykel Active Smart E522B...
I know this is a vague question. (trying to help out hubby) I am currently at work, however, our norcold elect/gas fridge/freezer in our mallard camper stopped working properly. the lp gas light is lit,...
Don't be despirate.
You need a little more knowledge ... I'm here to give it.
Your RV refrigerator requires 12 volts to operate; on gas or on electric ... it needs 12 volts - period.
Now then, your frig will get 12 volts from your 'power converter' AND/OR your battery. You do have a battery in your unit, correct? If not - why not? Get one. (Your power converter cannot provide all the 12 volts you potentially require in all circumstances. It is there to charge the battery, which CAN supply all the 12 volts you require. The converter can probably put out 15 amps - your battery can put out 100 amps or more (@ 12 volts DC). Relying only on the converter for your 12 volts will cause over heating and will eventually destroy the converter. Batteries are about $100.00 - converters are about $300.00.
As you know, your frig will run on gas if you are plugged in or on generator ... that allows your frig to get the 12 volts required to run the controls.
What about electric operation? If you are plugged in or on generator, you can run on electric because your Norcold has 12 volts from the converter and/or battery.
Whats going on? Your absorbtion type refrigerator requires a heat source to boil the ammonia mixture to create "heat removing" (you can't really cool anything ... only remove the heat from it!) You can heat the ammonia with a flame or with a electric CALROD. However, the control panel that drives the whole operation runs of 12 volts.
You have a battery and generator and are plugged in and it still doesn't work? You will find a fuse on the control panel in the compartment accessible from the outside of your unit. Check/replace the faulty fuse and you will be back in business.
I hope this helps you and hubby with your Norcold Frig. Thanks for your interest in FixYa.com. If you found this solution to be helpful, please vote. Thanks
Aug 02, 2010 | Refrigerators
Heller fridge keeps freezing up at the rear of the fridge
Model # would help!. The symtoms relating could be of a # of issues depending on the design (model #). Cold control, defrost issues, non or slow moving evaporator fan, slight pressue loss (undercharge), partial restriction, extra ambiant heat.
Ric
Mar 09, 2010 | Refrigerators
Temperature too cold even when on lowest
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 12, 2009 | Refrigerators
My norcold frig(RV) freezes food in lower level
thanks
cruz
Dec 16, 2008 | Thetford Norcold RV Cooler/Freezer
Norcold RV Refridgerator N611
Go to www.bryantrv.com and go to "service documents" and download the manual for your model "Norcold N Series". It says that 5 blinks then a pause means "no cooling detected by controls" see page 21 & 37.
Jul 08, 2008 | Refrigerators
Kenmore Side by Side Refrigerator too cold
On a fridge freezer only the fridge temperature is monitored. In a cold location the fridge might not even need cooling and the freezer would get too warm but the thing won't care.
If the fridge sensor sees it as too warm then it will keep the motor running and the first thing to get really cold is the freezer.
Remember the freezing part is not temperature controlled ion a fridgefreezer.
Apr 28, 2017 | Refrigerators
Thetford Norcold RV Cooler/Freezer Logo
2,076 people viewed this question
Top Thetford Refrigerators Experts
John Tripp
John Tripp
christian nielsen
tom wright
tom wright
Are you a Thetford Refrigerator Expert? Answer questions, earn points and help others
