Question about Pentax Cameras
A little help if you would be so kind? I have just aguiered a Pentax ME super and am having a little bit of trouble understanding the light meter. The worse thing is I also have the manual, which you'd think would throught some light on the subject, but I think a lot of that has been lost in traslation. Any pointer would be greatfully recieved. Thank you Nathan
    Champion:
    Scholar:
  • 216 Answers
Hi Nathan,
Let's start shooting without film, first.
Example: shooting outside on a bright day, let says between 10:00 to 14:00 with some clouds.
Set camera ASA/ISO to 100
Set lens to the highest number, that's the largest F Stop number.
Set camera to P, which is program. Camera will select aperature and shutter for you.
All you need is the focus and look at those LED lights, to make sure it won't lit & flashing up at the top as well as on the bottom.
If you are viewing a image that is bight without clouds, then the Shutter should be 125 and the Aperature 16. If in the shade, it will be Aperaure 11.
Start with that first.
atdlee@netzero.com
Posted on Nov 22, 2008
Can you usePentax k1000 or me super film caamera lens on a Pentax ditigal camera?
Yes, with limitations. The lenses will fit on any Pentax (now Ricoh) digital SLR. You may lose autofocus and/or auto exposure metering.
Oct 19, 2014 | Pentax Cameras
I recently dropped my Pentax K1000....oops! The only damage I noticed was a small dent in the metal side of the lens....hardly even noticeable. But now, the focus isn't working, and the light meter doesn't...
Unfortunately, this is a serious problem.
If the focus ring is not working then there is serious damage inside the lens. This cannot be repaired easily and must be taken in for repair.
As for the light meter, this is slightly more worrying as it is damage inside the body. It could be something as simple as the battery contact. But it could also be somehting more serious.
I would recommend taking it for repair.
If repair turns out to be too expensive I suggest you have a look on ebay. Pentax cameras are available with a wide range of prices and so are compatible lenses. A good upgrade would be a Pentax MX or even an LX if you can afford it. The ME super is also an excellent model if you want soemthing simpler.
Feb 22, 2011 | Pentax K1000 35mm SLR Camera
My shutter keeps sticking. I dont understand the
I would suggest you take the camera in to a qualifed service tech for a CLA (clean-lube-adjust). Like any mechanical device, a camera shutter could use periodic service.
Jun 25, 2010 | Pentax ME Super 35mm SLR Camera
When i tried to load my Pentax ME super i had trouble winding it through the sprockets and then after not being able to get it, the winder wont click over and the button will not press! any help would be...
I would say the film in the camera is lost.
Take it out with as little damage to the film as possible. If required cut the film and remove from the camera spool.
Try the camera with no film, does it work.
It could just be a bad roll of film, unlikely but possible.
Mar 21, 2010 | Pentax ME Super 35mm SLR Camera
I have a pentax me super that was recently given to me, and i have replaced the batteries however there is no indication at all from leds. i am not sure if it is broken or if there is something i am...
First, check that you've inserted the batteries the correct way up. the positive terminals face down as you hold the camera inverted. Also check that the camera's battery terminals are bright and clean.
With the batteries inserted and the battery cover in place, set the camera mode selector to Auto or M (manual) and lightly press the shutter whilst looking into the viewfinder. If the batteries are good one of the LED's from 4s to 2000 will light steadily. If they don't then you have a faulty camera and ME Supers are not easy to fix and the electronic parts which usually let them down are very hard to obtain. It's perhaps forgiveable when you think that these cameras are nearly 30 years old now... Not really a problem though as there were so many sold that it's usually fairly easy to obtain another for free (good old FreeCycle and Freegle) or very cheap, but a bit more difficult to find one which still works correctly in all respects.
The ME Super is very limited without batteries as the light meter won't work. By setting the mode selector dial to 125X you get the single mechanical shutter speed of 1/125 of a second.
If you want a free download of the user manual, it's in two parts as a pdf file on the Norman Butkus website
Mar 15, 2010 | Pentax ME Super 35mm SLR Camera
Pentax K100 Super D clicks, but no pictures.
Hate to say it, but it's dead. My Pentax K100 D Super did the same thing. Took it to the local camera shop. They scratched their heads and sent the body to Pentax. The reply that came back was that the circuit board was completely fried and it would cost more to fix than it would to buy a new body.
I was out of luck because the warranty was out (had it a year and a half), but with yours being less than a year, you should be able to get a new body without having to shell out $$$.
Jun 11, 2009 | Pentax K100D Digital Camera
How to replace back ''door'' on Pentax ME super
No, you won't. Open the back and look at the hinge of the film door. There is a small screw near the top that sticks out. push it down with your finger to release the upper door pin. Your light leak is likely coming from that area too. A bad seal on the hinge is the usual suspect.
Nov 23, 2008 | Pentax ME Super 35mm SLR Camera
Light meter not showing up
Have the old batteries leaked and left acid corrosion on the battery teminals?
Firstly i would clean the battery termainals in the camera (remove the battery lid and batteries and with a small screw driver gentally scrap the battery connection in the body) then make sure you refit the batteries correctly. if this still has not rectified you issue the camera will need to be repaired.
Good luck.
Oct 19, 2008 | Pentax ME Super 35mm SLR Camera
Loading film in my vintage camera..help!
The "magic needles" while making the camera easy to load are about as intuitive as a dead skunk, I had a similar confusion when I got an ME Super. Put the film can in the left side of the camera back (the side with the little thing sticking out is the bottom, it looks upside down this way, but that is correct). Next push the film winder down, this will semi-lock the can into place. Now pull the film-lead across the camera and push it down between some of the white "magic needles on the opposite spool(push it in a bit so that it will stay). Next advance the lever; release the shutter. If the spool starts to turn you are doing it right. Now close the door and continue advancing and clicking until the little frame number window on top reads 1.
May 19, 2008 | Pentax ME Super 35mm SLR Camera
Light meter
Yes, the Pentax ME Super has a built-in light meter. It is used by the ME Super in order to determine the correct exposure settings when the camera is used in the "A" (Autoexposure) & "AV" (Aperture-priority) exposure modes.
I don't mean to insult you, but have you tried new batteries?
Sometimes the meter fails when the batteries don't have enough juice.
Take care & Happy Imaging!
Glen
May 17, 2008 | Pentax ME Super 35mm SLR Camera
Cameras Logo
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
