Question about Kitchen Ranges
Asko gas stove has sparks going all the time on all the burners
    New Friend:
  • 21 Answers
Constant sparking (when the unit is off) means the spark module has failed or a switch may be stuck. In proper operation, the module senses a grounding condition (which is what burning gas does to the high voltage) at the burner and shuts the ignition system off.
If the unit is constantly sparking while the flame is on (which you didn't mention but is the most common complaint), you either have a miswire on the module or the ignitors and/or burner bases are too dirty to properly ground out (and therefore shut off) the circuit when lit. Also make sure the burner bases are tightly attached to the top. Replacement of the carbonized parts is the only solution - cleaning is a B.S. fix and not recommended as a final repair. You can try touching things up with a brass brush to hold a customer over in an emergency, but it seldom lasts very long.
Mark
Posted on Nov 22, 2008
Where is the pilot light on a GE profile gas stove? The burners suddenly would not light except with igniter.
Please add the make and model number of the stove. Modern gas stoves and ranges do not have a pilot light. They light the gas with an electric spark. On these models, there is a knob setting for "Light" which triggers the spark. If there is no A/C voltage to the stove, you can use a match or butane lighter to light the stove with care.
I've found that the ignition system can fail if the burner caps are not seated properly. Debris in the burner area can also lead to the ignition spark problems. If you take off the burner cap and head (for some models), the electrode will be visible. Clean off any carbon build up on the electrodes for better sparks.
Jan 22, 2017 | GE Kitchen Ranges
The igniters for the 6 burner are not sparking. The igniter for the griddle does spark. i do small gas when trying to light-how do I get to the spark modules
Gas Stove Top Burners Not Lighting / Not Working - YouTube
? 5:20
https://www.youtube.com/watch?v=dP3l5AW3YrI
Jul 19, 2012 - Uploaded by Bill Newberry
... not lighting. These are the 3 main reasons for gas range burners to not light. ... I see the igniter sparking but not lights up the gas. One thing I ...
Gas Stove Ignitor and Burner Not Lighting - YouTube
? 1:10
https://www.youtube.com/watch?v=1ZXz8_Md8hI
Nov 20, 2011 - Uploaded by Mike Klimek
Here is an easy fix if you hear the ignitor "clicking" but not lighting the burner. For more information, go to ...
How to Troubleshoot Gas Stove Burner Ignition Problems ...
homeguides.sfgate.com > Landlords & Tenants > Landlord Problems
Dec 19, 2015 | Kitchen Ranges
Kenmore gas range 790, not getting gas to the stove top, oven works, all 4 igniters fire when any knob is used. Is this a safety shutoff and how do I fix it?
Burner Spark Electrode Replacement - Kenmore Gas ...
? 2:23
www.youtube.com/watch?v=U0VcfMJPaiY
Nov 12, 2010 - Uploaded by RepairClinic.com
+Tony Eatinsky If the electrode is not damaged than the spark module ... I have a kenmore gas stove ( 362.7555190) that won't ignite unless I use a match. ... I have a Kenmore Elite 5 burnergas range top, it auto light continually sparks? .... You most likely will need to cut or grind off the screws and get new ...
kenmore model 790 gas range. the gas stove top burners ...
www.shopyourway.com > Manage My Life > Questions
kenmore model 790 gas range. the gas stove top burners stopped sparking. ... NOTE: I do not recommend measuring voltage unless you have experience and feel ... if the spark module is getting 120 volts when the burner knob is turned to the ...
Oct 19, 2015 | Kenmore Kitchen Ranges
Stoves sterling 1100DF hob burners will not ignite there is no spark to any burner. Gas flows as normal.
More than likely the spark module has malfunctioned and needs to be replaced.
Apr 23, 2012 | Stoves Kitchen Ranges
II do NOT get a spark when turning on my gas stove on any of the burners
next time send the model number and brand name,could have a bad spark module or if it has a computer board or boards in it it could be a bad board,no power is going to any of the burners
Nov 18, 2011 | Kitchen Ranges
Ignitor will not stop clicking
Marguerita , In addition to turning off the gas valve going to the stove, FIRST, unplug the stove from the electric outlet, so the high voltage ignitor (spark) will not be constantly operating and elminate the possibility of getting a serious jolt/shock.
Just follow Jumptrout's well described troubleshooting and repair instructions, but please uplug the range first and go one wire at a time, cleaning them and retrying them, or better yet, just clean them all; removing them one at a time, cleaning one, and putting it back in place until you've cleaned and reconnected them all.
Hope you find this Very Helpful and best regards!
Dec 01, 2009 | Tappan TGF320 Gas Kitchen Range
Installed stove, no flames on burners?
It may still have air in the system, turn on one burner on and allow the gas to flow with a lighter in the path of the gas see if the gas lights of at least explodes I mean until it goes Poof, once it does that if it does not light then pull the top off the stove and adjust the vents on the pipes to focus the flames and how much air is blended in with the gas, also turn the burner so that the holes are half way open, I am not sue about your stove but most have an adjustment by turning the burner 1/4 of a turn to change the flame characteristics. if this does not help post here and I will see what else I can find out on your stove. I need the modle of the stove and the regulator number where the gas hooks up.
Jul 23, 2009 | Kitchen Ranges
The ignition spark for my gas stove won't stop flicking....
Jan 16, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Stoves 900G gas oven stopped working
A lot of times the problem is with a dirty or a clogged burner. Make sure the burner is clean.
If you have a pilotless model, it uses a spark igniter to ignite the gas, which works in a combination with a spark switch (located on the burner gas valve) and a spark module. Because it is not simple to test these parts and find out which one is defective, we recommend to contact a professional appliance technician.
Sep 03, 2008 | Stoves Premier 900GRa Gas Double Oven
Ge spectra gas stove top not lighting
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Aug 15, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
173 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
