Question about Frigidaire GLMV169D Microwave Oven
Model GLMV169DQA: Significant ''arcing'' or ''flashing''
Just started arcing, two or three times per revolution of turntable while re-heating a plate of spaghetti with meat sauce uncovered and then covered with plastic.
  • Frigidaire Master
  • 9,086 Answers
Quite often this is due to grease or food particles stuck somewhere n the cavity of the oven or stuck on or behind the waveguide cover.
The waveguide cover (also called a spatter shield) is usually about the size of a playing card and often held in place by a plastic rivet.
In some models it is a larger stirrer cover type made of thicker plastic in the ceiling of the oven.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If your waveguide cover is burned, it will need to be replaced. It provides important protection for the magnetron.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Nov 21, 2008
Oven began to spark and smell. The waveguide cover broke apart & scorched side now won't heat. Clock/light work so does the turntable but groans. Is it fixable or done?
It is possible the magnetron may have been destroyed. Arcing in the waveguide would likely cause a significant increase of cathode to plate current through it; possibly melting it internally. You could also have failure of the high voltage rectifier; caused also by high current. If that's the only problem, then it's possibly repairable for a reasonable cost. You would have to repair and repainted the waveguide. Some waveguides have a vertical bar in them to aid in dispersion of the microwaves. If this is loose and shorting, then you'd have to replace the entire frame/cavity. Not very practical.
Mar 29, 2016 | Sharp R-1214 Microwave Oven
I have a GE Spacesaver PVM1870 microwave - the turntable has suddenly stopped turning. I've tried the "Turntable On/Off" button, but it did not help. What else can I try?
Perhaps the turntable motor has failed. Replace it as soon as possible as if you don't the food will not cook properly.
Replacing the turntable motor.
The motor assembly is fixed to the base of the oven usually with two screws and access i obtained by removing the inspection plate directly beneath the motor. It is usally a plug in synchronus motor that revolves at a few revs per minute but the plastic cogs in the motors gear box fail and the motor assembly must be replaced. They are fairly inexpensive and obtainable usually from a domestic appliance repair shop.
If you feel confident, disconnect it from the mains power, remove anything in the cavity and turn it upside down if it is a tabletop model, a little more complicated if it is built in!
Remove the inspection plate and disconnect the motor. Remove the motor and go and get a new one. Re fit it and put the microwave back in its position. Plug it back in, with the turntable and plate. Put a cup of water on the plate inside of the oven and heat for 20 seconds to check the plate goes round.
Hope this helps.
Jan 03, 2011 | General Electric PVM1870SMSS Microwave...
GE microwave oven squeals as carousel is rotating. Noise stops in a minute or so but begins anew when the unit is used again.
If it is the wheel on the turntable that squeels, wash the turntable in strong solution of washing up liquid and water.
If it does it without a turntable fitted, change the turntable motor.
Hope this helps.
Jan 01, 2011 | General Electric Microwave Oven
The glass plate inside will not rotate
Hope this helps.
Jan 01, 2011 | Thermador MBES Microwave Oven
My microwave oven turntable will not rotate. How should I solve the problem? Also if I just leave it and carry on using it does it matter? Model MICROMAT 21T-W
It is rather important having a turntable that revolves. Just as a matter of interest, place a refridgerated jelly in the microwave and watch as heat is only applied at one point!
Hope this helps.
Jan 01, 2011 | Microwave Ovens
Turntable does not turn - Whirlpool model mt910SFQ-0 - Accuwave 1000. The turntable turns erratically and only occasionally. It is accompanied by a clicking noise when it does not turn. Sounds like...
Hope this helps.
Dec 28, 2010 | Whirlpool MT9102SFB/Q Microwave Oven
Sharp microwave (R-959m) turntable not moving
Sounds like a new turntable motor is required.
Hope this helps.
Dec 28, 2010 | Sharp R-930AK Convection/Microwave Oven
I have a CMW-100 microwave. The turntable has intermittently stopped spinning. Now, it has stopped spinning entirely. Is there a part I need to replace to fix this problem? Judie Snivley
Sounds like the turntable motor has stopped working.
Hope this helps.
Dec 15, 2010 | Cuisinart CMW-100 Microwave Oven
GE Profile over the range microwave
It might be better to post this in the GE section, but I'll be happy to answer it here, too.
I would suspect a bad magnetron or high-voltage transformer, but it may be the turntable motor or an arcing stirrer.
If you can post back with the model number and a bit more detail on when and how it happens, we may be able to help you better.
Oct 23, 2007 | Microwave Ovens
No heat - where is the diode
Sorry to answer so late in the game, but in case others have this problem, you can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
Aug 23, 2007 | GE JVM1640 Microwave Oven
Frigidaire GLMV169D Microwave Oven Logo
85 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
