Question about Argox OS-214 Label Printer
Serial Communication command to printer Argox OS-214
I would like to use a communication tester to send a command to printer to generate some barcode.For eg i would like to generate barcode 123ABC and how would the ASCII command looks like?
Regards,
Rocky Rock
5 Suggested Answers
Nic61
  • 1073 Answers
SOURCE: software for the os-214 argox printer
Yes it will! It supports Win98/2000/NT/XP
Good luck to you
Posted on Dec 17, 2008
  • 171 Answers
SOURCE: Argox 214 not compatible with vista
Thermal printers seem to be notorious for that.
Try using Vista's "Generic/Text" printer driver (you'll need to go into device manager, select to update the drivers, go to Have Disk, select "generic" as the brand). That will send raw text to the printer. Many thermal printers support this.
After you do that, you will also need to go into your printer settings and setup a custom page size that matches the size of your labels. Then you should be good to go.
Posted on Jan 02, 2009
  • 5 Answers
SOURCE: Argox OS-214 SOFTWARE
Your printers run Windows XP and Vista.
If you don't have drivers and program. You can download driver and program from below link http://www.barkodokuyucu.com/download/argox/bartender_BT801_2239_UL_Argox.exe
Ufuk
Posted on Apr 02, 2009
  • 185 Answers
SOURCE: I'm inputing ASCII via RS232 would like barcode printout
You will need to send the data using ZPL or the printer won't recognize it , if you don't have experience in this area print through the Zebra Print Driver should work. In your application use Barcode 128 as the font and see how it goes
Posted on Oct 29, 2009
  • 61 Answers
SOURCE: where can I find the
The drivers can be found at this link. Just click on the drivers tab to download the drivers and make sure to choose the correct drivers for your PC's OS.
Thank you for using FixYa!
Posted on May 17, 2011
Print command goes, but printer do not print
do you send print command by driver or PPLB/PPLA command?
Mar 10, 2014 | Argox OS-214 Label Printer
I WANT ARGOX OS-214 DRIVER AND PDR FILE
Visit this website http://www.argox.com/content.php?sno=0000067&P_ID=19 to download the driver and pdr file.
Hope this help!
Sep 06, 2011 | Argox OS-214 Label Printer
Where can I find the free software and drivers of Argox- os-214 plus since I have lost my original CD. I just need the link to download free
May 17, 2011 | Argox OS-214 Label Printer
Tags cannot be printed properly in QB POS Version 8. Printer Argox OS 214-TS
The tag printer used by Qb POS is the Zebra LP 2824.
The argox is not compatible.
Jul 04, 2010 | Intuit Quickbooks POS Tag Printer PC...
Jan 02, 2009 | Argox OS-203 Thermal Label Printer
Ufuk
Dec 17, 2008 | Argox OS-214 Label Printer
Software for the os-214 argox printer
Good luck to you
Troubleshooting Argox OS-214 Label Printer, Support
Your ribbon is not firm enough - roll the ribbon at the top until it is firm. If it is too loose it will stick to the paper. Follow directions to ensure that ribbon is installed properly.
Jun 06, 2008 | Argox OS-214 Label Printer
Argox OS-214 Label Printer Logo
228 people viewed this question
Top Argox Office Equipment & Supplies Experts
pkwc
sahoo_sanjay
Norman  J Weimar Jr
Norman J Weimar Jr
Are you an Argox Office Equipment and Supply Expert? Answer questions, earn points and help others
