How do i link two peavey 2600 amps together without a crossover the crossover is built into the amps cheers
  • startraxmusi Nov 22, 2008
    how to link two peavey 2600 amps together
  • startraxmusi Nov 23, 2008
    Its OK now I have been on Peavey web site and they have said YES of course you can link two peavey amps together its very simple and now I have done it so you need help so I think you should have a look on Peavey site too then it will give you more idea
  • 979 Answers
Please tell us what you're trying to do..
Posted on Nov 22, 2008
  • Michael Borelli Nov 23, 2008
    We need more info; Like what type of signal you intend to amplify, what speakers, any processing you might be doing to the signal, etc. Without a large amount of internal modification, these amps are really not going to work this way due to bridge instability.Failure due to this instability Will result in thermal runaway, and resultant component destruction..
I have 2 peavey sp 5 and a pwavey 2600 amp . i wanna know can i hook a peavey 118 passive sub to one of the sp5 and how would it sound?
You would send high as well as low to the sub and unless the sub had a built in crossover it COULD get muddy sounding. The specs SEEM to indicate the 118 DOES have a low frequency crossover so it SHOULD be OK... How would it sound? An 18 inch sub normally adds to the sound of a system... You MAY need to PAN over to send more power to the one side with the extra load on one side. Often people use two sub's... one for each side so it is balanced.
Jan 19, 2011 | Peavey SP5 2-Way PA Cabinet (800 Watts, 15...
No matter what i do, my speakers sound very basey, ther is no mid or treble and tried everything 2 correct it through my mixer 2 no avail, is ther sum setting that is needed 2 correct this problem
This is not likely to be an amp problem unless there is a built-in crossover. I don't recall if the 26oo has that option. Check for that first. Other than that, you probably have blown tweeters in the speakers. Check the speakers and update this with your findings.
Dan
Nov 25, 2010 | Peavey Pv 2600 Power Amplifier
I feel like a dork asking this question but how do you connect the amplifier to your mixer. I see that there are places for a banna plug however my mixer will not take a 1/4 banna plug.
In case you don't have one, here is a link to the manual:http://www.peavey.com/assets/literature/manuals/80300573.pdf I don't know if you are using a separate crossover between the mixer and the amp but here is the simplest explanation.I just reread your question and I don't even know whether you have a Peavey amp. Run proper cables from the main output of your mixer to the main inputs of your power amp.They will be 1/4"shielded cables or Balanced XLR cables. Do not use unshielded speaker cables to hook the mixer and the amp together.Run speaker cables from the speaker outputs of the amp to the input jacks of your speakers.Make sure the impedance of your speaker cabinets equals or exceeds the impedance rating marked on your amp. Here is the link to the newer model PV2600 manual:http://www.sweetwater.com/store/media/pv2600_doc_manual.pdf Don't use Speakon cables unless your speaker cabinets are equipped with Speakon input jacks. Banana plugs aren't as solid a connection as the binding posts are.
Nov 07, 2010 | Peavey Pv 2600 Power Amplifier
Peavey XR800F 8 channel - I can't get but very little sound to my big speakers. Help
Troubleshooting is always a "process of elimination." Have you tried hooking up your Peavey powered mixer to another set of speakers? How about connecting the speakers to another audio system? Your term "very little sound" could mean audio input problems, mixer/amp settings or failure and possibly speaker damage (internal passive crossovers). Please be more specific.
Jun 12, 2010 | Peavey Pv 2600 Power Amplifier
I have 2 peavey 900 Power Amplifiers i would like to link them together was wondering what is the input wattage it can handle?? not wanting to mess anything up!
You CANNOT link the outputs of the amps. They need to drive seperate speakers.
You can tie the inputs together so they will send the same sound to their seperate speakers.
Max power for the Peavey 900 is 900 Watts RMS into a 4 ohm speaker in Bridge mode... That is enough to blow many speakers.
May 15, 2010 | Peavey Pv 2600 Power Amplifier
Run a sub woofer to a peavey board
I would recommend using a separate active crossover such as the Peavey 23XO and a separate amp for your subs.
Jun 20, 2009 | Peavey Pv 2600 Power Amplifier
Amp will not come on
hi thanks for using fixya!!
On this error, you should check still the built in breaker.
Apr 21, 2009 | Peavey Pv 2600 Power Amplifier
Wiring my peavey 112xt subs with my peavey 2xt tops
hi don't know if you have sorted this yet, you need to wire your cables that go from sub to top +2 -2 on the speakon (on the sub end only) HTH
Jan 04, 2009 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Peavey Compressor/Limiter and Peavey 3/4/5w Crossover
The correct order is Mixer>EQ>Compressor>Crossover>Amps>Speaker. Here is the link that helped me out. Scott's PA System Tutorial
Feb 13, 2008 | Peavey CROSSOVER, STEREO 2-WAY/MONO 3-WAY,...
35 people viewed this question
 Grubhead
Grubhead
