Kenwood 1000W Class D Bridgeable Mono Amplifier with Variable Crossover - Black/Blue
Problem for Kenwood 1000W Class D Bridgeable Mono Amplifier with...
Help needed
By roy_aguon on Nov 21, 2008
i'm building a moble boom box 8'hx16'l x8'w pull by a truck going around the village. i've got 2 jbl 15'' 8ohm loudspeakers, 1 jbl sub woofer 8ohm 15'' and 4-6x9 speakers for the front and for rear side of the boom box 2 - 18'' punch sub woofers 4ohms and 4-6x9 speakers'also 2-1000w for front and 1- 1000w for the rear all of will power by 1000 cranking amp battery with a charging system hook on the truck now will the amps carry the load
thank you
roy
Comments:
Nov 29, 2008
- mr.duncan
i have 3 amps 1000w 2 channel i mtght use a genarator 4000w to power the charging system also where can i get a capacitor
thank you
roy
Best Solution
posted on Nov 28, 2008
Very Helpful)
Duncan
Rank: Guru
Rating: 85%, 215 votes
Maybe, but my question would be will the truck alternator carry the load without frying. Also you will need one hell-a-chous size of battery and ground leads in order to feed that much power from the front of the truck to the amps in the trailer in back. I would think that some really big boost capacitors placed at the amps would be in order too. Also, you didn't mention how many amps you were using and what amperage they would draw. That is criticial information before you can figure out every thing else. Good luck.
Was this helpful?
Yes
No
Popular Solutions for Kenwood 1000W Class D
Questions and Unsolved Problems for Kenwood 1000W Class D
Do you recommend Kenwood 1000W Class D Bridgeable Mono Amplifier with Variable Crossover - Black/Blue?
Answer
Answer
data required for transistor 2SC560C Ie E B C pinouts
Answer
i need the schematic for the carver c-17 pre-amp. is one available anywhere? art.
Answer
no power , unit plugged in has sat for a couple months without use,
Answer
Need to know the circuit for the center channel
Answer
my amp shuts off then on after my volume reachs 25 just started doing this worked great for 2 months... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Amplifier and... Experts
Top Audio & Video Equipment Repairmen
in , OH
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
