Question about Homelite Mighty Lite Lawn Trimmer
How to restring?
Now how do i put the string on the head?
  • Anonymous Dec 27, 2008
    the string keeps cutting off every 5 seconds
  • jencooper84 Apr 26, 2009
    i cant figure out how to put more string in my homelite mighty lite weed eater i do not have a manual
2 Suggested Answers
  • 14 Answers
SOURCE: string broke off into string
Posted on Sep 12, 2010
Can I re-string the trimmer head or do I have to buy a whole new one. I have aEM4251CA string trimmer
You can restring it. If you don't have the manual to show you how to do it bring the head with you to a tool hire shop that deals in garden machinery and they'll supply it and show you how to fit it.
Jan 09, 2011 | Makita EM4251 16" 4 - stroke String...
How to get off the head so I can restring it
Unscrew the bump knob by holding the string head. Then, depress and twist the string spool and it will come right out.
Oct 05, 2010 | Ryobi Garden
Need help restringing it
For starters, if you don't have the original, in-the-box trimmer thread, you should get the appropriate diameter. Ez enough, you just need .9 to .10 diameter thread are somewhere around that diameter.
Which attachment are you trying to restring, there are several. One will have holes for a "fixed string" with a label that says "stop" on it. This is the fixed string attachment head. Take a piece of fix string, these are pieces of precut string that come with various other tidbits in the box, about 10-12 inches long. insert the string through the head the inserted end comes out the other side. Pull that end out to the edge of the "stop" label. Repeat the process for the metal hole on the other side. That's it, now you are ready to go.
The other trimmer head is a bit more difficult. Unscrew the top sleeve to expose the bare, 2 chambered core - have replacement or original thread ready to go (same diameter as mentioned previously). Once you have removed the top, notice that there are two holes with notches in between the 2 thread chambers. The notches will indicate which chamber you will be sending the thread that will be coming through the holes. Have the thread ready to go, and insert one end all the way through the hole on one side and then out the other. Now you must get the string ends coming out more-or-less equidistant from the two attachment holes so that you get an equal balance of thread being fed out of the head - either with helper holding the attachment head or by just hooking the attachment head around a pole or something, pull the 2 threads through to get them equidistant.
Once you've done this, follow the notches at the respective holes to wind the thread into the proper chamber, as if it were fishing line. Finally, put the head sleeve back
For the other trimmer head
Aug 18, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
How to restring dual feed trimmer
Aug 16, 2009 | Homelite Garden
I have a double string trimmer I cannot figure restring
check the following links :
Theses are just two, there are plenty of videos out there that shows how to resting trimmers
Hope it helps
Jul 17, 2009 | Ryobi Garden
Have weedeater but no manual to read on how to restring to line
to restring it all you have to do is pop the cap of string head pull the spool out and wind your string around it in the way they say to run it.its usually on the spool wind this way with an arrow.the cap shood be pushed in and turned to unlock the cap replaces the same way
Jun 10, 2009 | Troy Garden
Remove head to restring
you need to locate the black knob at the trimmer head and turn it coun ter clockwise and remove it to access your string spool you may have to chase the knob with pliers because some are more than hand tight
follow arrow on the spool for line winding direction
May 26, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
How do i restring the Ariens st 622 string trimmer
Cut two pieces of 18" commercial grade line - one to mount on each side. Look at the series of holes, two on bottom of rotating head, two immediately above but on outer lip of plate. Go up through the bottom two holes, even up your piece of line (like when you are putting in a new shoe string in a pair of shoes) and cross over then out through the top two. All done. If you are using an adequate grade of commercial line you can trim for hours over the roughest of stuff without worrying about restringing.
May 03, 2009 | Garden
Homelite Mighty Lite Lawn Trimmer  Logo
681 people viewed this question
Top Homelite Garden Experts
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
